Author Topic: Jvc av-21f3px shutdown after 5 sec.  (Read 2370 times)
Offline bododot
« on: April 08, 2011, 12:15:07 AM »
Mga master patulong naman po nitong jvc av-21f3px nag shutdown po xa after 5 sec. May  B+ 135, 9v, and 5v naman po xa at tama naman po voltage sa tuner.
Offline NORTH LUZON
  • Pogi/Ganda Points: 812
Re: Jvc av-21f3px shutdown after 5 sec.
« Reply #1 on: April 08, 2011, 12:37:27 AM »
check mo vertical section nyan
  • Pogi/Ganda Points: 915
« Reply #2 on: April 08, 2011, 01:12:44 AM »
do the basic  muna.. at add more info
Offline bododot
« Reply #3 on: April 08, 2011, 01:26:49 AM »
Ang nangyari po dito ay pag nai saksak sa outlet na 220 or 110 then power on nag oscillate naman po xa tapos makikita mo  na ayos ang display may osd tapos biglang nag shutdown xa sabay continues blink nang timer led.
Offline RhUNhA
  • Pogi/Ganda Points: 356
« Reply #4 on: April 08, 2011, 07:20:39 AM »
resolder k muna sis...check sa mga loscon,,both sa main at c board ...
Offline Vaounsi
  • Pogi/Ganda Points: 146
« Reply #5 on: April 08, 2011, 08:12:33 AM »
una replace ecaps primary psu,pg ganun p din check vertical sec,direct sub ng mga parts
Offline RhUNhA
« Reply #6 on: April 08, 2011, 08:20:04 AM »
try m din yung traynie jan sa pligid ng fbt kung mron yang model nyan,,,hope this help
  • Pogi/Ganda Points: 771
« Reply #7 on: April 08, 2011, 04:44:54 PM »
replace 1000uf sa secondary
Offline jmg
  • Pogi/Ganda Points: 83
« Reply #8 on: April 08, 2011, 07:38:38 PM »
monitor mo B+,5v,9v kung bumabagsak kapatid..
exact bang 5 seconds lagi pag nag shutdown?
d kaya nagloloko ang clock nyan? grandfathers clock?? ;D
Offline taqui
  • Pogi/Ganda Points: 228
  • ang ganda ko
« Reply #9 on: April 08, 2011, 07:45:00 PM »
patambay po..ng matuto sa jvc
Offline bododot
« Reply #10 on: April 09, 2011, 12:40:24 AM »
ok try ko munang palitan ang 1000 sa secondary at tsaka sa primary cap.
Offline NORTH LUZON
« Reply #11 on: April 09, 2011, 12:57:58 PM »
yup,sundin mo muna si master pete baka jan lang yan
check mo din ang vcc ng jungle
Offline lhan
  • Pogi/Ganda Points: 182
  • agta maloko
« Reply #12 on: April 09, 2011, 01:30:41 PM »
subscribing
Offline bododot
« Reply #13 on: May 07, 2011, 12:27:06 AM »
Sorry mga sis ngayon lang ako naka balik, napalitan ko na po yung 1000 ecaps pati yung vertical ic pero ganun parin nag shutdown xa after 5sec.
Offline x13r_kit_0
  • Pogi/Ganda Points: 150
  • --__x13r_kit_0__--
« Reply #14 on: May 07, 2011, 12:34:05 AM »
nagawa na po ba lahat ng suggest...
makiaral nalang.
   =How about the other side?=
Offline Vaounsi
« Reply #15 on: May 07, 2011, 12:40:25 AM »
syanga pala pag shutdown ba nito may secondary voltages ba kumpleto,o wala? observe b+ kng may pagbabago bago magshutdown..baka regulator pala sira nito..
maghanap ng tranie around flyback kung meron  ,tutukan collector kung may output bago magshut down,kung wala nasukat palitan na yan feedback yan galing flyback ovp yan.
Offline bododot
« Reply #16 on: May 07, 2011, 12:54:08 AM »
Sinubukan kng i hung isang paa nang 8mhz crystal hindi xa nag shutdown pero  yung display nya may 4 sided 1" black screen.
Online J@M
  • Pogi/Ganda Points: 122
« Reply #17 on: May 07, 2011, 03:56:43 AM »
abang nlng tingin ko nsa mga suggestion na mga master ang culprit.
Don't Give up
Offline RhUNhA
« Reply #18 on: May 07, 2011, 05:46:42 AM »
na try m ba lhat ng suggestion....
Online J@M
« Reply #19 on: May 07, 2011, 12:33:49 PM »
Ts update mo kung nasubukan na lhat suggestion para maka move na..
Don't Give up
