Author Topic: P3A amp 100 watts Help  (Read 31933 times)
Offline p®otocol
  • Pogi/Ganda Points: 57
  • konni chi wa
Re: P3A amp 100 watts Help
« Reply #340 on: May 07, 2012, 05:52:38 PM »
try virtual dj pro
agree parang pang DJ yun pede rin parang console, like ko dun ung flanger effect :D
Selling Arduino Uno & Shields
www.circuit-help.com.ph
Offline 01110011
  • Pogi/Ganda Points: 101
« Reply #341 on: May 07, 2012, 07:54:43 PM »
pwede na kaya 'to?
Offline gorex
  • Pogi/Ganda Points: 47
« Reply #342 on: May 07, 2012, 08:06:14 PM »
puwde yan pre .magkano yan trafo sa sakura av5023?
Offline 01110011
« Reply #343 on: May 07, 2012, 08:07:16 PM »
1600 bili ko originally 1750 yan ;D
  • Pogi/Ganda Points: 324
« Reply #344 on: May 07, 2012, 08:12:16 PM »
yep pde na yan.
mahal naman,
1250 lang yan dito.
Offline j a y k e z
  • gimmegaggigsss
« Reply #345 on: May 07, 2012, 08:36:10 PM »
yep pde na yan.
mahal naman,
1250 lang yan dito.
saan yan sis hengil? :D
Offline gorex
« Reply #346 on: May 07, 2012, 09:33:13 PM »
sa acdc tommys o advance o eclipse? nabili?
« Reply #347 on: May 07, 2012, 09:35:28 PM »
Offline 01110011
« Reply #348 on: May 07, 2012, 09:53:22 PM »
sa ac-dc mactan
yep pde na yan.
mahal naman,
1250 lang yan dito.
mahal talaga lahat dito ;D
buti pa dyan sa inyo
Offline 01110011
« Reply #349 on: May 07, 2012, 09:54:44 PM »
paano po kinocompute yung amps nito? VA lang kasi yung given  thanks :)
Offline gorex
« Reply #350 on: May 07, 2012, 10:23:24 PM »
ohms law: P=EI power in watts =voltage in volts x current in amps====Power=VA voltage amps=wattage
               E=P/I
               I=P/E current in amps= power in watts / voltage in volts
               V=IR  voltage= current in amps x resistance in ohms
               I= V/R = voltage in volts/ resistance in ohms
               R=V/R
               P=V^2/R=dito ata yung power sa amps voltage ng supply / impedance ng speaker ma compute.
mga master paki check nalang sa post ko or any additional info. thanks.  ;)
Offline gorex
« Reply #351 on: May 07, 2012, 10:36:22 PM »
R=V/I.
Offline mund24
  • Pogi/Ganda Points: 37
  • Certified Boy'z
« Reply #352 on: May 08, 2012, 12:47:17 AM »
yep pde na yan.
mahal naman,
1250 lang yan dito.
but looks heavygatin yung kay sis 1saging, looks convincing yung price, kasi yung iba nyan actual eh rated lang ng 150VA-200VA not true 300VA  peke yung nakalagay kasi nga commercial sya! :)
@1saging ilang kilo yan diameter center and out even height? (toroid trans.)
Offline mund24
  • Certified Boy'z
« Reply #353 on: May 08, 2012, 12:57:13 AM »
               E=P/I
               R=V/R
dagdag ko lang converting VA to wattage in actual , you need a power factor to get its true power/wattage
in transformer side the safe power factor is 60%-75%, if mas effecient/higher quality/good implementation yung trafo you can get above 75%, since trasformer is inductor not a pure RESISTIVE load :)
lets take 70% power factor as example
is your transformer rated at 300VA
P(watt)= 300VA X .7
P(watt)= 210watts
Offline BhongTech
  • Pogi/Ganda Points: 152
« Reply #354 on: May 08, 2012, 06:04:56 AM »
tama kayu sir nasa 300va nga ang trafo na yan yun nga lang 220vac/50hz ito.may nagpagawa sa akin nung isang araw na av502 parehas ng trafo.
pwede na kaya 'to?
pwedeng pwede. ;)
nice +1.
Offline 01110011
« Reply #355 on: May 08, 2012, 08:16:05 AM »
salamat sa inyu ;) +1
Offline gorex
« Reply #356 on: May 08, 2012, 08:20:16 AM »
@saging5 ano trannies mo sa vas at driver?  bd 139 at bd 140 yan or 2sd649 at 2sd669? thanks.
Offline 01110011
« Reply #357 on: May 08, 2012, 10:55:47 AM »
^bd139/bd140 :)
Offline mund24
  • Certified Boy'z
« Reply #358 on: May 08, 2012, 09:24:29 PM »
@1saging
thanks sis :)
anyway ano yung jumper mo doon magnetic wire/copper wire ba yun? galing ah! parang overpass hehe ;D
Offline mund24
  • Certified Boy'z
« Reply #359 on: May 08, 2012, 09:28:45 PM »
pwedeng pwede. ;)
nice +1.
makanahanap nga ng ganitong trafo :)
