Author Topic: SAKURA Amplifier AV-732  (Read 2319 times)
Offline ars
  • Pogi/Ganda Points: 7
  • No man is an island
« on: April 18, 2011, 08:39:01 AM »
Mga sis meron po akung customer sakura amplifier po, binuksan ko po kanina sunog po ung fuse sa secondary PSU ung nag drive ng 34Vac. Sa ngayon ung lang po nakita ko na sira, tanung ko lang baka meron na dito naka encounter ng ganito, anu po usually sira nito fuse lang ba?  TIA
  • Pogi/Ganda Points: 315
Re: SAKURA Amplifier AV-732
« Reply #1 on: April 18, 2011, 08:46:43 AM »
ung iba sira na output trannies
di lang ako sure wait natin mga masters.
  • Pogi/Ganda Points: 231
« Reply #2 on: April 18, 2011, 10:44:55 AM »
Check mo yung mga output transistor , may shorted yan..
Offline taqui
  • Pogi/Ganda Points: 228
  • ang ganda ko
« Reply #3 on: April 18, 2011, 11:12:33 AM »
output trannie,
check narin lahat ng drive trannie bago mgpalit ng output para sure sayawan na..
Offline Triple_D
  • Pogi/Ganda Points: 164
« Reply #4 on: April 18, 2011, 11:35:02 AM »
agree ako sa mga master sayawan na yan at kapehan..
Offline BUMBLEBEE
  • Pogi/Ganda Points: 109
  • transform!!!!!!!!!!!
« Reply #5 on: April 18, 2011, 11:37:08 AM »
patambay follow all comment..
  • Pogi/Ganda Points: 771
« Reply #6 on: April 18, 2011, 12:13:04 PM »
check driver, hung mona lahat ng output tapus sukatan mo ng voltage dapat pari-parihas ang makukuha mo kahit + at - basta pariho ng reading
Offline Vaounsi
  • Pogi/Ganda Points: 146
« Reply #7 on: April 18, 2011, 01:02:38 PM »
makitambay nga..agree sa mga master
shorted output cguro to..  madali lng gawin yan ala bangongot cool klng...congrats na..
« Reply #8 on: April 18, 2011, 01:05:33 PM »
bebangis ikaw ba si kuryenting baterya?
Offline Vaounsi
« Reply #9 on: April 18, 2011, 01:07:33 PM »
hehehe at ur service master..+1
« Reply #10 on: April 18, 2011, 01:10:15 PM »
copy dot points din sayo +1
Offline taqui
  • ang ganda ko
« Reply #11 on: April 18, 2011, 02:48:09 PM »
mga sis pa ot.. bigyan ko lang kayo ng points para sa mga utang ko yan..
TS sundin lang payo ng mga master at kapehan na yan.. basta be sure sa pag kabit ng mga trannie dahil meron jan na hindi dapat naka dikit sa ground.. check nyo narin mga fusable resistor at pati ung mga diode nyan..
goodluck
Offline ars
« Reply #12 on: April 18, 2011, 04:43:38 PM »
sis taquinaga...+1 sis pete,,,+1 ung untang ko pala points para sa  n u...try ko advice nyu 2nyt....
« Reply #13 on: April 18, 2011, 11:18:55 PM »
uy salamas hehehe
Offline ars
« Reply #14 on: April 20, 2011, 08:28:33 AM »
mga sis na check ko na ung output xsistor mosfet ung gamit nito 2SK899 at saka mga driver trannie,,wala naman akung makitang sira,,,d nga palang aku ng voltage check,,,sis ok lang po ba e power on ung amp. na d ikabit ung output nito? for voltage checking purposses. d ko kasi na try to.
Testing ko ito mamaya,,,kong  meron na po bang changes kasi galing to sa ibang tech. kinabitan ng jumper ung fuse.
Offline taqui
  • ang ganda ko
« Reply #15 on: April 20, 2011, 08:34:44 AM »
yap pwde yan, for safety narin ng output, baka brigde diode sira nyan ha..
Offline x13r_kit_0
  • Pogi/Ganda Points: 149
  • --__x13r_kit_0__--
« Reply #16 on: April 20, 2011, 08:42:17 AM »
wala na po ba kayo natrace na shorted...
check for bias voltage...for sure na hindi masira ang output mo.
   =How about the other side?=
Offline RhUNhA
  • Pogi/Ganda Points: 356
« Reply #17 on: April 20, 2011, 08:59:39 AM »
ok nga kung hindi m muna ikabit...pero ok kba tlaga n buo yan...yung bias voltage check mo kung n5551 ginamit direct plitan mo na...
« Reply #18 on: April 20, 2011, 09:21:48 AM »
mosfet :) :)
Offline ars
« Reply #19 on: April 20, 2011, 03:31:58 PM »
Meron sis, meron nga n5551,,,ok bali aku ngayun ng ma testing ko mamaya..
