Author Topic: Deepfreeze icon missing in system tray  (Read 1984 times)
Offline akhen
  • Pogi/Ganda Points: 47
« on: May 03, 2011, 07:30:52 PM »
mga sistah,
sino sa inyo nakaexperience na nito? nawala sa system tray yung icon ng deepfreeze di ko tuloy maunfreeze...
ano kaya solution dito?
Offline tiktak
  • Pogi/Ganda Points: 203
    • Tiktakx's Blog
Re: Deepfreeze icon missing in system tray
« Reply #1 on: May 03, 2011, 09:39:40 PM »
yung deep unfreezer ang ginagamit ko noong nag memaintain pa ako ng shop, meron na din ata ga bago na supported an deep freeeze 6
8051 stuff
Offline shadowstriker07
  • Pogi/Ganda Points: 10
  • DELL Business Printer Hardware Warranty Support
« Reply #2 on: May 11, 2011, 12:05:03 PM »
unfreeze only works if u forgot the password of your Deepfreeze..(otherwise the DP icon shld be there) even Deepfreeze icon is missing on the sys tray its still on task manager else DP is still working(freezestate)... until now wala parin aq Solution d2 :p....  but still may instance na sa kakarestart mo ng PC lalabas ung icon... tsambahan lng kpg mabilis magload ung OS... kpg mabagal Error message from DP ang makukuha muh.. otherwise wala solution... already tested on SAfemode wala din...
wait n lng muna natin update from others
Blow Job!!!.. Is the Only WORD that cannot be written on a resume` despite of years of Experience and References
Offline akhen
« Reply #3 on: May 11, 2011, 12:28:47 PM »
andami ko ng natry wala pa din... tsk tsk tsk
  • Pogi/Ganda Points: 413
« Reply #4 on: May 11, 2011, 12:38:13 PM »
Hindi ba pwede sis yung unfreezer. Then uninstall df and reinstall again?
Offline akhen
« Reply #5 on: May 11, 2011, 02:48:57 PM »
Di nya nadedetect yung deepfreeze sir e...
Offline Macgyver
  • Pogi/Ganda Points: 70
    • MakerDude
« Reply #6 on: May 11, 2011, 03:10:07 PM »
wala ba dun sa "show hidden icons"?    Sa win7 ko kasi meron yung mga hidden icons tapos pwede mo
  • Pogi/Ganda Points: 316
« Reply #7 on: May 11, 2011, 03:15:32 PM »
running ba ung deepfreeze mo sa Processes
na makikita sa Task Manager?
or puntahan mo nlang kung saan naka locate ung application na niyan
Offline Vaounsi
  • Pogi/Ganda Points: 146
« Reply #8 on: May 11, 2011, 03:53:42 PM »
hindi mo makita kung saan location nyan, gnagawa ko lng dyn maginstall ako ulit ng deepfreeze then magkaroon yan ng option n unstall mo lng saka mo nlng ulit install
Offline de PatAtas
  • Pogi/Ganda Points: 330
  • ' The unbreakable
« Reply #9 on: May 11, 2011, 05:53:04 PM »
' bakit wala ba sa program files ang exe ng deepfreeze ?
Offline spoco
  • Pogi/Ganda Points: 13
« Reply #10 on: May 11, 2011, 06:02:54 PM »
naalala ko yan deepfreeze na yan... pinahirapan ako mag repair ng isang computer dahil jan..  ;D ;D ;D nung kalikutin ko ng husto yung OS. nyihihi ;D ;D may deepfreeze pala kaya di ko ma alter ang mga settings.. ;D ;D ;D
Offline Vaounsi
« Reply #11 on: May 11, 2011, 06:10:08 PM »
pagnawala sa system tray nawala na sa program files,ewan ko kung bakit kahit ano hanap ko di ko makita kaya un lng ginagawa ko paraan unstall & intall nlng ulit..
Offline spoco
« Reply #12 on: May 11, 2011, 06:22:38 PM »
pero kahit wala sya sa sa system tray or program files makikita mo sya sa task manager kung nag ra run sya, under ng processes tab.
ummmm di ko lang sure kung makikita mo sya sa services ng windows.. if makita mo. manually stop the service of deepfreeze and start again..baka pag ginawa mo yun mag popup yung deepfreeze application kahit wala sya sa system tray and program files.
yun ay naisip ko lang pero di ko pa nagawa yun. ;D ;D pero di masamang subukan.  ;D ;D
Offline bombelat
« Reply #13 on: May 11, 2011, 06:30:04 PM »
Uninstall nalang den install ulit?
Offline akhen
« Reply #14 on: May 11, 2011, 06:35:50 PM »
maitry nga yan....
Offline de PatAtas
  • ' The unbreakable
« Reply #15 on: May 11, 2011, 06:37:01 PM »
 ' ah,,, kasi sakin dati nawala sa system tray pero andun pa rin sa program files... ginawa ko di noble click ko nalang  kaya bumalik sa system tray... teka anung version ba to ng defreeze?
Offline bombelat
« Reply #16 on: May 11, 2011, 06:42:06 PM »
Sir first try to run FrzState2k.exe
Offline spoco
« Reply #17 on: May 11, 2011, 06:50:10 PM »
na try mo naba tong gawin sis --> CTRL+ALT+SHIFT+F6
Offline akhen
« Reply #18 on: May 11, 2011, 07:36:27 PM »
yup.... di nagana yan sa version 7 ng deepfreeze...
ambangis mo talaga patotot... nakita ko na nasa program files nga...
problem solved... ganda mo patotot...
Offline Vaounsi
« Reply #19 on: May 11, 2011, 07:44:36 PM »
ayos!! buti na sa program files pa.. ;D ;D
