Author Topic: kawasaki HD III 125CC wiring diagram  (Read 2563 times)
Re: kawasaki HD III 125CC wiring diagram
« Reply #20 on: May 17, 2011, 09:11:20 PM »
Di kasi naibigay kung ilan ang voltahe ng battery at mga voltage rating nung ilaw.
Ang siste nyan baka iisa ang daanan ng charger sa battery at headlight tapos yun yung nacut. Baka tumatakbo yung motor mawala naman ilaw dahil drain na yung battery.
Offline x13r_kit_0
  • Pogi/Ganda Points: 149
  • --__x13r_kit_0__--
« Reply #21 on: May 17, 2011, 09:20:37 PM »
 hehehe..
nagmamadali baka mangchix..peace
oo nga 6v lng yan hd3,kinabitan ng ilaw 12,di ba mahina ilaw sis.,
"Kumain tayo at uminom,Sapagkat bukay ay mamamatay tayo"  CORINTO 15:32
   =How about the other side?=
« Reply #22 on: May 17, 2011, 09:24:13 PM »
Di naman sis mahina ilaw dim lang siguro.
Offline dEn:)
« Reply #23 on: May 17, 2011, 09:25:02 PM »
tsugi mga master :) pundi ung low ok ung high 12v po ung battery pinalit q bgo ko ikabit tester q muna ung positive ground pra s battery tpos pinaAndar q ok nman my reading umaAbot ng 16v kya ok charging nya head light nya 6v lng kinabit q pra hind mlabo...eto sir problema head light bka mpundi ndin ung high ano po kya magndang gawin d2....
« Reply #24 on: May 17, 2011, 09:30:06 PM »
Naku paniguradong tsugi ka nyan sis 6V sa headlight pero 12-16V sa headlight at charging di yan tatagal  sunog rin yan. Yan ay kung hindi battery operated. Maski sis sa 12V battery supply tapos 6 volts ang bulb mo sunog rin yan kaagad.
Ilan ba rating ng orig? 12V 35W? or 12V 25W?
Offline x13r_kit_0
« Reply #25 on: May 17, 2011, 09:35:57 PM »
 reg sis di mo na napalitan..sumasabay sa bigay ng gas yung ilaw mo..?
baka mapundi sis,.
Offline dEn:)
« Reply #26 on: May 17, 2011, 09:39:38 PM »
sir j.s 6v po tlga battery nito ginawa qlng 12v un kac available eh...ginawa qlng 6v ung headlight bka kac mhina ung ilaw pg 12v nilagay q...
Offline dEn:)
« Reply #27 on: May 17, 2011, 09:43:50 PM »
baka mapundi sis,.
wla kac pmalit eh kya ginawan qlng praAn pra magkasuply lng ung headlight.... hnd po b pag my batery wla nang over charge kac magfix xa dapt s 12v lng...
Offline nucleus
« Reply #28 on: May 17, 2011, 09:47:05 PM »
sira ang regulator mo master kaya napupundi yung ilaw, palit ka lang ng regulator at ibalik sa dati ang orig na linya :)
sakit sa ulo pag may dumadating na tampered ang wiring >:(
Offline dEn:)
« Reply #29 on: May 17, 2011, 09:49:15 PM »
s tester kac 12v lang reading kahit buhay ang makina iwan qlng pag tumaTakbo n...d kya mhinang klase ung nbili qng bulb kac malayo n natakbo q ok prin ung high....
Offline nucleus
« Reply #30 on: May 17, 2011, 09:51:20 PM »
naka menor pa lang yan master, rev mo at tiyak tataas yan
Offline dEn:)
« Reply #31 on: May 17, 2011, 09:55:01 PM »
sira ang regulator mo master kaya napupundi yung ilaw, palit ka lang ng regulator at ibalik sa dati ang orig na linya Smiley
wla nga po sir suply s regulator nya ppuntang headlight 4 pins po un d po b ung right side pra s charging ok nmn gumgana xa tpos ung left para s headlight tama po b....
« Reply #32 on: May 17, 2011, 09:56:06 PM »
Lalo na kung medyo napamali siya ng pasok ng gear from high shift to low tapos napabomba.
Offline dEn:)
« Reply #33 on: May 17, 2011, 09:57:17 PM »
sana mga master my idea po kau hbang wla pang pmalit n reg.
Offline nucleus
« Reply #34 on: May 17, 2011, 10:02:31 PM »
shunt regulator po ang gamit ng HD3, kapag tinanggal connection sa regulator ay iilaw parin hindi lang magiging regulated ang output kaya putok ang mga bumbilya mo, tulad din ng sa honda wave/xrm/dream yamaha mio/sniper hindi lang pin compatible ang regulator nito pero pwede gawan ng adaptor na linya para maikonekta at gagana din
« Reply #35 on: May 17, 2011, 10:05:05 PM »
Matanong ko sis para ba itong relay type?
Offline nucleus
« Reply #36 on: May 17, 2011, 10:13:20 PM »
electronic sir, maliit lang ito
Offline x13r_kit_0
« Reply #37 on: May 17, 2011, 10:16:17 PM »
 thanks nadagdagan nagsusugest.,matoto ako dito..
thanks..!
« Reply #38 on: May 17, 2011, 10:17:51 PM »
Pamilyar lang kasi ako sa lumang sistema ng auto. Shunt to ground ang regulator.
Offline nucleus
« Reply #39 on: May 17, 2011, 10:31:36 PM »
parehas lang ito ng bago sir, semiconductor devices lang ang ginamit, maihahalintulad sa isang highpower zener diode :)
itong circuit na ito sa net:
pwede rin iyan isang SCR lang ang kelangan mo na ikokonekta sa dulo ng winding na mas mataas ang output
