hehehe ganon nga dalawang linya lang kailangan mo kung single phase lang kailangan mo, at kung kailangan mo naman na gamitin yung max power ng 3 phase mo simple lang yan tatlong transformer lang kailangan mo
naguluhan ako ah. yung thread kasi 3 to 1 pero yung question 1 to 3.
di mu naman kelangang iconvert pa yung 3phase to single phase ah. kung ang system voltage mo eh 230vac 3phase at gusto mo ng single phase na 230vac eh yung dalawang line lang ang gamitin mo. pero kung madae kang load na single phase tapos 3 phase ang supply mo eh kelngan mo lang gawin eh load balancing.nasagot ko ba tanung mo?BR
anu yung max power? para saan yung tatlong transformer?
wala namang problema dun ah. 230vac pa din makuha mo na voltage dun at 60hz pa din.... ang mahalaga sa 3phase system eh yung load balancing. halimbawa, kung sa factory mo eh meron kang 3 load na single phase at ang wattage nya eh sabihin natin na 10,000watts, ang connection nun sa line eh yung load 1 sa L1 & L2 yung load 2 eh sa L2 & L3 at yung load 3 eh L1 & L3. para balanse yung current mo sa 3 phase.BR
ang ibig sabihin ko ay yung MAXIMUM WATTAGE LOAD kung 600W ang 3 phase mo 600W lang ang maximum na pwede mong i load ay 600W lang, at kung gagamitin mo lang eh yung 1 phase mahahati sa tatlo ang maximum yung 600W na 3 phase mokaya ang maximum mo na lang na pede i load eh 200W na lang kung gagamit ka naman ng tatlong transformer i kokonvert mo yung 600W na 3 phase sa 600W din na 1 phase (hindi step down transformer ito)
hehehe sensya
Hindi ko pa rin magets. Mathematically, you'll definitely get either more or less than 230V output if you use two 230V out of phase lines.Your answer just assumes you'll get 230V 60Hz single phase from using 2 230 live lines which are out of phase w/o any explanation.Ang pagkaka-intindi ko, in order to get lets say a single phase 230V from a three-phase system is by tapping only one line lets say L1, and feeding it to a 1:1 transformer. The output of the transformer is center-tapped and the center tap is earth grounded. This way, you get 2 115V on each line that adds up to a 230V output. I'm not an electrical engineer so I'm not sure of my understanding.
