Author Topic: Philips 21PT3324/71 shutdown->dead set share  (Read 927 times)
Offline Tripler02
  • Pogi/Ganda Points: 84
  • Saka na my own pic
« on: May 10, 2011, 08:25:13 AM »
History=bigla na lang shutdown,next pinapainit muna bago magon until ayaw na talaga magon.
Action taken=1st day 1.Voltage checking,ok.Palit dual cap no luck pa rin.
2.Fbt naman.Walang hivo humihinga secondary,(mukhang me overload)palit vertical no luck ulet.Tsk!12am na,oily na mukha ko,ayaw pa rin,bukas na lang to.
2nd day 1.Suyod caps,ayos me shorted(2367 1uf/50v)palit,ayaw pa rin,soli ko na ata to.Bukas ulet.
3rd day 1.Service muna sa iba at ng magkalaman bulsa ko.Magugutom ako sa philips na to.
4th day 1.Heto na.Target ko tulog ako ng 9pm,pero inabot ako ng 10pm,check caps ulet ok.Pero duda ako sa 2411(47uf/50v)actual palit,voila!Ayos!Back to normal.Buti wala akong pambili ng fbt at uoc.Sumatotal tip ko lang sa philips,mukhang me isyu mga caps nila.Yun lang po..Baw..Wawaw..=)
Offline Triple_D
  • Pogi/Ganda Points: 164
Re: Philips 21PT3324/71 shutdown->dead set share
« Reply #1 on: May 10, 2011, 08:39:40 AM »
saan banda yan sis cap na pinalitan mo?
by the way buti nakapag voltage check ka na dead set hehe..
thanks for sharing sis...
Offline Tripler02
« Reply #2 on: May 10, 2011, 09:21:12 AM »
I mean,sa panlabas na kaanyuan,deadset.Wala din led indicator..Pero sa kalooblooban,ok..Ok na pu ba paliwanag?Ehe.Connected pu caps na to sa hdt.
Offline elaijah
« Reply #3 on: May 10, 2011, 11:41:48 AM »
good sharing sir.
Offline Tripler02
« Reply #4 on: May 11, 2011, 07:12:51 AM »
Up ko lang.Uso philips ngayon eh..
Offline taqui
  • Pogi/Ganda Points: 228
  • ang ganda ko
« Reply #5 on: May 11, 2011, 11:13:50 AM »
bagong kaalaman to sis.. tnx sa sharing..
Offline Tripler02
« Reply #6 on: May 11, 2011, 05:11:48 PM »
Ok.Basta makatulong masaya na tayo dun.=)
Offline danyenz
  • Pogi/Ganda Points: 196
« Reply #7 on: May 11, 2011, 05:28:09 PM »
ok bok ganda tip ...-1 pogi point ka hehhehe
Offline Tripler02
« Reply #8 on: May 11, 2011, 06:00:44 PM »
Ehe.Minus ba?
Offline danyenz
« Reply #9 on: May 11, 2011, 06:23:24 PM »
Ehe.Minus ba?
hahaha joke + pala..16+1=71
Offline Tripler02
« Reply #10 on: May 11, 2011, 10:11:38 PM »
magaling ka pala sa algebra,jumping numbers.Ehe.At dahil jan,puntos ka sis.Uhm!=)
Offline danyenz
« Reply #11 on: May 12, 2011, 06:46:33 AM »
hahahha :D :D
Offline khabod
« Reply #12 on: September 09, 2011, 01:44:35 PM »
lahat po b ng tv na may problem na auto shut off
eh ganito rin kaya ang dahilan
ecaps dn ba ang salarin?
Offline BUMBLEBEE
  • Pogi/Ganda Points: 109
  • transform!!!!!!!!!!!
« Reply #13 on: September 09, 2011, 01:54:37 PM »
pwede rin...pero hindi lahat
pero sir wag mo na buhayin pa itong thread na to gawa ka ulit ..para makapag-comment mga master ;) ayus...simulan mu na pag-gawa ng thread ;D para masimulan narin ang pag-comment ;) goodluck
Offline Triple_D
« Reply #14 on: September 09, 2011, 01:59:44 PM »
nabuhay n2man ang paktay..
Offline Tripler02
« Reply #15 on: September 10, 2011, 10:28:21 PM »
awo0o0!
Offline DJFEL
  • Pogi/Ganda Points: 44
« Reply #16 on: November 07, 2011, 05:40:27 PM »
okis ha...
dj fel on the mix
