Author Topic: The system could not log you on. PA HELP naman po!  (Read 1090 times)
Offline clarkie31
Re: The system could not log you on. PA HELP naman po!
« Reply #20 on: April 12, 2011, 07:58:45 PM »
ni reformat ko na lang po using recovery cd..... na open ko na cya, ang problem naman po di ako maka download ng skype and other programs sa net. laging error and failed, huhuhu... hirap talaga ng shunga sa computer.
Offline danyenz
  • Pogi/Ganda Points: 197
« Reply #21 on: April 12, 2011, 08:07:06 PM »
virus po yan kasi repair lang gawa mo sa os..virus nandyan pa din..gamit ka malwarebyte,virus removal spy doc..or clean pormat mo na 4sure..
  • Pogi/Ganda Points: 414
« Reply #22 on: April 12, 2011, 10:13:15 PM »
Kung virus yan gamitan mo na lang ng malwarebytes free po yan icombo sa avast free din po yan. Kasi i rf mo yan madali lang yan mainfect uli. Balik problema.
  • Pogi/Ganda Points: 53
« Reply #23 on: April 23, 2011, 08:29:26 PM »
Format mo na lang, kung dalawa drives yan format mo yung system drive(C is very common). Tapos install mo AV(Antivirus) then update if not updated ang AV you. tHEN Scan both drives... After scanning and cleaning(virus,malware, etc), install mo na drivers mo essential programs and the like...
if isa lang drive mo... format pero iretain mo lahat... pwd yan.. Then install AV then driver, etc.
