Author Topic: how to add an application to BC2MOD2C using BlueLab  (Read 950 times)
Offline bisr2k
  • "Learning is fun.." -GB
« on: May 20, 2008, 08:49:45 PM »
hello pips,
has anyone here tried opening their usb bluetooth dongle.. the older model is using a BC2MOD2C module it is said to be based on CSR's BC02 Chipset (4Mbit)has 8Mb of Flash memory(some site say its only 4Mb) and the good thing about it is that it programmable :)
it uses Bluelab SDK for its software develeopment.. kaso nga lang I'm still new to bluetooth technology at nangangapa  pa ???
patulong naman dyan sa mga nakatry na nito o   ;D
ito nga pala yung pin config ng BC2MOD2C
18                          17
PCM_OUT /      GROUND
PCM_SYNC /          3V3
PCM_IN /              1V8
PCM_CLK/      UART_RX
USB_DP   /   UART_RTS
USB_DN/       UART_TX
PIO(7)/       UART_CTS
PIO (6) /           ignore // SPI MOSI
PIO(5)              ignore // SPI CLK
PIO(4)/             ignore // SPI CBS
 PIO(3)/            ignore // SPI MISO
PIO(2) /            RESET
PIO(1)              AIO(1)
PIO(0)/             AIO(0)
GROUND /       GROUND
RF          / NO CONNECT
GROUND   /      GROUND
 34                        1
Offline bisr2k
Re: how to add an application to BC2MOD2C using BlueLab
« Reply #1 on: May 20, 2008, 09:55:44 PM »
ops sori nagkamali ng post :)
dito nalang po kayo mapost about the topic "http://www.electronicslab.ph/forum/index.php?topic=2618.0"
