Author Topic: Wireless Router ni CD-R king...  (Read 1559 times)
Offline marviella
« on: June 02, 2011, 09:38:50 AM »
Hellow mga papsi...
Patolong..
1st time ko naencounter to sa wireless router ni cdr king.. bali, nagagamit na mn sia ng mga laptap.. tapos, my PC aku at binilhan ko ng USB wireless dangle ni CD-king din... AHHmmm, pagconnect ko ay lumalabas na "Limeted or No Connectivty".. Eh, naka set naman sa auto obtain na IP address.. Anu kaya problema??? Patulong...
Good Day!
  • Pogi/Ganda Points: 433
Re: Wireless Router ni CD-R king...
« Reply #1 on: June 02, 2011, 09:50:21 AM »
Anong klase naman ng router model number para matulungan ka ng mga master dito.
Offline marviella
« Reply #2 on: June 02, 2011, 09:52:46 AM »
Eto po model nya.. LP8186... My kasama yan na 4 port LAN...
« Reply #3 on: June 02, 2011, 10:04:20 AM »
Hmm wag lang mapatapat dun sa model na hindi compatible. Natanong mo ba dun sa technician ng cdrking about compatability before buying so?
Share mo yung settings mo at OS na gamit para mas mapadali sa ating mga master.
Offline _basura_man()
  • Pogi/Ganda Points: 36
    • Learn robotics here.
« Reply #4 on: June 02, 2011, 10:08:56 AM »
i-ping mo muna yung ip address ng PC mo pag coconect,pag hindi palitan mo yung IP address baka di sya nakasama dun,create ka muna ng local network using windows.meron wizard yan at instructions kung windowsxp or 7.
halimbawa yung router mo 192.168.2.50 yung simula pwede ka magdagdag ng 51,52 and so on and so forth.mas ok yung manual set kaysa obtain para sa akin.
-John
Offline marviella
« Reply #5 on: June 02, 2011, 10:11:06 AM »
di ko na natanung sa tech nila ang compatability ng wireless dangle nila..
Im using windows xp service pack 2..
settings ng pc ay nka auto obtian na IP adrress, net mask, at gateway..
pati DNS nka auto na din..
Sequence ng IP is 192.168.0.X
Sinubukan kung emanual ang IP sa PC ng 192.162.0.5 net mask na 255.255.255
At gateway na 192.168.0.1
Ang lumabas sa is "connetected" na.. Xempre kasi match na IP add ng router at PC,
yung problema, AYaw pa rin mka pgbrowse...
« Reply #6 on: June 02, 2011, 10:14:15 AM »
Kung vista to 7 ang OS mo punta ka sa network management then punta ka sa IPV4 lagay ka ng static IP add tulad ng nasabi ni sis sa taas.
O kaya punta ka sa router page check mo kung anong nakakabit sa router mo dapat makita mo mac or ip add ng dongle mo. Be sure na activated ang dongle mo.
« Reply #7 on: June 02, 2011, 10:17:11 AM »
Teka ano ba ang router mo sis?
« Reply #8 on: June 02, 2011, 10:18:09 AM »
Any firewall or security settings sa router mo?
« Reply #9 on: June 02, 2011, 10:32:12 AM »
ok i MAC clone mo muna yung service provider mo para makita ng PC mo yung service provider hinde yung ip ng router.
-John
Offline marviella
« Reply #10 on: June 02, 2011, 10:43:51 AM »
CD-R king PO na Router..
Firewall ng PC ko s nka turn on..
ang sa router palagay ko default kasi nireset ko ei..
-Emac CLone nga siguru muna.. di ko naisip yan ei.
Pero ngdeside na aku na tatanggalin na lng ang dangle at mgLAN na lang..
My gagalawin pa po ba aku sa router>???
Offline marviella
« Reply #11 on: June 02, 2011, 10:47:57 AM »
tapos eto pa po...kasi nereset ko ang router.. Dati my WEP, natanggal na nga dba..
Then niconect ko ulit ang laptap na dati ng nkaconnect nung my WEP pa..
Tapos di na rin mka pgbrowse... Akala ko sa ISP, so dnirect ko ang ISP sa laptap, OKEY naman...
Then ngconnect ulit aku sa router, ayun na, nkapagbrowse na ulit..
Anu ng yari dun??
Offline marviella
« Reply #12 on: June 02, 2011, 11:16:19 AM »
arrrrr....... panu po ba to eclone?? MAC po ba ng ISP o MAC ng PC ko???
« Reply #13 on: June 02, 2011, 12:32:15 PM »
Hehehe nagugulo rin ako dyan sa lagay mo.
So
1. CDRking router gamit mo?
2. CDRking wifi dongle gamit mo?
3. Nakaxp ka?
1. Una di makaconnect kasi meron wep key at baka iba rin ang settings. Sunod nakalock sa firewall.
2. Nireset mo, di nakaconek kasi yung settings mo eh meron pang wep encryption key. Nilagay mo sa automatic detects settings kaya ka nakaconek uli.
3. Mac cloning cloning ng Mac ng modem mo sa router mac para yung registered MAC sa ISP ay syang madetect ng ISP para mapadalhan ka ng net connection. Sa digitel maski hindi na imac clone ok na yan, Just set the setting for the IP address, DNS. At go na yan isama mo na settings ng LAN cable o wireless man yan.
Kapag hirap magkonek sa auto obtain try mo set manually yung mga IP minsan ganyan talga yan.  Kapag di pa rin hardware na problema mo. Patest mo uli sa cdrking yan. Isa pa magreboot ka for the changes to take effect baka yan lang ang kulang.
Offline marviella
« Reply #14 on: June 02, 2011, 12:40:51 PM »
whahaha! Salamat Sis!
Ay, you mentioned MAC cloning... San ba na PC ang ecoclone ko ang MAC, yung  sa laptap na ngcoconect na? or yung  sa bago na di pa nka internet? OR either of that 2???
Offline marviella
« Reply #15 on: June 02, 2011, 12:45:32 PM »
yung laptap kasi, ayus na.. my internet na, kasi dati ng ginagamit to dito ei,
pero nung sa bago kung PC wala.. nang ngconnect aku wifi.. connected pero walang internet..
Mamayang gabi susubukan kung mgLAN na lng..
« Reply #16 on: June 02, 2011, 12:54:07 PM »
Ang MAC cloning ay pagkupya ng MAC address ng DSL modem para sya rin ang makikita ni ISP sa router mo.
MAC address ng modem mo ay katulad sa MAC address ng router mo. Para iisa yung nakikitang registered mac sa ISP. Ganun lang  po yun.
Offline Vaounsi
  • Pogi/Ganda Points: 146
« Reply #17 on: June 02, 2011, 01:09:46 PM »
galing mga master! ;D
ano po isp nila, baka matulungan kita sa problem mo
kung globe broadband isp sa ganyang model ng router mo no nid mag clonemac kung wimax, dsl and smart nid ang mac add..
« Reply #18 on: June 02, 2011, 01:12:22 PM »
O ito na ang talagang master. Dami pati isp connection.
Offline Vaounsi
« Reply #19 on: June 02, 2011, 01:15:04 PM »
kung globe wimax set ur default ip to 172.168.10.254, then u nid to copy mac add.. and put it sa clone mac.. then check all boxes below on clone mac sa router gui..
dsl,smart bro, set default ip to 192.168.10.254, then copyy also mac add..
pag globe broadband lng set default 192.168.10.254 wala na iba pa..
how to get mac add.. punta ka commnd prompt.. type 'ipconfig/all' enter, then copy pysicall adress w/o dashes..
