hmm opinion ko lang ha. yung shockings when preheating nakakapagpababa buhay nung lamp, and also its the voltage good to make it comfy sparks and heat up pretty good (600V + DC).it would be the same as cfl's. cfl's dont need pre-heating.AFAIK: pre-heating is only needed because the supplied frequency and voltage is not enough to make good arcs so it needs to be forced to make initial arcs.CORRECT ME IF WRONG PLEASE
salamat po sir sa correction yun nalang pala kulang ahihihihi! hanap pako wala kasi mapag kahuyan galing sa sirang fireflly e salamat po hanap ako test ko uli,pero for now nawala na yung napakatagal na pag ilaw ng flourecent ko salamat sir test ko uli pag nakahanap ako ng kukuhaan? yung volts kailangan po ba talaga na 600 to 400v kasi 1200v yung caps na mali ko nilagay
thanks for sharing master efrenanother +1 ka sa akin.
Maraming salamat po kuya "efren" nagawa ko po ngayon 20W ang inasemble ko nilagyan ko pa ng petsa ng paggawa para malaman ko ang life-span ng FL.
Maraming salamat po kuya "efren" nagawa ko po ngayon 20W ang inasemble ko nilagyan ko pa ng petsa ng paggawa para malaman ko ang life-span ng FL.+5 po para sa inyo very useful po nito...yong iba try nyo na din basta sundin lang ang diagram at mga value gagana talaga...
ung life-span ng FL mo will depend on how frequent ung on-off cycles na gagawin mo.. instant start produces larger voltage ignition compared sa merong preheat.. you can check using a scope to verify
definitely, start up voltage spikes can reach as high as 600Vdc.
frequent on-off cycles is not recommended in this circuit or the pre-heat types either. Both will end up in a short lifespan of FL.
