regarding 7193 linestage, these are notorious noise & hum amplifier, even amplifying the mechanical noise of a power transformer if placed in close & not so close proximity, but once this issue is addressed, every one who builds this particular linestage had nothing but positive comments on the sound quality.
challenge yan sa skills mo as a builder...
Hwag mo lang kalimutan ang plate choke (small resistor wrap around wire) and bypass the filament with ceramic caps...this may help
Sir efren : gawa po kayo build thread
depende yan sa application...6H23, 6DJ8, 7DJ8, EC88, PC88, E88C, CCa, 6BK7, 6BQ7, etc...
this will help sir...+1 sayo....BTW, do you have any simple inductance meter schematics?Does anybody knows how much inductance is present with a 40w flourescent ballast...will it be good to use as inductor on tubes amps...will it pass 0.43 amperes of current as indicated?
