Author Topic: kawasaki HD III 125CC wiring diagram  (Read 2583 times)
Offline dEn:)
  • Pogi/Ganda Points: 4
« on: May 16, 2011, 09:59:58 PM »
tanong qlng po mga master san mka2kuha ng service manual nito napundi lhat ng ilaw... posible kyang s battery cra nito..hnd qn kac magamit pg gabi... ga2win q po kac bukas...hingi lng po ng idea pra san q maguumpisa....salamt ng marami............ :)
  • Pogi/Ganda Points: 413
Re: kawasaki HD III 125CC wiring diagram
« Reply #1 on: May 16, 2011, 10:12:29 PM »
Anong ilaw ang napundi? Headlight? Lahat?
Ito share ko na lang. Generic
1. Baka sira na battery parang act as regulator yung battery or load na rin para di magovershoot.
2. Kung galing ng dynamo at tail light at head light ang nasira malamang battery. Or mababa rating ng headlight.
Offline x13r_kit_0
  • Pogi/Ganda Points: 151
  • --__x13r_kit_0__--
« Reply #2 on: May 16, 2011, 10:22:36 PM »
 sir ang alam ko kahit wala battery iilaw parin yan...motor ko barako sira po battery or wala gumagana po ilaw ko lahat
   =How about the other side?=
Offline x13r_kit_0
« Reply #3 on: May 16, 2011, 10:25:16 PM »
 gumamit narin po pala ako nyan..hd3.ganun nga po sis sa sinasabi ko.
may kinuhanan ako manual send kos sayo tom..
« Reply #4 on: May 16, 2011, 10:35:00 PM »
Sana sakin rin meron makarating na service manual.
Offline x13r_kit_0
« Reply #5 on: May 16, 2011, 10:39:16 PM »
 ah ok sis js kaw pa.,post ko dito bukas pag nahanap ko uli..
nkacp lng ksi ngayun eh.limited service,hehehe
Offline dEn:)
« Reply #6 on: May 17, 2011, 06:28:42 AM »
hulang lng po mga master pki korek nlng po.....:)
alam ko po kac pag wlang battery tumataas ang supply ng dc galing s denamo kac wlang humihigop gaya ng 12v battery nong nagtest ako non sa generator nmin pinaAndar ko ung mkina pagwalng batery overload mataAs ang supply umaAbot ng 24v pataAs pero pag my battery fix lng xa 12v pareho lng po kya ng operation sila...salamt po ng marami........
salamat sir yern eto po pala email q den_stc@yahoo.com
« Reply #7 on: May 17, 2011, 07:43:12 AM »
^Opo ganyan nga po parang absorber din yan. Yung sa yamaha na luma kaya madaling masira ang battery dahil absorber na din sya ng sobrang boltahe.
Kaya kapag walang baterya overshoot ang boltahe at kapag medyo mababa rating ng headlight o tail light sunog kaagad.
Except iba ang design ng motor mo naman.
Offline malamig
  • Pogi/Ganda Points: 61
« Reply #8 on: May 17, 2011, 07:59:07 AM »
^ agree ako dito.
nasubukan ko na rin mag start dati ng walang battery, napundi ang neutral light.
buti hindi naka ON ang ibang ilaw :)
Offline x13r_kit_0
« Reply #9 on: May 17, 2011, 08:55:02 AM »
agree din ako..yung nga lang sakin..,umiilaw  pero di kagaya talaga ng may good baterry..
checkmo na rin sis charging voltage..para sigurado nagchacharge pag nagpalit ka baterry..
karagdagang suggestion pls...
Offline dEn:)
« Reply #10 on: May 17, 2011, 10:49:12 AM »
sir pwd bang plitan q nlng 12v battery q pwd b un sir plitan ko din lhat ng bulb>? tsaka ung 4 ang paa regulator po cguro to ung papuntang head light d2 nkatop ok n lhat pati ung cgnal light pero ung head light wla parin cra po kya regulator nito pero nagcha2rge xa.
Offline dEn:)
« Reply #11 on: May 17, 2011, 10:53:14 AM »
my nkatop din s head light ppunta s ilalim...pwd po b tangaling qnlng nkatop s regulator tpos kbit q s main positive...>?
« Reply #12 on: May 17, 2011, 11:23:58 AM »
Kung ang headlight mo sis ay dapat sa dynamo ang source dapat wag mong ilagay sa main positive o battery terminal kasi mahina ang ilaw ng headlight mo at baka madaling madrain at masira battery mo.
Madilim ang headlight mo nyan baka madisgrasya ka.
It either yung papunta ng ilalim galing ng headlight eh papuntang taillight or headlight switch kaya wag na muna tanggalin kaagad.
Ganito na lang sis. Kung meron ka new installed battery. Tanggalin mo yung headlight bulb gawan mo na lang ng paraan na masukatan mo ng boltahe yung b+ niya sa socket(loob) yan tapos isang probe sa body ground ng motor(DC settings ng multitester). Tapos paaandarin mo makina then on headlight switch. Dapat me masukat ka maski 12 to 16Volts DC yata. Kapag me battery mga 14 volts lang yata.
Ibig sabihin good ang linya ng headlight mo at meron source sa dynamo. Kapag wala check your wiring or ground connection ng multitester mo o kaya kuha ka ng connection sa negative terminal ng battery.
« Reply #13 on: May 17, 2011, 11:26:03 AM »
Kapag walang battery madaling matest kung me galing sa dynamo kasi at idle speed wala ka masukat na boltahe then upon revying tataas yan ng lagpas 12V dc.
Offline dEn:)
« Reply #14 on: May 17, 2011, 01:04:47 PM »
wla po tlaga masukat khit e top q bago dumating s ignition switch dlawa po ung source nya ung isa galing don s my charging regulator n my 4 pins
ung isa nman papuntang mkina, ang ginawa q po cut q po ung s my regulator cut din ung s ilalim top qs battery no choice n po kailangan mapailaw.....:) s plagay nu po magtatagal kya
Offline dEn:)
« Reply #15 on: May 17, 2011, 02:11:05 PM »
sir j.s 6v lng po ung nilagay qs headlight pra medyo maliwanag tpos lhat 12v n.. tapos pinaAndar qn ok nmn....
Offline x13r_kit_0
« Reply #16 on: May 17, 2011, 08:43:52 PM »
 gumana na ba sis,cnsya na ha,di ko makita yung site matagal na kasi baka dna aktib
send ko nalang pag nakita ko..
Offline x13r_kit_0
« Reply #17 on: May 17, 2011, 08:46:02 PM »
 suggest lang...
pag magconnect direct sa battery lagi lagyan ng relay para di mabilis magdrop o madrain battery..
« Reply #18 on: May 17, 2011, 08:50:37 PM »
Yan ay sis kapag naiwan nakaon yung switch ng headlight di madrain yung battery.  ;D
Naglalayas na yata si sis.
Offline x13r_kit_0
« Reply #19 on: May 17, 2011, 09:01:25 PM »
 oo nga,baka ok na.hehe
wag mabilis magpatakbo sis denz bka bigla mapundi..grin,grin
