Author Topic: Goldstar shutoff  (Read 1544 times)
Offline xoochu
Goldstar shutoff
« on: June 08, 2011, 12:55:01 PM »
..good day po mga masters!pahelp naman po…
Ang inaayos q po kcng goldstar na tv biglang nagsh-shutoff kapag kinakabitan q ng antenna. Ganun din po ang nangyayari kapag iswitch q sa uhf. Ano po kaya problema nito? Salamat, :)
Goldstar shutoff
Offline x13r_kit_0
  • Pogi/Ganda Points: 149
  • --__x13r_kit_0__--
Re: Goldstar shutoff
« Reply #1 on: June 08, 2011, 01:09:31 PM »
an
anu model nito sir...?at pakidagdagn na rin po ng info..
ibig sabihin po ba gumagana sa av mode..,at hindi namamatay pag wala antenna..
   =How about the other side?=
  • Pogi/Ganda Points: 231
« Reply #2 on: June 08, 2011, 01:17:22 PM »
baka may kumakawang ..try mo tapik- tapikin ang chassi.. wag sobrang lakas ha..baka sa junk mapunta.
Offline xoochu
« Reply #3 on: June 08, 2011, 03:36:35 PM »
an
cn-20a86,opo, ganun po ang nangyayari.
..naresolder q na lahat, tsaka naghu.hum pala ang transformer supply sa relay, kapag may antenna..
Offline enriz622
  • Pogi/Ganda Points: 284
« Reply #4 on: June 08, 2011, 05:11:21 PM »
patambay nga ako dito,check ecaps
Offline sharbor_tech
  • Pogi/Ganda Points: 75
  • <img src="http://www.chatchaielec.com/board/index.
« Reply #5 on: June 08, 2011, 05:31:15 PM »
patambay 8)   cold solder joint parin yan sis. ;D hinang pa sa system section.
« Reply #6 on: June 08, 2011, 05:38:01 PM »
[/quote]
pag anttenna lang,sa A/V ok,hindi kaya graunded yung bubung
Offline Mr. Turko
  • Pogi/Ganda Points: 56
« Reply #7 on: June 08, 2011, 06:37:31 PM »
palit ka na ng mga ecap sa power supply, palitan mo narin yung xtal osc. 503..
Offline NORTH LUZON
  • Pogi/Ganda Points: 811
« Reply #8 on: June 08, 2011, 06:44:14 PM »
filter sa secondary supply ang malamang na sira jan lalo na ung b+ ecap!
congratz na yata ito ah
« Reply #9 on: June 08, 2011, 06:51:39 PM »
Parang na uncounter troble na yan,bumabagsak mga boltahe at transformer nag HUMM pag connect ang antenna, parang LIVE ang isang linya mula rooftop... sa audio video walang problema... nasa power supply yan. pagitan ng HOT at COLD AREA ng graound,temistor ata yon. ???
Offline NORTH LUZON
« Reply #10 on: June 08, 2011, 06:54:53 PM »
ndi na sinagot ng ts kung ok ang unit sa av mode
pero malamang shut-off din yan sa av mode
« Reply #11 on: June 08, 2011, 07:01:22 PM »
wala pa si sis... sis tanong kolang,wala pang antenna pag iconnect shoutoff na at nag spark pag ikiskis sa metal ng antenna?  ???
Offline taqui
  • Pogi/Ganda Points: 228
  • ang ganda ko
« Reply #12 on: June 08, 2011, 09:44:55 PM »
abang muna...
Offline noman75
  • Pogi/Ganda Points: 260
  • 09335154904 / 032-4848039
    • Here`s my blog....
« Reply #13 on: June 08, 2011, 09:48:27 PM »
makiabang na rin dito...
NoMaNz 4-ever
Here`s my blog....
http://noman75.blogspot.com/
  • Pogi/Ganda Points: 771
« Reply #14 on: June 08, 2011, 09:53:46 PM »
update TS para mapadali
Offline x13r_kit_0
« Reply #15 on: June 08, 2011, 11:09:23 PM »
 ok daw yata sa av mode,baka ng grounded yung antenna..subukan kaya kaperasong wire lang iantenna.
abang update...
Offline danyenz
  • Pogi/Ganda Points: 196
« Reply #16 on: June 09, 2011, 07:41:29 AM »
wala na si ts...abang muna dito sa gilid..
« Reply #17 on: June 09, 2011, 07:52:14 AM »
baka nakuryente na!!! sa TUNER ;D ;D ;D ;D
Offline J@M
« Reply #18 on: June 09, 2011, 08:04:53 AM »
makiabang nga muna d2 malamig eh..
Don't Give up
Offline enriz622
« Reply #19 on: June 09, 2011, 08:13:10 AM »
Baka naka dikit naman antenna sa live wire sa labas
