Author Topic: help from 7seg to decade counter?  (Read 1067 times)
Offline Alexis1989
« on: May 18, 2011, 04:56:39 PM »
pano ko po ba maseset ung 7seg ko papuntang decade counter,
gusto ko kasi malaman kung pano mo magagawa ung running lights tapos blinking lights para sa specific out ng 7 segment ko
kunwari pag output ng 7 seg 5 mag ruruning lights tapos 6 blinking lights.
any suggestion?
Offline dummy_c
  • Pogi/Ganda Points: 162
  • If I die 2nyt, 8's bcoz maimai is not at my side!
Re: help from 7seg to decade counter?
« Reply #1 on: May 18, 2011, 06:38:58 PM »
Di ba sir before sa seven segment may binary to 7-segment driver?. Yung sa binary out doon ka mag connect.
Pwede rin maglagay ka ng logic gates sa 7-segement out pero daming gates kailangan lalo na kailagan i-decode ulit yung # 0-9.
Wait tayo sa mga masters i believe may mas mmadali silang paraan.  ;D
The world's technology is always changing, no doubt about it, and I hope it’s a while yet before it impacts my ability to tinker.
« Reply #2 on: May 18, 2011, 06:55:06 PM »
any suggestion?
Gamit ka na lang ng pic :D then if gusto mo sa 7-segment display niya gamit ka decoder :D
Offline Alexis1989
« Reply #3 on: May 18, 2011, 09:08:30 PM »
actually naisip ko na din yan e
ganito kasi ung balak ko
0000\
0001 } running lights
0010/
0011\
0100 }blinking lights
0101/
and so on
gusto ko malaman kung pano ko maiinput ito sa decade counter tapos un ung output
Offline dummy_c
« Reply #4 on: May 18, 2011, 09:14:53 PM »
0000\
0010/
0011\
0101/
and so on
Mukhang possible yan sir using cd4017.
Offline Alexis1989
« Reply #5 on: May 19, 2011, 03:58:35 PM »
pano ba ko makakapag palabas ng output sa decade counter ng sabay sabay para sa blinking
parang
Q0 = 1
Q1 = 1
Q2 = 1
Q3 = 1
Q4 = 1
Q9 = 1
pede ba un?
halos lahat ng nababasa ko tungkol sa decade counter puro sequence
Offline dummy_c
« Reply #6 on: May 19, 2011, 06:18:30 PM »
parang
Q0 = 1
Q1 = 1
Q2 = 1
Q3 = 1
Q4 = 1
Q9 = 1
pede ba un?
Hindi ko ma gets ang ibig mong sabihinsin...
Offline Alexis1989
« Reply #7 on: May 19, 2011, 07:24:18 PM »
nag search kasi ako tungkol sa ic ng 4017
meron syang 10 output
kala ko pede mag output sa ic na yan ng logic high at low ng sabay sabay (para sa blinking lights).
sabi kasi
"decade counter has ten outputs which go HIGH in sequence when a source of pulses is connected to the CLOCK input", pede lang sa ic na yan running lights
d ko din magagawa ung blinking.
ano pa ba mga pede kong gamiting ic?
