Author Topic: 60MHz Frequency Meter / Counter (PIC16F628A)  (Read 2387 times)
Offline sharbor_tech
  • Pogi/Ganda Points: 76
  • <img src="http://www.chatchaielec.com/board/index.
« on: June 06, 2011, 07:25:31 PM »
saan dito sa elab meron program ng 60mhz freguency meter gamit PIC, interesado lang ako gumawa ng isa, tulong sa pag gawa ng electronic circuit...
Offline RaffT
  • Pogi/Ganda Points: 103
  • more on R-n-D
    • MY Bots
Re: 60MHz Frequency Meter / Counter (PIC16F628A)
« Reply #1 on: June 06, 2011, 07:46:10 PM »
do you mean HEX file?
« Reply #2 on: June 06, 2011, 07:48:51 PM »
« Reply #3 on: June 06, 2011, 07:56:46 PM »
ito yung scematic.. yung program di ko makita
Offline RaffT
  • more on R-n-D
    • MY Bots
« Reply #4 on: June 06, 2011, 08:23:09 PM »
search nalang for other PIC based freq counter.. meron ako nakita w/c uses F84 and a 2x16 lcd..
madami yan sa google :)
  • Pogi/Ganda Points: 269
« Reply #5 on: June 07, 2011, 03:49:42 PM »
subscribing .. parang interesado rin ako dito ah..
Offline Macgyver
  • Pogi/Ganda Points: 70
    • MakerDude
« Reply #6 on: June 07, 2011, 04:40:13 PM »
mayroon bang nakakaalam kung paano nagwowork yan specifically ung part mula sa input hanggang makarating dun sa pins 3 and 4
  • Pogi/Ganda Points: 482
« Reply #7 on: June 07, 2011, 04:53:21 PM »
ito ayaw mo ba?
MAIN FEATURES
    * 10 Hz frequency resolution.
    * Direct frequency measurement.
    * Seven offset channels selectable with a push button.
    * Each offset channel got 3 options (VFO + IF) , (VFO IF), ( IF - VFO ) selectable with a three position switch.
          o Eg.1 Suppose IF is 9MHz (9MHz SSB filter using with home made TRX) and VFO is 2 MHz you have to select the third option (IF-VFO) ie (9 2) = 7 for 40 mtr operation.
          o Eg.2 Suppose IF is 9MHz and VFO is 5MHz you have to select the first option VFO+IF ie 9 + 5 = 14 for 20 mtr operation With this offset channel selection option you can simply input the VFO frequency to the counter with out any conventional mixing for displaying the operating frequency
    * In each of the above offset channel option, it is possible to select USB/LSB displayed as N / R (Normal / Reverse) selectable with another 2 position slide switch.
Any IF frequency can be programmed into the available seven channels, as per the requirement of the user . We have pre-programmed the most commonly used frequencies such as 9, 1.6, 10, and 4 Mhz.
ito yung HEX
« Reply #8 on: June 07, 2011, 05:19:16 PM »
sis kasamiko.. hindi ko gaano na gets yung crystal,kung mag palit ng crystal 4.000mhz makuha yung 60mhz???
