Author Topic: p4 mobo ayaw tumoloy magerformat.  (Read 1963 times)
  • Pogi/Ganda Points: 414
Re: p4 mobo ayaw tumoloy magerformat.
« Reply #20 on: October 07, 2011, 08:43:29 AM »
Saksakan mo ng windows 3.11.  Talo pa nyan win7.
Offline ΔЅịMø
  • Pogi/Ganda Points: 140
  • "Live Curious"
« Reply #21 on: October 07, 2011, 08:51:24 AM »
Gagamit ka nga lang ng 3rd party para maka-gamit ng TCP/IP.
« Reply #22 on: October 07, 2011, 08:59:05 AM »
Para sa luma yan sis na mga mobo using win3.11 or 3.5 ba.
Offline ΔЅịMø
  • "Live Curious"
« Reply #23 on: October 07, 2011, 10:00:03 AM »
Ahhh. Yun pala.. :D Medjo OT na.. :D
TS, musta na ang pag-rereformat mo?
« Reply #24 on: October 07, 2011, 01:39:58 PM »
Kaya lang, mabagal rin naman po sigurong mag-load yung mga dating mobo sir.
di naman, dami pa naming P4 sa opisina. mahigit 15 pa siguro tapos may isa dito sa bahay. yung P3 pababa ang noticeable ang bagal.
« Reply #25 on: October 07, 2011, 10:28:17 PM »
P3 xp na yan. P4 xp pa rin.
« Reply #26 on: October 07, 2011, 11:43:38 PM »
^ last days of P3 ('di na 'yung Slot 1 variant), following the unsuccessful Windows ME. ;D
Offline Johannah Aleksandria
  • Pogi/Ganda Points: 137
  • Make it simple
« Reply #27 on: October 08, 2011, 08:55:40 AM »
P2 at 233Mhz at Winxp no service pack, pwede mo pang magamit for MS Office at net browsing, provided 512Mb Ram mo at 64mb video card at AGP 4x. Slot 1. Maayos pa rin mag-browse.
Para kay TS, tanggalin mo yung mobo at sabunin mo, patuyuin at test uli. Na-encounter ko na yan at yung lang ang ginawa kong solution at kung marunong kang magpalit ng capacitor na lumobo, palitan mo na.
Offline Rtechy
« Reply #28 on: October 10, 2011, 09:02:24 PM »
baka possible na din yan hdd mo may problema, baka naman maluwag ung SATA cable mo or ung ide cable mo, try mo tanggal tapos kabit ng maayos o kaya ung power connector tanggal kabit mo din baka maluwag na, o kaya palitan mo ng ibang power connector na avail sa PSU mo, and nga pala pede din CDROM na... wag muna board pagsuspetsahan mo... huli na yun
Offline buddy3388
« Reply #29 on: October 27, 2011, 12:54:09 PM »
sis try mo muna 1 ram nakakabit kung dual channel yan. one at the time, pgnakluko ung isa ,try mo naman ung isa ang ikabit.
Offline ΔЅịMø
  • "Live Curious"
« Reply #30 on: October 27, 2011, 01:11:29 PM »
Ano na nga po pala ang update nito TS? :D
  • Pogi/Ganda Points: 916
« Reply #31 on: November 03, 2011, 10:41:40 AM »
aku inuuna  kng siguraduhin  buong buo ang hardware bago sa sasabak sa RF ;D
binubuksan ang PSU para makita ang loob ang magvisual check baka bloaded caps... kng duda man sa di lumulubong caps. ay pinapalitan na.... sinusunod ko naman ang optical mouse at keyboard dapat makompirm na 100% gumagana
then inusunod ko nmn ang IDE/SATA cable..., dapat nag-aapear sa BIOS lahat ng hard drive.. at ang pinakamahalaga  sa  lahat na  OK ang window CD installer.... at 100% working ang CD/DVD rom... at hindi bumibitaw....
then para makasiguro gumamit ng hirens para na bigay ni sis coolet na makulit  package  na  kasi  yun  may mini xp sa loob...  ;D
« Reply #32 on: November 03, 2011, 11:37:23 AM »
WOW galing naman dami ko natutunan sis ultrasonic. +1
Sana makuha ko yang procedure mo. Meron palang mini xp yung hirens. Teka ano ba yang hirens?
« Reply #33 on: November 03, 2011, 12:06:12 PM »
GMG  mu sis  JS  ;D
maganda  ang  mini xp... pag umabot sa desktop meaning buong buo lahat ng hardware ram, proce, mobo, vcard & etc..... except sa HD  ;D
kasi sa cd/dvd rom kasi tayo nag boot ;D
sa  ganitong way mas nabawasan halos agad ang suspect  ;D
Offline acer
  • Pogi/Ganda Points: 110
« Reply #34 on: November 03, 2011, 01:20:00 PM »
agree ako kay master ultraman
nevergive up
Offline centOS
  • Pogi/Ganda Points: 45
  • screw the screw
« Reply #35 on: November 15, 2011, 04:07:47 PM »
baka sira na HDD nya meron na bad sector
  • Pogi/Ganda Points: 524
« Reply #36 on: November 15, 2011, 06:05:54 PM »
palitan na yung psu....
Offline DJFEL
  • Pogi/Ganda Points: 44
« Reply #37 on: November 15, 2011, 08:12:17 PM »
ano kaya apdit neto..
dj fel on the mix
Offline joey022
« Reply #38 on: December 07, 2011, 04:02:11 PM »
same problem with my mobo sir... ecs g31t-m7... hangang loading lang ng windows tas hang na... na try ko ng palitan ng cd-rom, installer, ram, psu, at hdd... anu kaya prob ng board nun>? no busted capacitor po....
Offline BhongTech
  • Pogi/Ganda Points: 152
« Reply #39 on: December 07, 2011, 04:25:35 PM »
^ build in po ba ang videocard o hindi?merun din mga videocard na sa loading lang ng windows ay nag hung-up na.pag build in pwedeng me problema sa memory card.
