wow dami.
ganda nun kaso wala akong output traffo any 9 pins sir tony?
any price list sir tony?
found some more gems of a tube:lots of 6RRH8, these are japanese tubes looks very closely similar to the 6H23 Russian tubes....a pair of ECC182, ECC90, 6146, 12BG7, 6DQ6, 40KG6 tubes....thse are not for sale.....as of today, for disposal are about 20+ 6005, 6AS5, 6AR5, 6AQ5 7pin power tubes, and 10 6AV6 triode/diode tubes, the 6av6 is 1/2 12ax7......as usual, cellphone loads will get you these tubes....0932-509-5191tubes are not cartoned since the boxes are already decrepit......
small signal pentodes:Bagay ang mga 'yan dito sa Tube Tester ko...for P2 petot per tube
Mazda pa tatak
Did a search for schematics using Tony and Edrel's tubes. meron na palang existing Thread dito sa atin. http://www.electronicslab.ph/forum/index.php?topic=25918.85
maybe we can convince edrel to make very small, 3/4 inch sq. pp opt....or a 5/8 inch square single ended opt.....
