Author Topic: epson stylus tx121 blinking problem  (Read 3026 times)
Offline mike11
« on: May 18, 2011, 06:56:44 PM »
mga master new lng po s elab help nmn po 2x printing after non ayawn mgprint blinking na lhat ng led good nmn ink genuine po inks thnks
Offline allan_tech
Re: epson stylus tx121 blinking problem
« Reply #1 on: May 18, 2011, 07:00:40 PM »
subscribing wait tau sa mga master n nandyn
Offline AC-DC
  • Pogi/Ganda Points: 162
« Reply #2 on: May 18, 2011, 07:06:06 PM »
kulang sa info!
ano na po nagawa nu?
Offline mike11
« Reply #3 on: May 18, 2011, 07:10:03 PM »
nakakapag print naman 2 times nga lang pagkatapos nun wala na blingking na lahat ng led brandnew naman ang ink
  • Pogi/Ganda Points: 58
« Reply #4 on: May 18, 2011, 07:20:47 PM »
Baka chip na ang sira :D ;D ;D wish mo na mali ako... Teka san un manual u nyan :D
Di naman kaya paper jam lang :D ;D
  • Pogi/Ganda Points: 1093
« Reply #5 on: May 18, 2011, 07:25:59 PM »
matagal  na ba  sayo ang printer ?
kong  hndi  pa,  try  mu  press ang stop
at tignan mu ang cartridge sa loob. papuntahin mu sa  gitna  at  press mu  yung switch nya  doon... nang mareset.
be sure  din nga  pala  na i-cancel lahat ng pending print jobs
DVD Dump - http://www.elab.ph/forum/index.php?topic=22986.1660;topicseen
Offline oemor1968
« Reply #6 on: May 18, 2011, 07:52:11 PM »
kapatid na ts itong sa akin cannon pag nagkaganyan nerefreshh  ko lang.....try press the botton and hold then unplug the cord...then plug uli baka makatulong.
Offline akhen
  • Pogi/Ganda Points: 47
« Reply #7 on: May 18, 2011, 08:01:49 PM »
im using the same brand of printer po. anything i can help?
pasagot po muna ng mga tanong sa taas para maadress natin correctly.
questions like:
1. brand new ba yan?
2. may waranty pa ba?
3. ano ginagawa mo nung lumabas yung error na yun?
4. ano na ginawa mong actions trying to fix the problem?
Offline >>>???<<<
  • Pogi/Ganda Points: 547
« Reply #8 on: May 18, 2011, 09:45:45 PM »
Kung bago warranty.
Baka reset na naman ng ink pad ito?
http://www.elab.ph/forum/index.php?topic=41860.0 My DIY transformer... ? ? ? Test Build Uli
http://www.elab.ph/forum/index.php?topic=33717  I2c / spi programmer
http://www.elab.ph/forum/index.php?topic=37150.0 Lcr esr makikigulo rin ba kayo ??? Test Build
http://www.elab.ph/forum/index.php?topic=29963.0 Esr collection na malamig
http://www.elab.ph/forum/index.php?topic=25854.0 Basic C++ Programming Tutorials by Prof Asimo
3T LTB DIY P50 tunogsarilingsikap
Offline x13r_kit_0
  • Pogi/Ganda Points: 168
  • --__x13r_kit_0__--
« Reply #9 on: May 18, 2011, 10:53:55 PM »
 gusto ko matoto nyan....
"Never argue with an idiot, they drag you down to their level and then beat you with experience"
  -nevermind
Offline >>>???<<<
« Reply #10 on: May 18, 2011, 11:00:45 PM »
Paper jam. Baka naman iba ang printer sa print menu na napupuntahan.  ;D
Offline x13r_kit_0
« Reply #11 on: May 18, 2011, 11:06:56 PM »
 pag home use,di na siguro marami nakainstall na driver ng printer.,pag office pwede pa.,hehe.pagaralan ko nga bukas yan
  -nevermind
Offline >>>???<<<
« Reply #12 on: May 18, 2011, 11:14:19 PM »
Marumi contact ng cartridge.
Offline akhen
« Reply #13 on: May 19, 2011, 07:30:04 AM »
Kung bago warranty.
kung reset lang ng ink pad may solution tayo jan...
Offline x13r_kit_0
« Reply #14 on: May 19, 2011, 10:04:20 AM »
tutorial ka na sis..nang matoto na.. :)
  -nevermind
Offline akhen
« Reply #15 on: May 19, 2011, 12:04:29 PM »
not sure kung pwede magtutorial nyan baka mayari tayo ng epson. ;D
bigay ko na lang yung pang reset na softaware madali lang naman paglaruan.
Offline >>>???<<<
« Reply #16 on: May 19, 2011, 12:48:32 PM »
Magagalit ang seiko.
Offline comtronixs
  • Pogi/Ganda Points: 53
« Reply #17 on: May 28, 2011, 09:07:42 PM »
pwede bakit naman hindi download kayo ng resetter..  program kung wala meron ako.... hehehhe pm me lang
Offline centOS
  • Pogi/Ganda Points: 46
  • screw the screw
« Reply #18 on: May 30, 2011, 06:27:05 PM »
pwede nya rin gawin sa builtin software ng printer meron naman maintenance yan subokan mo lang...
http://www.elab.ph/forum/index.php?topic=42197.msg673054;boardseen#new
http://www.elab.ph/forum/index.php?topic=34991.0
http://www.elab.ph/forum/index.php?topic=36002.0
Offline de PatAtas
  • Pogi/Ganda Points: 332
  • ' The unbreakable
« Reply #19 on: May 31, 2011, 11:00:55 AM »
' wala ang TS.. ;D
