Author Topic: Toshiba 25 surplus t.v standby mode only  (Read 2762 times)
Offline bongking
« on: June 04, 2011, 12:49:58 PM »
mga master patulong sa newbie, pag on ng t.v may tik sound then mag light ang standby led (ginamitaN ko na rin ng remote same po ang nangyare nag tik sound only). Meron normal voltage sa filter capacitor but no B+. Meron input sa StrS5041 same voltage ng filter cap, ask ko lang if this is the culprit kase wala me makuha na any output voltage? Maraming salamat po If meron po kayo flowchart what to check next na ma share sa akin. ??? ??? ???
Offline taqui
  • Pogi/Ganda Points: 228
  • ang ganda ko
Re: Toshiba 25 surplus t.v standby mode only
« Reply #1 on: June 04, 2011, 12:52:00 PM »
check muna hot. or hang muna baka magka b+ na
mag painit ka muna .. kapag nilalamig..
  • Pogi/Ganda Points: 776
« Reply #2 on: June 04, 2011, 01:03:12 PM »
normal lang na may tik sound yan dahil may sariling standby transformer
agree check hot ba shorted
  • Pogi/Ganda Points: 834
« Reply #3 on: June 04, 2011, 01:06:48 PM »
wala man lang bang masukat na 2ndary voltages?
check baka may overload
Offline bongking
« Reply #4 on: June 04, 2011, 01:11:27 PM »
cge, sirs check ko hot ng secondary voltages? Update ko kayo what happens. tnx
Offline bongking
« Reply #5 on: June 04, 2011, 02:19:52 PM »
Mga master update po Toshiba 25 standby mode only
remove HOT  nagkaroon ng 115 volt ang B+
voltage sa chopper transformer secondary 50 volts
still tv at standby mode
check ko po ang hot transsitor shorted po ata sya kase ang palo ng analog tester sa base-emitter and emitter-base ay zero.
Ask ko lang po mga master ang diagnosis nyo. maraming salamat
Offline Vaounsi
  • Pogi/Ganda Points: 146
« Reply #6 on: June 04, 2011, 02:26:38 PM »
palitan nayn ng matapos na..
Offline bongking
« Reply #7 on: June 04, 2011, 02:31:49 PM »
mga sir magkano kaya D1428 HOT?
Offline sniper72
  • Pogi/Ganda Points: 13
« Reply #8 on: June 04, 2011, 02:39:03 PM »
90 petot yan dito sa amin..
Offline danyenz
  • Pogi/Ganda Points: 209
« Reply #9 on: June 04, 2011, 02:48:14 PM »
hay salawahan na tread..may post po alo sa kabilang tread mo ts 2 pala ito... lito ako...hehehe
PAPUNTA KA PA LANG.......PAUWI NA AKO.....
Offline bongking
« Reply #10 on: June 04, 2011, 03:06:48 PM »
@dantenz, sensya na sir pina dedelete ko na nga sa mod. yung isa d ko kase makita kanina to.
Mga sir update ko nalang po kayo if naka buy na me ng HOT.
Offline x13r_kit_0
  • --__x13r_kit_0__--
« Reply #11 on: June 04, 2011, 03:12:46 PM »
 kapehan na yan...
"Kumain tayo at uminom,Sapagkat bukay ay mamamatay tayo"  CORINTO 15:32
   =How about the other side?=
Offline danyenz
« Reply #12 on: June 04, 2011, 03:16:17 PM »
ok kongrats na yan bazooka tv yan...hehehe
  • Pogi/Ganda Points: 237
« Reply #13 on: June 04, 2011, 04:30:48 PM »
kapehan nayan ts...
Offline taqui
  • ang ganda ko
« Reply #14 on: June 04, 2011, 07:21:43 PM »
kapehan na pala.. pag wala available pwede na d1879 d1556 d1557
« Reply #15 on: June 05, 2011, 07:16:09 PM »
mayron yan hehehe
Offline taqui
  • ang ganda ko
« Reply #16 on: June 06, 2011, 01:46:22 PM »
hehe dito kc wala available ng hot na un..
Offline bongking
« Reply #17 on: June 06, 2011, 04:08:15 PM »
Update lang mga master, pinalitan ko ang HOT gumana ang unit for 5 minutes after that nagbalik sa standby mode ulit. check ko HOT nagshort ulit, at may hissing sound sa may psu section. Mga master what next move na i check para di na ma short HOT pag palit ko ulit. tnx
« Reply #18 on: June 06, 2011, 04:16:27 PM »
baka may tama na sis ang flyback mo pa check mo muna. replace ka na rin ng crystal cs503 kung meron yan .
Offline bongking
« Reply #19 on: June 06, 2011, 04:20:00 PM »
ganun ba yun sir, kase nung nag standby mode ulet masyadong mainit yung Hot nung hinawakan ko. Any more suggestion mga master?
