Author Topic: Vacuum tube amplifiers  (Read 55791 times)
Online tony
  • Pogi/Ganda Points: 520
Re: Vacuum tube amplifiers
« Reply #1260 on: May 12, 2012, 05:49:10 PM »
pwede yun..
  • Pogi/Ganda Points: 316
« Reply #1261 on: May 12, 2012, 05:58:55 PM »
pwede yun..
ok sir , nag try ako sa 53vdc, distorted.. ;D takot pa ako sa 100, 53 lang muna :)
Offline efren
  • Pogi/Ganda Points: 210
  • old school audio fanatic
« Reply #1262 on: May 12, 2012, 06:44:14 PM »
try the old school way also.
1.replace 2,200 uF w/ 4.7uF non polar, those used on tweeters will do fine
2. replace 2uF w/ a .047/400V mylar you can find these on discarded psu or TV boards. (if not available .02, .05 .1 will also do fine.
3. since you will be using these on solid state amp, series a 220K at the output after 1meg. the purpose is to virtually isolate the high Z output of tube to the low Z input of SS amp. you can increase the rail to 100V this time, Rp=100K.
4. place 1meg from grid to ground
Please post results ;)
"just keep 'em glowing"
« Reply #1263 on: May 12, 2012, 06:55:40 PM »
di pde 100k o 220k? :D wala ako ngayon in hand. :)
Offline efren
« Reply #1264 on: May 12, 2012, 06:59:30 PM »
pwede, make it 220k.
with that set up you will achieve more or less the sound of the past, when tubes was at the height their glory  :)
the pot was too low, if you have 100k replace it.
Offline efren
« Reply #1265 on: May 12, 2012, 07:09:20 PM »
because the output was not isolated, i understand you are using solid state amp, actually you can play with values starting from 220K up to 470K, whichever matches your preference, much better for experimentation purpose, use a 500K trimpot  ;)
In my opinion that tube (& me :D) will be much happy with a 100V rail, just exercise caution...
« Reply #1266 on: May 12, 2012, 07:19:59 PM »
hehe meron ako dito 100k trimpot, cge update ako maya maya, 1 channel lang muna tirahin ko.
Offline efren
« Reply #1267 on: May 12, 2012, 07:23:08 PM »
trimpot or pot?, mahirapan ka i -volume yan ;D
« Reply #1268 on: May 12, 2012, 07:50:27 PM »
pot pala.. ;D
the tube now runs @ 100VDC, output ung SS. kaso di maitodo. dito na ba papasok ung gagamit na ng mosfet as power??
Offline efren
« Reply #1269 on: May 12, 2012, 07:52:32 PM »
anong di maitodo? distorted pa rin ba?
« Reply #1270 on: May 12, 2012, 07:56:12 PM »
parang impedance mismatch , nag separate supply ako pansamantala, ung B+ 100 tpos sa class a, ( mosfet) 12vdc battery , eto ang lakas ;D ;D ;D swabeng swabe
Offline efren
« Reply #1271 on: May 12, 2012, 08:00:04 PM »
gawin mo na 330 or 470K resistor sa output...iLan nga pala value ng blocking cap mo?
« Reply #1272 on: May 12, 2012, 08:03:22 PM »
blocking cap = 1uf 250V = ung makikita sa mga PSU
Offline efren
« Reply #1273 on: May 12, 2012, 08:06:20 PM »
ang laki pala, hanap ka .047, .05, 0.1 kahit alin dyan pupwede or any value in between ng mga yan.
Offline efren
« Reply #1274 on: May 12, 2012, 08:10:16 PM »
wala bang humming, cracking of sound, wala bang umuusok ;D
nandyan na pala si sir tony, kain muna ako :D
« Reply #1275 on: May 12, 2012, 08:18:26 PM »
wala naman sir, everything seems to be fine . i hope ;D
iniisip ko kasi kanina to
kaso ung LM317,mukhang no no no na sa 100VDC. kaya nag separate supply ako..
btw kakailanganin pa ba ng cap sa gate ng mosfet?
Offline efren
« Reply #1276 on: May 12, 2012, 10:07:13 PM »
so ok na pala, implement using both channels, later you can also implement that cathode follower design, that should match your SS amp, for the meantime enjoy the fruit of your labor, that elusive tube sound :D
« Reply #1277 on: May 12, 2012, 10:10:21 PM »
^ ok na po sir, implement ko na bukas.. :)
Offline efren
« Reply #1278 on: May 12, 2012, 10:34:18 PM »
how is the sound quality this time, how does it perform in the mid to high frequencies, what about the bass? ::)
« Reply #1279 on: May 12, 2012, 10:46:25 PM »
di ko pa ma feel, kasi maliit lang na speakers ung gamit ko ;D baka bukas ko na ma appreciate. :)
