Author Topic: TRIGONOMETry Problems (Patulong)  (Read 702 times)
Offline THF
« on: June 14, 2011, 01:11:47 AM »
Q:
At a certain point, the angle of elevation of the top of a flagpole which stands on level ground is 40 degrees. 80 feet nearer the pole, the angle of elevation is 65 degrees. How high is the pole?
I like to risk it all
Offline dummy_c
  • Pogi/Ganda Points: 162
Re: TRIGONOMETry Problems (Patulong)
« Reply #1 on: June 14, 2011, 07:49:23 AM »
Pwede kaya 80tan65?? Pero parang hindi kasi parang easy lang. I don't understand the first statement.
  • Pogi/Ganda Points: 433
« Reply #2 on: June 14, 2011, 08:46:32 AM »
Ratio and proportion lang yan. Two right triangle.
1. Where at 40 degree distance from base of the pole (assuming horizontal plane at x axis) lets say that point from pole base is mark as point "r". And pole base is 0.
2. And 80 ft nearer the pole seeing the highest point of the pole its angular degree is 65 degree. Mark as point " x".
                                    p
                                    I
                                    I
                                    I
                                    I
        / 40 d       /65d       I
       r               x           0( base)
3. where distance from r to x = 80 ft.  Point r = x + 80ft = adjacent side
    ratio and proportion on right triangle    point x, 0, p then x. And right triangle point r,0,p then r.
Just solve the other unknown. Goodluck.
Online kinyo
  • Pogi/Ganda Points: 25
« Reply #3 on: June 14, 2011, 09:01:26 AM »
h = (80*sin(40)*sin(65))/sin(25)
law of sines
 ;D
« Reply #4 on: June 14, 2011, 09:17:16 AM »
In simple term you must first solve the unknown "x" to get the true height of the pole. Height commonly denote as "y" is subtituted by the angular displacement. Using your fav SOH CAH TOA method. Since your talking trigonometry.
Offline motion55
  • Pogi/Ganda Points: 245
« Reply #5 on: June 14, 2011, 09:37:45 AM »
tan 65° = y/x
tan 40° = y/(x+80)
You now have 2 linear equations with 2 unknowns. It is straight algebra to solve this.
"Set your mind free!"
Offline THF
« Reply #6 on: June 14, 2011, 11:02:46 AM »
Tama kaya tong ginawa ko?
let: y1 be the height in 40 degrees
      y2 be the height in 65 degrees
Solution:
y1=(x+80)tan40
y2=xtan65
y1 must equal y2 (y1=y2)
xtan65  =  (x+80)tan40
Offline Johannah Aleksandria
  • Pogi/Ganda Points: 138
  • Make it simple
« Reply #7 on: June 14, 2011, 11:29:08 AM »
Very simple problem actually, ayoko lang mag-isip ;D ;D ;D. basta ts pag-aralan mo sign law ska cosine law.
Offline melecee
« Reply #8 on: June 24, 2011, 09:36:23 PM »
may isang ganyang-ganyan problem na lumabas sa nakalipas na board ng ee april 17-18 sa math.
Offline iyo karpo
  • Pogi/Ganda Points: 18
« Reply #9 on: July 16, 2011, 09:45:22 PM »
hcot65 + 80 = hcot40
h = 58.056
Offline /
  • Pogi/Ganda Points: 317
« Reply #10 on: July 16, 2011, 10:25:13 PM »
nice post.. :D
Offline Nokia
« Reply #11 on: February 20, 2012, 06:52:52 PM »
first equation: tan 40 = [h / (80+x)]
second equation: tan 65 = (h/x)
using shift solve,
x = 51.423 deg
substituting the value of x in the first or second equation gives
h= 110.27 deg
Offline NORTH LUZON
  • Pogi/Ganda Points: 834
« Reply #12 on: February 20, 2012, 10:04:32 PM »
112.797 ft
