Author Topic: amplifier design + 800 watts mosfet amplifier hope it will help you.  (Read 5560 times)
Offline sp0c0
  • Pogi/Ganda Points: 38
Re: amplifier design + 800 watts mosfet amplifier hope it will help you.
« Reply #60 on: March 22, 2012, 08:08:19 PM »
sa power supply palang nito mga 6k+ na ang gagastusin mo.
Learning by doing..
Offline ricdelros
  • Pogi/Ganda Points: 73
« Reply #61 on: March 27, 2012, 01:53:57 PM »
Mamumulubi ka dito ,bawi ka na lang sa hataw ng 1000watts..maraming IRF transistor dyan sa Evangelista.
Offline BhongTech
  • Pogi/Ganda Points: 152
« Reply #62 on: April 01, 2012, 11:07:57 AM »
mahal nga talaga ito sir,mataas na wattage ang kailangan eh. :D
maganda siguro makinig dito kahit mahina lang patugtug para ng binabayo ang dibdib mo. ;D
Offline ricdelros
« Reply #63 on: April 23, 2012, 03:43:16 PM »
Actually i't is only 550w @ 8 Ohms, 1000w sa 4 Ohms ito.
Offline Tukkar
  • Pogi/Ganda Points: 27
« Reply #64 on: April 24, 2012, 09:18:10 AM »
800w is too much para ma feel lang ito....why not try class A, kung gusto mo talaga ng matigas ang kalabog a 100w with 12 inches woofer will do.  nasa speaker at amp combination din yan...
Offline BhongTech
« Reply #65 on: April 24, 2012, 09:33:07 AM »
saka na ako mag try nitong class A sir.
pero para sa akin iba pa rin ang mataas ang wattage tapos de dyes o de dose na speaker tapos nasa 200watts pataas.
sa ngayun happy naman ako sa pag diy ng mga amp na class AB na nasa 100w to 200w/8ohms.
Offline Tukkar
« Reply #66 on: April 24, 2012, 01:36:07 PM »
ganun din ang impression ko nun kasi yung 150w triple darlington ko na BJT amp eh maganda yung tunog pag low volume lalo nat naka bias ng 50ma per pair or 150ma sa 3 pairs per channel. pero ng masubukan ko low wattage(15w) class A...halos pareho lang kung sa parehong volume ang usapan...
Offline yehan
« Reply #67 on: June 07, 2012, 04:43:39 AM »
K1058 j162' nasa 280 pesos po isa nyan
