Author Topic: RF trnsmitter yung pang FM radio  (Read 1568 times)
Offline necoleis
« on: January 30, 2008, 12:43:10 AM »
meron po ba kayong schematic ng RF transmitter na pang FM radio? Paki post naman po
necolei
Ang ulo ay hindi lang pinapagupitan kundi ginagamit din hehehe
by: uncle jr
Offline paranz
  • Pogi/Ganda Points: 177
  • 1/4W resistor specialist
    • RapidSignal Electronics
Re: RF trnsmitter yung pang FM radio
« Reply #1 on: January 30, 2008, 12:48:53 AM »
i-google mo na lang siguro marami eh..
if you are interested to build one, hanap ka ng circuit na may electret mic. (ECM) and using 2-3 transistors. Good project na yan.
Offline necoleis
« Reply #2 on: January 30, 2008, 12:55:50 AM »
pwede rin po bang i connect ang mp3 player dun? yung pong parang mey radio station ako pero sa bahay lang or sa kotse hehehehe.
necolei
by: uncle jr
Offline paranz
« Reply #3 on: January 30, 2008, 01:02:48 AM »
yeah pwede. alisin mo lang ang ECM ok na yan
Offline necoleis
« Reply #4 on: January 30, 2008, 01:05:52 AM »
salamat po. naka kuha na po ako ng link ng FM Radio transmitter. share ko lang po.
http://www.electronickits.com/kit/complete/surv/ck200.htm completo yan with schematic just download the PDF file
necoleis
by: uncle jr
Offline paranz
« Reply #5 on: January 30, 2008, 01:33:53 AM »
good find.. thats one of the simplest FM transmitter around, and it uses reactance modulator technique for FM modulation.
the circuit is not really good though, since first transistor amplifier stage (the ECM preamp) uses a self-bias circuit which is very sensitve to transistor gain variation. Half of the time the circuit will not work as well as advertised.  :P
Offline Born2BeWired
  • Pogi/Ganda Points: 171
    • e-Gizmo Mechatronix Central
« Reply #6 on: January 30, 2008, 10:54:06 AM »
necoleis
This kit does not have any frequency stabilizing circuit. Just about anything will throw its frequency off mark.
It will work fine with old analog type FM receiver equipped with AFC (automatic Freqency Control) function. But (I suspect) making it work it newer PLL FM receiver will be a challenge.
Offline Mayor Johnaray
  • Pogi/Ganda Points: 238
« Reply #7 on: February 03, 2008, 02:30:11 AM »
Ehem bili ka na lang sa CDRKing
Ito link http://www.cdrking.com/local/products/index.php?action=mnu&temp=2&typeno=7294644-366654-481500020-0550430&prod=FM%20Modulator/Transmitter
Mas makakamura ka pa kaysa mag assemble ka pa.
Pero kung gusto mo talaga mag assemble meron nyan sa ALEXAN sa RAON or sa DIVISORIA
 ;D
