Author Topic: toshiba surplus., vertical prob..  (Read 945 times)
Offline benigz
« on: June 11, 2011, 12:21:34 AM »
mga master patulong po..
ung unit ko po eh 1 line horizontal..
nagpalit n me ng vert. ic., ganun padin..
tpz resolder s jungle at syscon.,
ok nmn ang supply ng vert. 24vdc..
ok din po ung yoke..
tnx in advance..
Offline Mr. Turko
  • Pogi/Ganda Points: 56
Re: toshiba surplus., vertical prob..
« Reply #1 on: June 11, 2011, 01:09:45 AM »
ano model # nyan sis bazooka ba yan? ano ginamit na vertical ic AN5515 ba or AN5521, maganda kung ma-picturan mo yung board..
Offline taqui
  • Pogi/Ganda Points: 228
  • ang ganda ko
« Reply #2 on: June 11, 2011, 06:45:06 AM »
diode..ecap,
pakisukat po sa vert.def yoke kung my masusukat or sa ecap 25v/2200uf-1000uf. 12-14v dapat meron
Online pete
  • Pogi/Ganda Points: 771
« Reply #3 on: June 11, 2011, 06:47:30 AM »
sirain talaga ang vert. nyan or baka nagalaw ang svc switch pwede rin ecap sa paligid.
paki kapa nga ng vert ic kong lalaki ng kaunti
Offline sharbor_tech
  • Pogi/Ganda Points: 75
  • <img src="http://www.chatchaielec.com/board/index.
« Reply #4 on: June 11, 2011, 06:48:01 AM »
model no. chassis no. picturan mo rin.. :D
Offline danyenz
  • Pogi/Ganda Points: 196
« Reply #5 on: June 11, 2011, 07:38:43 AM »
post mo po ts model # kung ang ic gaya sb ni master mckoy AN5521 palit mo c305,c342,R306 yan ang culprit nyan...ay nadulas ako nasubo agad hahaha sori mga master hula lang po..
  • Pogi/Ganda Points: 231
« Reply #6 on: June 11, 2011, 12:07:08 PM »
Master ka talaga sis danyenz... ;D
Offline Triple_D
  • Pogi/Ganda Points: 164
« Reply #7 on: June 11, 2011, 12:42:27 PM »
congrats na ts...
Offline Mr. Turko
« Reply #8 on: June 11, 2011, 03:12:54 PM »
vertical common na yan sa mga toshibak madalas yan 1uf or 2.2uf 50volts kulay brown minsan kulay green dalawa yan, kung  bazooka yan isang ecap katabi ng vertical ic yung isa katabi ng jungle madali lang hanapin dahil sa kulay..
Offline taqui
  • ang ganda ko
« Reply #9 on: June 11, 2011, 04:00:13 PM »
correct ka sis micmkoy. para san kaya ung 1uf/50v near jungle? vertical anu kaya un? frequency kaya?
Offline danyenz
« Reply #10 on: June 11, 2011, 04:13:03 PM »
baka drive o vert.ramp
Offline taqui
  • ang ganda ko
« Reply #11 on: June 11, 2011, 04:14:54 PM »
tnx sis danz..
sa ts isama narin palitan ecap na un.
Offline Mr. Turko
« Reply #12 on: June 11, 2011, 05:22:47 PM »
parehas yan sa vertical section yan ecap sa near jungle vertical out, kung makikita nyo yung isang tread dito yung naka post ang picture board ng bazooka makikita nyo dalawang ecap kulay green katabi ng vertical ic yung isa is near jungle..
Offline taqui
  • ang ganda ko
« Reply #13 on: June 11, 2011, 05:54:51 PM »
tnx plus one ka at kay sis danyens
Offline unitech
  • Pogi/Ganda Points: 58
  • all in one hunter
« Reply #14 on: June 11, 2011, 06:58:28 PM »
nasubo na nman ni master danyenz...congrats na...
Offline RhUNhA
  • Pogi/Ganda Points: 356
« Reply #15 on: June 11, 2011, 08:26:50 PM »
tambay nga po.
Offline benigz
« Reply #16 on: June 11, 2011, 09:43:57 PM »
mga master toshiba 14RS1 po ung model nya., surplus., 100VAC.
TMP47C434N-R224  syscon
TA88C4AN  jungle
TA8403K   vertical
nagpalit n poh ako ng vertical ic, voltage checking, tska po my volatge ung s yoke nya., n try ko n din po n galawin ung serv. swtch., pero 1 line p din..
panu po b magpost ng image para makita nyo po mga master..?
Offline Mr. Turko
« Reply #17 on: June 11, 2011, 10:50:37 PM »
ganun ba,  may sound ba yan sis benigz?
Offline NORTH LUZON
  • Pogi/Ganda Points: 812
« Reply #18 on: June 11, 2011, 10:55:55 PM »
@ts
para mapadali ka ay dapat masiguro mo kung working ang vert output mo. pag 0k ang output mo ay sa vert driver then sa oscillator ka naman! saka kada laki ng guhit at malalaman kung saang parte ang nagkakaproblema sis.
ask ko lang kung anung kulay ng guhit mo at gaano ito kalaki?
ga sinulid ba na pula?
Offline danyenz
« Reply #19 on: June 11, 2011, 10:56:22 PM »
TA88C4AN  jungle
TA8403K   vertical
ok na yan kht wala picture kuha na namin..yung pin #4 ng vert. ic papunta yan jungle..palit mo mga pyesa, resistor at capacitor...nasa 3 o 4 na pyesa lng yan... or volts reading mo pin #4 dapat mron yan kaht 1v,,
