Author Topic: USB AVR LAB - AVR programmer  (Read 3203 times)
« on: May 09, 2011, 04:07:11 PM »
Original website in German:  http://wiki.ullihome.de/index.php/USBAVR-ISP/de
Translated webpage: http://babelfish.yahoo.com/translate_url?doit=done&tt=url&intl=1&fr=bf-home&trurl=http%3A%2F%2Fwiki.ullihome.de%2Findex.php%2FUSBAVR-ISP%2Fde&lp=de_en&btnTrUrl=Translate
Its a programmer and debugger, a developmental platform, an oscilloscope, a jtag interface, a protocol analyzer and best of all its uses an atmega8L which is locally available sa electronics stores.
Its like a pickit2 for pics but with more feature or functions.
Offline glutnix_neo
Re: USB AVR LAB - AVR programmer
« Reply #1 on: May 09, 2011, 05:38:25 PM »
subscribing...
« Reply #2 on: May 09, 2011, 09:44:57 PM »
whoah.. ayos ito ah :D
« Reply #3 on: May 09, 2011, 10:24:02 PM »
na breadboard ko, device not recognized  ....  hirap intindihin ng site, di ko malaman kung anong bootloader firmware yung dapat gamitin
« Reply #4 on: May 09, 2011, 11:21:36 PM »
Patranslate mo ki sis red sonja.
« Reply #5 on: May 09, 2011, 11:32:01 PM »
ano kaya ang problem   ... usb device not recognized daw  ...  even if I load the firmware for usbasp since almost identical lang nanam ang schematic
« Reply #6 on: May 09, 2011, 11:47:14 PM »
tukso layuan mo ako...:P
wag mo muna ako tuksuhin sa AVR na yan maldita...tinatapos ko pa to...
http://www.electronicslab.ph/forum/index.php?topic=26278.new#new
;D ;D
« Reply #7 on: May 10, 2011, 12:28:34 AM »
Napagana ko rin kahit sa breadboard lang  ....
What I like about this is it can function as a programmer  .... different kinds like USBASP, AVRISPmkii and JTAGICEmkii, JTAGICEmkii cost about 4~6K kahit clone.  Also has other functions but I'm not sure but pwede din USB-UART TTL, I2C logger, etc. etc.  What I like most is pwede rin gawin oscilloscope, which the pickit2 for pic lacks.
Below screenshots of the different functionalities that can be uploaded to perform thier intended functions.
Masubukan na gawan ng PCB, I'll go for smd na ri siguro like sa website para compact and maliit.
« Reply #8 on: May 10, 2011, 12:29:25 AM »
;D ;D
ok lang yan bruha  ... the more projects, the merrier :P ;D ;D
« Reply #9 on: May 10, 2011, 12:54:38 AM »
baka makagawa ka ng DIP...;D
meron pa ako Mega8L dito...
« Reply #10 on: May 10, 2011, 06:17:55 AM »
Matagal ko na rin gusto magkaroon nito. Thanks
Offline akhen
  • Pogi/Ganda Points: 47
  • "Learning is good but application is 100x better!"
« Reply #11 on: May 10, 2011, 06:27:29 AM »
subscribing...
Offline akhen
« Reply #12 on: May 10, 2011, 06:28:42 AM »
bat di ko makita yung schematic?
« Reply #13 on: May 10, 2011, 08:23:23 AM »
Here is the schematic:  http://shop.ullihome.de/catalog/userdownloads/10403_0de_0Schaltung.pdf
Almost identical to the schematic of the usbasp but with more components
« Reply #14 on: May 10, 2011, 09:14:35 AM »
di ko ma intindihan yung schem..;D
particularly ang R10 & R12...47R ba yun? yung MESO_OUT at RESET_OUT..
« Reply #15 on: May 10, 2011, 09:36:14 AM »
Bauteil   Wert   Bauform
C1   22uF   6032
C25,C26   22pF   0805
D1   LSG T671 oder 2x1206 LED
D5   LB T676
D9   3V9   MINIMELF
IC2   ATMEGA8-16AI   TQFP32
K1,K4   Jumper   1X02
K2   USB-STECKVERBINDUNG_B   USB-B SMD
K7   WANNENSTIFTLEISTE 10-POLIG   2X05
Q1   12 Mhz   HC-49/U
R1,R14   10K   0805
R6   1K   0805
R7,R2,R25   470   0805
R3   2K2   0805
R4,R5   39   0805
R11,R9   100   0805
R8,R10,R12   47   0805
R13   22K   0805
T1   BC817   SOT23/3
  • Pogi/Ganda Points: 203
« Reply #16 on: May 10, 2011, 11:31:50 AM »
ayos ito!
@ate gigz, i convert na natin USBASP natin sa ganito :D :D :D
« Reply #17 on: May 10, 2011, 12:08:48 PM »
The original firmware (bootloader) is detected as usbasp but modified so you can load different f/w for jtagicemkii, avrispmkii, stk500, usbasp.
May problem lang ng kaunti, kaya lang di ko rin maintindihan you FAQ kasi naka german tapos kung translated namanmasyadong barok to understand.  Once loaded yung f/w ng jtagice, naloload yung orignal windows driver from avrstudio so you can't change f/w anymore via the avr usb lab tool. But avr studio has successfully detected it as avrispmkii. jtagicemkii or stk500.  Have to build the pcb para pwede na rin gamitin yung oscilloscope firmware.
Offline akhen
« Reply #18 on: May 10, 2011, 12:49:22 PM »
thanks...
pwede isa pa master alyas? yung image po nung buo na...
TIA
« Reply #19 on: May 10, 2011, 09:55:22 PM »
Ang liit lang nung image sa site nung actual product
