Author Topic: help in IC for switching from main power to backup power  (Read 2920 times)
Offline gunbladespecialist
    • Paradox Equation
« on: May 27, 2008, 10:05:55 AM »
Hello guys i have a problem right now..
We are currently designing a system that will have a main power source as well as a backup power source.
Once the main power source runs out, the systemwill the  switch to the backup source. I was wondering if I can implement this
using an IC or a relay. I hope you could help me out. thanks..
P.S. the two power supplies are both DC..
Engineer,Photographer,Blogger,Techgeek
Offline ahlburuto
  • E&I tech.
Re: help in IC for switching from main power to backup power
« Reply #1 on: May 27, 2008, 10:27:06 AM »
Kung relay logic, ang mga kelangan mo eh dalawa na magnetic contactor, yung isa eh para sa main supply tpos yung isa eh sa standby supply. 2 relay na 4pdt or 2pdt. yung isang relay eh connected yung coil nya sa main supply. At sya ang magpower up ng isang contactor. tapos yung isang relay naman eh para sa isang contactor. kelangan mo dito ng UPS kahit yung maliit lang at timer para sa switching ng mga contactor. UPS will serve sa switching ng standby power.
br
    • Paradox Equation
« Reply #2 on: May 27, 2008, 10:29:52 AM »
portability is one of the top priority sa design..kaya po naghahanap me ng IC that will do the switching job between the two dc supplies which is 6V
Offline ahlburuto
  • E&I tech.
« Reply #3 on: May 27, 2008, 10:31:47 AM »
Alin yung 6volts? yung control voltage? at para sa 220vac supply ba ito or demo lang na ang gagamiting supply eh 6volts?
Offline ahlburuto
  • E&I tech.
« Reply #4 on: May 27, 2008, 10:34:42 AM »
both power supply ba eh 6volts?
    • Paradox Equation
« Reply #5 on: May 27, 2008, 10:39:25 AM »
yan po ang supply voltage...bale the 6v will be distributed to the different components via a buck converter and each of the power supplies are rated 6V..pero isa lang ang normally active while the other one will be on standby and pag naubos na ang main power that's the time magiging active ang standby.
Offline ahlburuto
  • E&I tech.
« Reply #6 on: May 27, 2008, 10:43:51 AM »
anung mag trigger sa standby power? lagi ba syang naka on or mag on lang yung standby power pag nawala na yung main power? Or both supplies ar at on position?
    • Paradox Equation
« Reply #7 on: May 27, 2008, 10:47:46 AM »
yan dn po ang tinatanong ko..hehe.. the one that will trigger the standby power once nag run out na ang main.. possible kaya cya using an IC.. if so anong IC ang ggmitin?
Offline ahlburuto
  • E&I tech.
« Reply #8 on: May 27, 2008, 10:53:06 AM »
kaya yan ng relay logic. iparallel mu lang yung switch ng standby power supply sa relay ng main supply. dun sa normally close mu sya parallel. kasi pag naka energized yun eh normally open mangyari dun... di pa ko nakapaggawa nyan using mga IC eh. intayin mong magising yung iba nating mga kasama. baka me idea sila sa kelangan mo.
sa aking design eh puro relay lang gamitin mo. kelangan mu lang ng electrical interlock nun para safe sa switching....
br
    • Paradox Equation
« Reply #9 on: May 27, 2008, 10:58:31 AM »
noted po sir.. ty po.. ano pong type ng relay ang gagamitin? sorry po if im asking too much.eto po kasi task ko sa OJT e and hindi pa ako nka pag implement nga circuit using relays..based on assumptions and theories lang tlaga yung akin.. it would help sana if merong block diagram...im also searching on google about relays
« Reply #10 on: May 27, 2008, 11:13:17 AM »
Pareho bang battery ang main and backup power supply?
Offline 1110000
  • Pogi/Ganda Points: 28
« Reply #11 on: May 27, 2008, 11:14:54 AM »
depende yung relay mo sa load ;) ilang watts ba yung load mo?
E153C51513
Offline zer0w1ng
  • Pogi/Ganda Points: 305
    • The Cebuano Geek
« Reply #12 on: May 27, 2008, 11:23:06 AM »
2 diodes will do.
But the primary supply should be a bit more voltage than the secondary, so that there will be no consumption on the secondary ps.
The Cebuano Geek
Offline 1110000
« Reply #13 on: May 27, 2008, 11:32:37 AM »
@ zer0w1ng
diba pede naman  pagibahin yung voltage nila using diode again :D
E153C51513
    • Paradox Equation
« Reply #14 on: May 27, 2008, 11:37:32 AM »
regarding the diodes?ano yung configuration nla?will the two be forward biased?
Offline ahlburuto
  • E&I tech.
« Reply #15 on: May 27, 2008, 12:38:07 PM »
kung 6volts ang voltage na gamitin o eh merong nabibili na pcb mount na 6vdc na relay, anu nga lang yun 1PDT. kaya madami kang magagamit. depende rin kung ilang contact ang kelangan mu.
Offline zer0w1ng
    • The Cebuano Geek
« Reply #16 on: May 27, 2008, 12:51:53 PM »
Like this:
Primary (6.71V)  o---------|>|------+------o Output (6V)
 Secondary (6.7V) o---------|>|------+
@ zer0w1ng
You could put another diode to drop the voltage. But this depends on the application.
The Cebuano Geek
    • Paradox Equation
« Reply #17 on: May 27, 2008, 07:04:27 PM »
@zerow1ng
correc me if im wrong, pero based dun sa diode config..pero it looks like that both pwer sources are working/drawing power at the same time?
Offline 'yus
  • Pogi/Ganda Points: 299
  • hw -> fw -> sw
    • yus' projects
« Reply #18 on: May 27, 2008, 07:29:24 PM »
Or, you can use two ORing mosfet instead of forward diodes..
advantages:
1) higher current capability (provided that you use power fets with low "on-resistance"),
  and also, no need to increase the output voltages of the two supplies..
2) smaller compared to mechanical relays (if you use mosfets with small packages like "power so-8")
disadvantage:
1) additional circuit (and also bias voltage) for turning-on the two ORing fets..
« Reply #19 on: May 27, 2008, 08:14:47 PM »
ang tawag sa IC na yan ay Power Multiplexer. gumagamit ang mga handheld devices na battery powered nito to switch from external supply or internal battery, or from 2 batteries.
eto lang naaalala ko pero 5.5V lang ang max voltage niya. nababago yung mga threshold kung kailan lilipat. maliit na IC 'to. TSSOP package. no need for external logic. trimmer na lang ang external circuit para i-program yung thresholds. tapos mga capacitors na lang. it takes around 1" x 1" footprint kung kasama na yung mga trimmer at capacitors.
Dual In/Single Out Autoswitching Power MUX, Manual/Auto Sw, Adj. Cur Limit, Adj. Vol Threshold
http://focus.ti.com/docs/prod/folders/print/tps2110.html
