Author Topic: sharp 14v-L80M vertical  (Read 883 times)
Offline enriz622
  • Pogi/Ganda Points: 291
Re: sharp 14v-L80M vertical
« Reply #20 on: June 17, 2011, 08:13:26 AM »
24c02 pwede dyan
Offline danyenz
  • Pogi/Ganda Points: 197
« Reply #21 on: June 17, 2011, 09:27:07 AM »
may mga post dito na di sagot ng ts kya malabo ito matulongan....o baka ok na unit..
Offline J@M
  • Pogi/Ganda Points: 125
« Reply #22 on: June 17, 2011, 10:56:36 AM »
Ts hanapan mo muna ng EEprom...tsaka nga pala ung supply ng vertical mo db dapat my +12 & -12 yan be sure na present 2 na yan...
Don't Give up
Offline hackerz
  • Pogi/Ganda Points: 5
    • operamini
« Reply #23 on: June 17, 2011, 05:03:15 PM »
pin#4 ng vert ic connected ba sa ground? check mo na din yung yoke../pin4 ground po master,.nextday ko nalang ulit eto gagawin kc wala ako eprom ,nasira ko kc sa pag baklas,.salamat po mga nagreply..
god is good all the time
Offline hackerz
    • operamini
« Reply #24 on: June 17, 2011, 05:20:47 PM »
update ko lang kau mga master,k0ng may eprom na ako,medyo matagal narin to sakin.
Offline hackerz
    • operamini
« Reply #25 on: June 30, 2011, 02:50:27 PM »
ok na po vertical..salamat po.
Offline danyenz
« Reply #26 on: June 30, 2011, 03:00:30 PM »
kongrats pwde yata share ng trouble..
Offline hackerz
    • operamini
« Reply #27 on: June 30, 2011, 03:07:54 PM »
nagpalit po ako eeprom nag normal po vertical,..salamat master,1+pogi point po,
