Author Topic: toshiba surplus., vertical prob..  (Read 943 times)
Offline danyenz
  • Pogi/Ganda Points: 196
Re: toshiba surplus., vertical prob..
« Reply #20 on: June 11, 2011, 10:57:14 PM »
ganun ba,  may sound ba yan sis benigz?
oo nga pala may sound ba ito? kung wala  iba sira nyan..
Offline benigz
« Reply #21 on: June 11, 2011, 11:06:29 PM »
wla din sound sismicmkoy..
ganito kz history nun..
ang unang trouble nun eh madilim..
so binaklas ko para iadjust ung screen nya.. pero pagbukas ko ng cover sa likod., kala ko paso.. kulang na lng damo.. so nilinis ko ng brush., then nung pinower on ko.. un 1 line n.. ngresolder n din me at replace ng vert ic..
panu po b magpost ng image para po makita nyo ung board nya..
Offline Mr. Turko
  • Pogi/Ganda Points: 56
« Reply #22 on: June 11, 2011, 11:26:09 PM »
paliguan mo muna babad mo sa tubig na may ariel powder ng 2hours tapos brusin mo ng sipilyo banlawan tapos patuyin isang araw, para mas maganda itrouble baka may nag open na dyan. kung walang sound yan check mo supply sa tuner kung may 12volts pag wala sundan mo baka may open yan o may short hung mo isaisa para matuntun mo wala rin supply yan sa jungle, nakahiwalay ang supply nyan  galing fbt  dumaan muna sa regulator papunta jungle hangang tuner..
Offline danyenz
« Reply #23 on: June 11, 2011, 11:36:24 PM »
may kulay ang guhit o puti..kung may kulay patay ang ic mo..
Offline benigz
« Reply #24 on: June 11, 2011, 11:44:01 PM »
ok.. cge sis..
i will follow you..
update n lng me.. tnx
Offline benigz
« Reply #25 on: June 11, 2011, 11:46:14 PM »
patay tyo jan master danyenz.. my kulay nga.. pula p..
Offline danyenz
« Reply #26 on: June 11, 2011, 11:50:46 PM »
chck mo ic d nag wowork baka wala suply..
Offline benigz
« Reply #27 on: June 12, 2011, 12:07:16 AM »
cge po maestro danyenz..
check ko ung supply ng jungle ic..
update n lng po me tom..
tnx..
Offline taqui
  • Pogi/Ganda Points: 228
  • ang ganda ko
« Reply #28 on: June 12, 2011, 05:29:51 AM »
ilang supply na na-read at sa output ng vertical ilan dn?
Offline benigz
« Reply #29 on: June 12, 2011, 03:50:16 PM »
mga master ok n po ung sa vertical problem
nya.. bumuka n.,
9v regulator papuntang jungle ang salarin.,
loose solder., matapos ko itong resolder bumuka n xia.
tinaas ko ung screen to make sure n bumuka n..
kaya lng plain black.. walang display.,
kahit mglipat me ng channel, nothings happen.,
wla rin xiang sound., suspek ko po ung jungle nya.,
TA8864AN ung jungle nya., ang available ko lang po d2 ay TA8680N.,
parehas lang po b un..?
tama po b ang suspek ko...??
Offline danyenz
« Reply #30 on: June 12, 2011, 05:58:50 PM »
sabi na nga ba hahaha...tangalin mo muna jungle tapos balik mo baka mag normal... suply lang nawala kaya may kulay ang guhit..malamang buo yan jungle sundin mo lng sugestion ko,,tangal balik..
Offline Mr. Turko
« Reply #31 on: June 12, 2011, 06:35:05 PM »
nya.. bumuka n.,
may supply ba sa g2?, sa heater, tingnan mo rin crt socket baka corroded na hindi liliwanag yan..
Offline Mr. Turko
« Reply #32 on: June 12, 2011, 06:37:19 PM »
wala ka bang maaninag kahit konti?
Offline NORTH LUZON
  • Pogi/Ganda Points: 812
« Reply #33 on: June 12, 2011, 09:08:21 PM »
@ts
para mapadali ka ay dapat masiguro mo kung working ang vert output mo. pag 0k ang output mo ay sa vert driver then sa oscillator ka naman! saka kada laki ng guhit at malalaman kung saang parte ang nagkakaproblema sis.
ask ko lang kung anung kulay ng guhit mo at gaano ito kalaki?
ga sinulid ba na pula?
kuhang kuha pala ang hula ko
sa kulay ng guhit palang ay malalaman na ang salarin
Offline taqui
  • ang ganda ko
« Reply #34 on: June 12, 2011, 09:17:46 PM »
suyod muna sa vcc jungle, try muna sa audio video kung wla dn sound at picture.
Offline Triple_D
  • Pogi/Ganda Points: 164
« Reply #35 on: June 15, 2011, 12:16:35 PM »
di yata binasa ng ts ang post mo master kagz hehe..
Offline NORTH LUZON
« Reply #36 on: June 15, 2011, 12:32:41 PM »
parang ganun na nga sis
parang alang silbi ung post ko pero same din after awhile ang mangyayare
