Author Topic: P3A amp 100 watts Help  (Read 29938 times)
Offline israfel
  • learning things by doing...
« on: March 31, 2011, 05:12:26 PM »
Guys im encountering problems with my amp, I already testing its output for DC,I only record about 10mV. But when I started playing it the 10 ohms resistor 1 watt started to get so hot, that was the resistor that connects to the ground
Offline jiggins20
  • Pogi/Ganda Points: 15
Re: P3A amp 100 watts Help
« Reply #1 on: March 31, 2011, 05:36:09 PM »
mainit rin ba output trannies?what is  ur quiescent current?
Audio amp addict
Offline israfel
« Reply #2 on: April 01, 2011, 09:31:36 AM »
output trannies is in normal temperature,my quiescent current is set to minimum setting.
Offline israfel
« Reply #3 on: April 01, 2011, 09:34:24 AM »
ginamit ko poh ang pcb na shared by jayke which is nasa thread pa too bad di pa ako maka post ng may image.
Offline a.out (drako65)
  • Pogi/Ganda Points: 30
« Reply #4 on: April 01, 2011, 10:43:03 AM »
ano voltage/current before the nag-iinit na resistor?
od</dev/urandom
Offline israfel
« Reply #5 on: April 01, 2011, 02:08:23 PM »
hmmm il try to check the output voltage and current
Offline jiggins20
« Reply #6 on: April 01, 2011, 11:08:12 PM »
10 ohms ba talaga yun.nameasure mo ba?
Audio amp addict
  • Pogi/Ganda Points: 522
« Reply #7 on: April 02, 2011, 08:25:43 AM »
could be a sign of the output stage oscillating at radio frequencies, one measure would be to put a 10 ohm base stopping resistors close to the base of the output transistor.
were you playing loud when that happened?
the topology of the output stage is prone to oscilations.....
  • Pogi/Ganda Points: 316
« Reply #8 on: April 02, 2011, 09:07:16 AM »
ask ko lang mga master kung pwede 2 npn output transistors gamitin ko dito instead of complimentary.meron ako dito 2ps 2sc5200 tsaka 2pcs 2sd1047 sayang naman  :)
« Reply #9 on: April 02, 2011, 10:48:14 AM »
pwede, yung itaas na power tranie at driver magiging emitter followers instead na compound pair...
yung sa baba as is yon.....
Offline pEN DoTA
« Reply #10 on: April 02, 2011, 01:13:38 PM »
ang galing n master tony pag audio ang pag uusapan....
GOD LOVES YOU
Offline israfel
« Reply #11 on: April 02, 2011, 03:51:49 PM »
@tony
Yes sir when i started to play it loud the resistor of 10ohms is starting to get burned
Offline israfel
« Reply #12 on: April 02, 2011, 03:54:31 PM »
Btw sir tony how can i fix the trouble?any suggestions?
and before I forget is it okay if I used 0.1uf capacitor that connect to the ground and output to the speaker sa case ko kasi d2 there no available 100nf..
Offline israfel
« Reply #13 on: April 02, 2011, 04:04:19 PM »
yes it was the 10ohms resistor na prang shunt pra sa ground.
Offline jiggins20
« Reply #14 on: April 02, 2011, 06:24:25 PM »
0.1 uf mylar cap ba ang nilagay mo sis?
Audio amp addict
« Reply #15 on: April 02, 2011, 06:52:42 PM »
ahhh, ok po sir tony maraming salamat po. +1
« Reply #16 on: April 02, 2011, 10:11:48 PM »
0.1uf = 100nf
0.01uf= 10nf
0.001uf= 1nf
the 0.1ufd is in series with the 10ohm resistor, it is also called a "boucherot cell"...
Offline israfel
« Reply #17 on: April 03, 2011, 09:32:51 AM »
yes sis 0.1uf mylar replacement sa 100nf is it okay?
Offline israfel
« Reply #18 on: April 03, 2011, 09:35:45 AM »
@tony
sir with the problem im encountering w/c the resistor of 10 ohms is getting burned when im starting to playing loud what should be done?
« Reply #19 on: April 03, 2011, 12:40:24 PM »
did you connect that in series with the 0.1uf capacitor? you can try 5watt resistors...
