Author Topic: What Equipment will you buy if you have 20K pesos to start your electronics lab  (Read 2457 times)
Offline Macgyver
  • Pogi/Ganda Points: 70
    • MakerDude
If you are just starting to build your home electronics hobby area,  what equipment/tools/parts would you buy if you have PHP20,000?
Pls specify kung anong brand/model of equipment.
Offline 'yus
  • Pogi/Ganda Points: 299
  • hw -> fw -> sw
    • yus' projects
parang kulang pa rin yan 20k..  :'(
1)tektronix oscilloscope w/ passive voltage probes, current probe &
differential probe (more than 20k na 'to.. hehe :D)
2)fluke DMMs (almost 20k na rin.. hehe)
3)variable voltage/current power supply
4)tools (e.g. pliers and tweezers) and tool box
5)soldering tools (iron, sucker, lead, wick, etc)
6)comonly used electronic parts (resistors, capacitors, etc..)
Offline zer0w1ng
  • Pogi/Ganda Points: 305
    • The Cebuano Geek
-An oscilloscope is a must.
-Analog and digital multimeters.
-Temp controlled soldering iron.
-Adjustable power supply.
-good working table
The above should cost more or less 20K.
Additional items:
-breadboards
-microprocessor programmer, DIY or PICKIT2/ICD2 if you are into embedded systems.
-signal generator
-frequency counter
-hot air soldering/desoldering station if into SMD components.
-few wires with alligator clips at end, or banana connector and alligator pairs
-passive components sets (1/4W or 1/8W resistors, ceramic capacitors, electrolytics)
-common logic gates HC (74HCseries ) ICs (inverters, and gates, or gates, flipflops, counters etc.)
-computer / PC
-adjustable wall warts
The Cebuano Geek
Go for must have basic equipment like:
1.  Autorange Digital Multimeter (the one with frequency, temperature, hfe, and capacitance  test measuring functions, if you can find one with a inductance measurement it will be much better.)
2.  LC/R meter if you cant find a Digital multimeter with L and C.
3.  Temp. controlled soldering station. and associated accessories.
4.  Adjustable power supply and several regulated AC adapters.
5.  Universal device programmer (programmer for various memory and mcus).
6.  Additional cheap digital multineters.
The equipment doesn't need to be branded or expensive.  The above 3 items will cost about 8-10K max from cheap china or taiwan made products.  Keep the rest of your money for buying components for the project you want to build.  Then just start to build your equipment inventory as the need arises and when you have enough cash to spare.
Off course you will still need a printer, preferable a laser printer for printing the pcb artwork.
As for the oscilloscope, well off course all the electronics hobbyist would want one immediately but is really not needed specially when just starting out in electronics.  Test yourself first if your interest can persist into this hobby before investing in very expensive equipment.
Offline beginner wan
  • Pogi/Ganda Points: 46
    • [im]Duino
kung nagtitipid ka.. sa may quiapo, may nakita ako dun na soldering station, temperature controlled.. 800 pesos. at marami pang murang mga gamit dun.. ;D ;D ;D
Offline paranz
  • Pogi/Ganda Points: 177
  • 1/4W resistor specialist
    • RapidSignal Electronics
i would buy the best oscilloscope that will cost 20k pesos, kahit second hand oki na
Offline ahlburuto
  • E&I tech.
Hot air w/ soldering iron sa quiapo: around 1.2k-1.5k
Mulitmeter: alexan 600php (digital at auto range na ito)
soldering iron 100w (for heavy loads) : around 300-500php
tools: madaming package sa handyman or ace na branded, mura pa.
BR
Offline 1110000
  • Pogi/Ganda Points: 28
 :'( mura naman niyan bili ko sa hotair ko eh 2,500 mini pa huhuhuh parang blower nang buhok walang parang compressor sa loob
E153C51513
Baka naman hot air gun yung nabili mo.  Mahal talaga yun, around 2.5K talaga presyo nun.
Offline 1110000
yun ba tawag sa parang tubo ang blower nya nanduun nadin yung blower, tapos yung control nya nasa box parang hot air din kaso maliit
E153C51513
yung DMM ng ASTI - 550 lang. and mukhang ok naman. same functions as my Fluke (may 10A ammeter), and same readings.
eto ang list ko:
- DMM (at least 2) with a couple of probes, and clipping probes (kailangan pag multiple measurements
- a good set of precision screwdrivers (ok yung benta sa Alexan), for tinkering with mobile phones, kailangan mo rin yung pang-cellphone na screwdriver
- long nose
- diagonal cutter
- plastic cutter
- soldering iron (40W to 60W) (sometime you need 2 when desoldering/soldering in huge ground planes)
- temperature controllable soldering iron, preferably may hot-air station
- good set of solder wires (0.4mm and 1mm)
- solder sucker
- solder wick
- DIY programmers would be good to begin with
- a DIY logic probe can also assist you if you don't have an oscilloscope
- yung matitirang pera, iipunin ko panmbili ng oscilloscope ;D (pero merong mga murang brand new scope na sa USB kinakabit, marami ring 2nd hand)
additional accessories:
- 12V blower fan, you would not want to inhale the fumes
- a PC PSU converted to a bench supply (so far, puro 12V at 5V at 3.3V pa lang naman kailangan kong voltages, so it's fine for me)
  • Pogi/Ganda Points: 412
But kaagad mag jump sa oscilloscope? una alamin mo muna ang level ng skill at kung sa anung project ka ma involved..
wag basta-basta hakot ng gamit at top of the line and branded pa... :o
are you planning to design or work with high speed digital or analog circuit? which requires multi channel super accurate scope or equiptments?
ako i started at mosquito peste este..pester ng EE and started with 25 petot soldering iron..some hand tools etc....
be wised sa investment mo...invest for necessity...
RBT
simple lang sa akin
1. soldering iron
2. oscilloscope - kelangan ko nito... mas madali ang troubleshooting pag meron nito
3. DMM (diode test, resistance, voltage, current, capacitance)
4. variable DC power supply - eto kelangan ko para mabawasan ang kakagamit ng  LM78xx at LM317 v-reg during development. heheheh
5. kester soldering lead
agree with Kasamiko. pwede itabi muna yung 20k. bilhin muna yung mga kailangang gamit lang. pag nakaipon na ng mas malaki pwede na bilhin yung ibang gamit.
buy as you need. pero ang starter package lang, soldering iron, DMM (pwede rin analog), basic tools (long nose, screwdrivers, diagonal cutter), and Power Supply.
yung sinulat ko sa taas, naipon ko lang na equipments yun through the years. hindi ko na maalala kung magkano nagastos ko.
papi rdpzycho, may ipaparaffle ka ba sa mga naipon mong equipments? ;D ;D
mga nasunog na long nose kakashort ng malalaking capacitor. ;D
mumurahin lang sila. nakakahiyang ipa-raffle. naghihintay rin ako ng biyayang oscilloscope. ;D
yung toolbox ko, pang nursing na kit. ;D gusto ko kasi transparent para madaling makita kung ano yung nasa loob. and mas mura kaysa sa toolbox talaga. (80 pesos compared to 300++ toolbox)
Offline Anna
  • ONYX - Pinoy Open Source!
    • ONYX - Pinoy Open Source Technologies
don't forget the first aid kit :D
Cheers,
The WebMaster
Visit MetaDesign Web Solutions
Visit SPICEsim Electronic Designs
nice advice. ;D
hindi nga dapat mawawala yun. I also do minor machine works like drilling, grinding, and cutting of metals kaya madalas din ako masugatan. dapat laging ready ang first aid kit. mahirap maghanap ng gamot kapag tumutulo na ang dugo. ;D
Offline deanc
  • Pogi/Ganda Points: 8
Go for simple things first to get you started.
You can for example buy the following things first:
1. DMM - necessarily branded, just something to give you an indication that there is something there
2. Soldering iron - get something that is of good quality, it might be a bit expensive but there is nothing better than a good solder joint
3. Solderless Breadboard - nothing beats testing concepts to actual circuits without breaking the bank
4. Logic probe - a must for digital circuits
5. PSU - You can DIY or buy a ready built one. Could be as fancy or as simple as you want. Digital or analog display wanted but not needed as long as you have that DMM above.
6. Sturdy Work table - A place holder for all of the above and for you not to burn your dining table else you might get evicted
7. Table Lamp - stop straining your eyes, get one.
I estimate that all of the above would not cost more than 15K (may pang inom pa tayo hehehehe)
As your projects get more an more complicated and complex and you had the hang of using your equipment you can target to buy an Oscilloscope, better DMM, etc....
