Author Topic: DIY Zener Diode tester  (Read 900 times)
  • Pogi/Ganda Points: 772
« on: April 09, 2011, 10:47:11 AM »
share ko lang po ito  ;D
hirap naba kayo kakabasa ng code ng zener diode? ako hindi pa naman waglang burado ang code, kaya
naisip ko e share naman ito sa mga elabers
kinuha kolang ito sa psu ng may 24v (SMPS)
ito naman ang actual na voltage reading
ginawan ko ng lagayan bali naka series ang 1k sa B+
ito ang actual na reading ng zener diode 7.8vdc
ito ang actual na reading ng zener diode 8.4vdc
nakuha kolang ito sa ibang site matagal na
Re: DIY Zener Diode tester
« Reply #1 on: April 09, 2011, 11:48:01 AM »
hay sorry diko na nabago ang voltage reading dapat sa baba ang 8.4vdc hehehe nawala ang connection natin
Offline stcboy
  • Pogi/Ganda Points: 5
« Reply #2 on: April 24, 2011, 08:52:26 PM »
Pwede ba share mo schema para masubukan at magamit din madami ako zener na di na mabasa ang marking at ilang volts supply nya bro.
Regards,
« Reply #3 on: April 24, 2011, 09:27:22 PM »
Regards,
series kalang ng 1k sa positve supply
pwede dito kahit 36vdc
Offline NORTH LUZON
  • Pogi/Ganda Points: 812
« Reply #4 on: April 25, 2011, 02:23:58 AM »
ang galing ni master pete
pogi mo sir pete
ask ko lang,kaya ba nyang sukatin ung 91volts zener sis?
« Reply #5 on: April 25, 2011, 05:56:15 AM »
pogi mo sir pete
pwede sir kahit 100vdc pa basta supply mo mas mataas din hehehe at syempre kunting adjust sa resistance ng resistor
Offline JiMmYbRaVø
  • Pogi/Ganda Points: 57
  • wag kang susuko, hanggat may elab may pag-asa
« Reply #6 on: November 26, 2012, 05:03:50 PM »
master pete pwede po ba gumamit ng 12vdc supply? O 24vdc tlga ang minimum?
Practice as if you're the weakest,
Perform as if you're
the best..
« Reply #7 on: November 26, 2012, 05:09:39 PM »
pwede yan kaya lang kapag ang reading ay same as the supply voltage ibig sabihin either open yan or mataas sa supply voltage ang zener voltage.
Online tony
  • Pogi/Ganda Points: 523
« Reply #8 on: November 26, 2012, 05:27:40 PM »
Gawa ka ng 100volt dc supply, then gawa ka ng CCS set for about 2mA, sakop mo na testing ng maraming klase ng zener.....
  • Pogi/Ganda Points: 414
« Reply #9 on: November 26, 2012, 06:55:02 PM »
papogi ka muna  +1
Offline Deantyne
  • Pogi/Ganda Points: 90
  • Focus my friend...
« Reply #10 on: November 26, 2012, 07:09:24 PM »
sorry di ako maka-relate, ano po yong CCS set at 200mA?
BACK TO BASICS
« Reply #11 on: November 26, 2012, 07:11:53 PM »
ccs = constant current source
« Reply #12 on: November 26, 2012, 07:12:23 PM »
http://www.ecircuitcenter.com/Circuits_Audio_Amp/BJT%20Current_Source/BJT_Current_Source.htm
i-compute na lang sa 2mA 'yung current. 'yun kasi 'yung typical average na zenering current ng mga zener diode.
Offline Deantyne
« Reply #13 on: November 26, 2012, 07:19:25 PM »
ok tnx po, im planning also to try this.
yong gamit ko kasi is LM555 , pinakamataas is only 30v...
BACK TO BASICS
Online tony
« Reply #14 on: November 26, 2012, 07:25:12 PM »
make sure that the CCS is heatsinked just to be sure.....with a ccs, you can short out the output and nothing smokes.....and it adjusts its terminal voltage to maintain the 2mA....the voltage reading at the zener terminals will be its voltage rating...
Offline JiMmYbRaVø
« Reply #15 on: November 26, 2012, 10:01:42 PM »
wow hindi po ako makarelate.hehe pasensya na po,wala akong aral sa mga ccs at iba pa,hindi po ako nakapag college. Vocational lang.. Ganito nalang ang gagawin ko,i will use a stepped down transformer (220v in, 110v out) at gamit ako fullwave bridge tapos 160v 1000uf ecap , ano po pwede gamiting resistor? At yun na 110vdc na ang output.. Tama po ba? Ngayon sa zener testing ,sa positive out anong value resistor gagamitin ko? At san ko ikoconnect ang negative out ng supply? Salamat sa magreply hehe
the best..
Offline JiMmYbRaVø
« Reply #16 on: November 26, 2012, 10:06:37 PM »
pano po makagawa nung ccs with 2ma? Wala po akong idea.. Hirap tlga kapag walang aral.. Masahol pa sa nakapiring ang mata at nangangapa.. Haist
the best..
Online tony
« Reply #17 on: November 27, 2012, 04:48:24 AM »
wag yan, delikado yan, makukuryente ka....kailangan isplation type traffo ang gagamitin mo, 100volts dc requires around 70volts ac, low current lang yan...
Online TBG
  • Pogi/Ganda Points: 145
« Reply #18 on: November 27, 2012, 05:27:28 AM »
pangtesting ko ng zener ay yung basic na voltage regulator na gumagamit ng isang transistor na may 1k connected sa collector to base at ang zener naman connected sa base to ground.yung input sa collector at ang output naman sa emmiter.masusukat mo ang value ng zener sa base ng tranny.
Offline JiMmYbRaVø
« Reply #19 on: November 27, 2012, 09:37:24 AM »
thanks sa babala sir tony, pero wla po tlga ako idea.. Sis tbg pwde po ba makahinge ng diagram ng gamit mo? With components value.. Kung ok lang po sir
the best..
