Author Topic: Thermoelectric Cooler TEC-12706  (Read 3585 times)
Offline kheich
  • silently waiting
« on: May 21, 2011, 11:02:33 PM »
350 pesos only!
Features:
Solid state, vibration free, noise-free.
Simple to install and operate.
Should use with a heat sink.
Product Name : Thermoelectric Cooler
Dimensions : 40 X40 X 3.4 mm
Color : White
Couples : 127
Vmax : 15.2 V
Imax : 6 A
Max power consumption : 92 W
Tmax : 67 degree celcius
Resistance : 1.3-1.5
Item Net Weight: 250g / 17.5oz
LIMITED STOCKS ONLY
NO NEED TO WAIT FOR 15-20 DAYS
GET IT NOW ♥
Contact me : 0915-785-1662
Yahoo: caduds_12@yahoo.com
Facebook: kichsbox@gmail.com
~*~>so long my almost lover<~*~
Offline Tripler02
  • Pogi/Ganda Points: 84
  • Saka na my own pic
Re: Thermoelectric Cooler TEC-12706
« Reply #1 on: May 21, 2011, 11:54:52 PM »
Picture naman.
If you have a reason to live,then you have no reason to quit....
  • Pogi/Ganda Points: 909
« Reply #2 on: May 22, 2011, 12:24:04 AM »
sis  saan ang location  mu...
sana  mindanao  lang   :-[
Offline kheich
  • silently waiting
« Reply #3 on: May 22, 2011, 08:21:35 AM »
Offline kheich
  • silently waiting
« Reply #4 on: May 22, 2011, 08:45:08 AM »
sa mandaluyong po ako :) aavail kba sis?
« Reply #5 on: May 23, 2011, 04:07:32 PM »
sana  kahit  isa  lang  needed  ko... for diy water dispensing
Offline kheich
  • silently waiting
« Reply #6 on: May 24, 2011, 09:36:16 AM »
ygpm
Offline kheich
  • silently waiting
« Reply #7 on: June 17, 2011, 12:56:28 PM »
up up :)
Offline drin20
  • Pogi/Ganda Points: 17
« Reply #8 on: June 17, 2011, 05:38:01 PM »
Lakas sa kuryente nito.
« Reply #9 on: June 17, 2011, 08:22:28 PM »
depende sa pag gagamitan... mas tipid na yan sa kuriente.
next solution is gumamit ka nang COMPRESSOR. gusto mo gumamit nang COMPRESSOR? mas tipid yun!
Offline kheich
  • silently waiting
« Reply #10 on: June 21, 2011, 09:23:36 AM »
natawa aku dun ah :) para lang naman po sa mga interested :) hehehe mga gus2ng magkaroon ng self project. bili na po kau :)
Offline kheich
  • silently waiting
« Reply #11 on: June 21, 2011, 09:39:41 AM »
here are the pictures you guys :)
Offline kheich
  • silently waiting
« Reply #12 on: June 26, 2011, 07:41:00 PM »
up up up :)
Offline e-tronix
« Reply #13 on: June 26, 2011, 07:51:00 PM »
question? anu mgandang application para dito?
« Reply #14 on: June 27, 2011, 01:20:36 AM »
madaming chemist ang gumagamit nito for cooling small amounts of chemicals. (altho di ko alam saan nila particularly ginagamit)
cooling semiconductors at below zero temperatures without using liquid nitrogen or fancy compressors
may fog machines na gumagamit nito para makagawa nang ground effect.
precision clock ovens, may xtal na needed na super precise eto ginagamit. since baligtarin mo lang yung polarity eh iinit na yung cooling side.
Thermal camera din. ewan ko din kung bakit meron nito sa loob nang sensor...
Offline kheich
  • silently waiting
« Reply #15 on: June 27, 2011, 09:17:28 AM »
in addition, Peltier devices are commonly used in camping and portable coolers and for cooling electronic components and small instruments. Some electronic equipment intended for military use in the field is thermoelectrically cooled. The cooling effect of Peltier heat pumps can also be used to extract water from the air in dehumidifiers.
so as a summary
(1) ginagamit din po xia sa mga cooler para maintain yung lamig ng mga softdrinks and foods.
(2) ginagamit for cooling ng CPU system lalo na kung sobrang umiinit, at mga nagooverclock ng PC nila
(3) dehumidifier / humidifier
(4) really anything na gus2 mo magpalamig :)
(5) pde din gamitin yung hotside :)
Offline e-tronix
« Reply #16 on: June 28, 2011, 11:28:50 PM »
so pwedi siya heater or cooler? pwedi more than 1 gamitin ng sabay nito para ma double ang cooling or hotting effect niya?
« Reply #17 on: June 29, 2011, 01:43:35 AM »
i think wala naman issue mag parallel nito.
pwede naman heating pero
it's better na heating element na lang kung heating.
Offline cristeta
« Reply #18 on: June 29, 2011, 08:18:22 AM »
mas mura kaya ito? CDR King (USB Cooler/Warmer 200pesos lang) may casing na at USB pa.
Offline kheich
  • silently waiting
« Reply #19 on: June 29, 2011, 09:48:07 AM »
sa pagkakaalam ko po same lang din nman ang laman nyan :) peltier din yung nasa loob :) its one of the example usage/application ng peltier as stated above :)
