Author Topic: The system could not log you on. PA HELP naman po!  (Read 1092 times)
Offline clarkie31
« on: April 07, 2011, 11:59:13 PM »
mga sir/mam/ engrs/prof; patulong naman po. nag pa reformat po kasi yung BF ko nung laptop ko bago ako umalis, ok naman po cya after. kaso ngayon, pag open ko nung computer eto po yung message na lumalabas :
The system could not log you on. Make sure your User name and domain are correct, then type your password again. Letters in passwords must be typed using the correct case.
nung daw po kasi kinuha 'to ni BF, pinalitan daw po nya yung administaror (OWNER daw po yung nakalagay) ng name ko tapos nilagayan nya ng password. at eto nga po ngayon di ko na cya ma open. lagi lang po cya nag open ng window tapos mamamatay, and mag scan ng system....ulit ulit lang po cya. window XP po gamit ko.
hope may makatulong, wala kasi marunong dito na makapag repair. and di rin ako maalam sa ganito! thanks in advance po.
Offline Vaounsi
  • Pogi/Ganda Points: 146
Re: The system could not log you on. PA HELP naman po!
« Reply #1 on: April 08, 2011, 08:20:17 AM »
ayusin mo lng password mo baka mali,at case senstive din an..
Offline RhUNhA
  • Pogi/Ganda Points: 356
« Reply #2 on: April 08, 2011, 08:24:34 AM »
yup tama baka incorrect lng password,,,,try to contact ur bf bka alam nya ang correct PW..
">>>''HiNdI mO mAkIkItA aNg TaMa HaNgGaT mAsAyA mOnG gInAgAwA aNg MaLi "<<<''
« Reply #3 on: April 08, 2011, 08:30:20 AM »
Pazaway si bf... xp ba yan?
kung xp try mo cntrl+alt+del x 2
default values lang toh kung nabago toh try mo ung LIVE OS NG LINUX. makukuha rin pw niyan gudlak!
username: Administrator
pw:
blank ang pw hit enter
« Reply #4 on: April 08, 2011, 08:38:38 AM »
try to access in safemode,
upon booting up, press F8 to show the selection screen,
basta kahit anong safemode ok na yun,
check if you can access the builtin administrator account of your System..
if you can: then go to RUN: type 'lusrmgr.msc' without the quotes then hit enter
go to USERS,
right click to your account,
Set password...
proceed.. then type your new password
then voila=)
hope that you can access it..para mabawasan ka na ng problema=)
Offline de PatAtas
  • Pogi/Ganda Points: 330
  • ' The unbreakable
« Reply #5 on: April 08, 2011, 12:05:27 PM »
' rf....
  • Pogi/Ganda Points: 414
« Reply #6 on: April 08, 2011, 04:09:28 PM »
Basa mode ng matuto sa mga master.
Offline de PatAtas
  • ' The unbreakable
« Reply #7 on: April 08, 2011, 06:10:26 PM »
' eh rf na kasi...pag si umubra
Offline Vaounsi
« Reply #8 on: April 08, 2011, 07:03:11 PM »
sis patotot ano rf? reformat ba ;D ;D ;D ;D ;D ;D ;D
idol talaga kita.. ;) ;)
Offline de PatAtas
  • ' The unbreakable
« Reply #9 on: April 08, 2011, 07:07:58 PM »
' nyahhhhhhhhhhh ...parang... ;D
 sino ka ba dati?,,,nag palit ka na nman ba ng name? nalilito nako..
Offline Vaounsi
« Reply #10 on: April 08, 2011, 07:15:30 PM »
ako ung tuwang tuwa pag sinabi mo format na..nyahahahah
Offline de PatAtas
  • ' The unbreakable
« Reply #11 on: April 08, 2011, 07:20:36 PM »
Offline clarkie31
« Reply #12 on: April 08, 2011, 09:15:00 PM »
iyon na nga lang po yata talaga ang choice ko ang mag reformat ulit.... di ko po kasi cya malagay sa safe mode, lagi pong nag kakaroon ng blue screen... ang problem ko is yung mga files na na transfer ko dito, di ko na cya ma retrieve kasi di ko ma open yung windows. hay, kakalungkot naman. anyway, salamat po sa lahat ng nag reply.
« Reply #13 on: April 08, 2011, 09:29:44 PM »
kung laging nagbbluescreen..
same thing.. press F8 momentarily upon booting up, then select "Disable Automatic System Restart", Get the error log and post it here =)
« Reply #14 on: April 09, 2011, 05:43:27 AM »
:D baka hardware na tama'
sunod na niyan panay restart na pagkareformat :)
Offline RhUNhA
« Reply #15 on: April 09, 2011, 07:31:41 AM »
posible sis :)
Online danyenz
  • Pogi/Ganda Points: 197
« Reply #16 on: April 09, 2011, 10:34:04 AM »
baka madala pa sa repair wag mo deritso format selsct mo repair d mawawala files mo.. nxt time partition mo hardrive wag ka save files sa local c...magreformat ka man di wala files..
PAPUNTA KA PA LANG.......PAUWI NA AKO.....
Offline Vaounsi
« Reply #17 on: April 09, 2011, 01:20:33 PM »
kung very important files mo at nagawa mo na lahat suggest mga master,pullout mo hdd gamitan mo enlosure to recover files.. saka mo rf..
Offline clarkie31
« Reply #18 on: April 09, 2011, 08:17:42 PM »
sige po update ko bukas nasa work kasi ako tonight. di ko nabuksan kanina, nakigamit lang po ako ng PC. hay nababad trip nga ako, kasi 500 pesos pa binayad ko. tapos pinalitan lang ng name yung computer, mas lalong pang dumami ang problem kesa nung nireformat. hayzzzzzzzz........... salamat po mga sir! try ko po bukas yung payo nyo.
Online danyenz
« Reply #19 on: April 09, 2011, 08:43:18 PM »
hahaha siguro hindi taga elab tech mo...
