Author Topic: Philips 21PT1323/71R Power Shutdown Problen  (Read 2039 times)
Offline Berlin C. Alcayde
  • Pogi/Ganda Points: 5
« on: May 09, 2011, 01:46:43 PM »
Mga masters help naman po sa TV  na ginagawa ko. Ang Trouble ay nagsashutdown, pag lumabas ang picture e bigla na lang mag-sashutdown ang TV. Pag pinindot ko ang channel button e mag-oon ulit. Pag diniinan ko ang channel button e d na mag shutdown ang TV pero lipat ng lipat lang ang channel at pag binitawan na ang channel e shutdown ulit yung TV. Ano po kaya  cra nito? Sinukat ang B+ voltage ay 130V pag nag-oscillate. Gumamit ito ng P10NK80ZFP power fet at TEA1507 control IC sa power section primary side.
Offline Vaounsi
  • Pogi/Ganda Points: 146
Re: Philips 21PT1323/71R Power Shutdown Problen
« Reply #1 on: May 09, 2011, 01:58:28 PM »
bumibitaw yata 5v mo, check maiigi mga output supply kung may ripple.. try to hang eeprom pin8 kung magshutdown..
Offline pEN DoTA
« Reply #2 on: May 09, 2011, 02:12:26 PM »
epprom problem yata o try to replace tact switches
GOD LOVES YOU
Offline danyenz
  • Pogi/Ganda Points: 197
« Reply #3 on: May 09, 2011, 02:17:52 PM »
protect yan xray kasi pag nilagyan ng signal saka off? lumalakas osc pag may signal na..try mo ba pag wala signal? kahit av ganun din?
Offline taqui
  • Pogi/Ganda Points: 228
  • ang ganda ko
« Reply #4 on: May 09, 2011, 03:40:57 PM »
mataas yata 130v b+ ?
  • Pogi/Ganda Points: 916
« Reply #5 on: May 09, 2011, 03:53:07 PM »
do the basic muna
kong napalitan  na  ang dual B+ filter caps at vert. drive
check nyu nmn ang DC reverse resistance ng B+ line.
pag yan meron kahit kunti.... the unit goes to shutdown
Offline Triple_D
  • Pogi/Ganda Points: 164
« Reply #6 on: May 09, 2011, 03:55:40 PM »
makitambay nga..eeprom yata ang salarin dito,palit muna tac switch..
Offline NORTH LUZON
  • Pogi/Ganda Points: 812
« Reply #7 on: May 09, 2011, 07:14:39 PM »
check mo rgb voltages mo bro
baka ecap ang salarin dyan at check mo rin ung c-board baka may loskon
kung alam mo iconmdemn ang protection ckt nyan try mo muna at makikita mo na sa screen ang section na may problema. sigurado ba tama ang system supply mo?
« Reply #8 on: May 09, 2011, 07:54:45 PM »
Sir ginawa ko na yung mga advice nyo. Sinubukan ko sa AV shutdown pa rin. I hang 1 pin of all tack switch still shutdown. I hang pin 8 ng memory ic nag oscillate pero shutdown pa rin. Sinukat ko supply voltage ng memory ic pin 8 ay 3.3V meron ditong voltage regulator IC na 78L33. Pinalitan ko rin yung 2 filter capacitors sa b+ line ganun din ang nangyari. Sinukat ko rin yung reverse resistance ng B+ line alang palo yung meter ko kahit kaunti. Pinalitan ko rin yung memory ic 24C16W6 na galing sa JVC 24C16A nag oscillate pero shutdown din. Ang supply ng vertical IC pag nag oscillate ay 13V-Supply voltage at 60V-Flyback voltage. Mga masters ano pa kaya ang dapat kong gawin?
« Reply #9 on: May 09, 2011, 08:03:27 PM »
Sir Insider paano ba icondemn ang proteksiyon circuit nito? Ala po akong diagram saka baguhan po ako sa ganitong problema.
Offline NORTH LUZON
« Reply #10 on: May 09, 2011, 08:04:23 PM »
direct mo vert output kung may spare ka sis,alalahanin mo philips yan
o kayay try mo to then post mo ano resulta ha.hang mo muna ang yoke then try mo ipower on
« Reply #11 on: May 09, 2011, 08:17:15 PM »
hindi  ka  pa rin  tlga  ngbabago  kagz.. halos  sinusubo  mu  na  ang totoong  salarin
@TS  suyod sa C board.. meron  Protection ang Philips na kong saan ang Xray prot at unbalance of RGB can cause of power shutdown..
check mu muna...  do the basic  again..
Check the resistors on the C-board
Offline Tripler02
  • Pogi/Ganda Points: 85
  • Saka na my own pic
« Reply #12 on: May 09, 2011, 08:59:03 PM »
Pasub..La ko advice,..Binabangungot din ako ni philipo...=)
Offline danyenz
« Reply #13 on: May 10, 2011, 07:06:44 AM »
yun! kuha mo na abnoy yun boltahe ng + suply ng vert. galing fb kung 60v..ang taas nyan ano ba ibig mo sabihin 60V-FLYBAK VOLTAGE?
Offline danyenz
« Reply #14 on: May 10, 2011, 07:13:22 AM »
ito ba yung jungle tda 8844? update po baka may xray protect maka advance troubleshot tayo..
Offline Mr. Turko
  • Pogi/Ganda Points: 56
« Reply #15 on: May 10, 2011, 08:20:22 AM »
sis check mo sa c-board mga trans. resistor nyan sa RGB.. check mo din baka palyado na trimpot ng screen ng FB nyan mag cause din yan ng shut down..
« Reply #16 on: May 10, 2011, 11:45:23 AM »
Yung datasheet ng vertical ic pin6 e Vfb-flyback supply voltage at yung pin3 Vp-supply voltage at 18V ang maximum. Vfb e hanggang 68V ang maximum. Nag direct replace na ko ng Vertical IC pero shutdown pa rin.
Offline elaijah
« Reply #17 on: May 10, 2011, 11:50:08 AM »
hello mga sirs sa ganitong kaso pag e hang ba yung yoke at mag kapower so, yoke po ba ang salarin?
« Reply #18 on: May 10, 2011, 12:25:22 PM »
Magkasama ang system/jungle nito SMD cya TDA9580H/N1/3l
Re: Philips 21PT1323/71R Power Shutdown Problem
« Reply #19 on: May 10, 2011, 12:32:15 PM »
Mga master baka may service manual po kayo ng Philips na ito ang model:21PT1323/71R L01 chassis. Ito ang email ko berlinalcayde@yahoo.com
