Author Topic: sakura AV2800 no power  (Read 649 times)
Offline Jerbho
« on: July 05, 2011, 03:02:39 PM »
good pm mga master patulong naman po ano po problem good naman ang transistor output nya kaso wala pong audio out papunta sa speaker
Offline taqui
  • Pogi/Ganda Points: 228
  • ang ganda ko
Re: sakura AV2800 no power
« Reply #1 on: July 05, 2011, 03:05:10 PM »
may relay ba speaker out?
baka hindi napalo..
wait natin mga audio master.
Offline x13r_kit_0
  • Pogi/Ganda Points: 153
  • --__x13r_kit_0__--
« Reply #2 on: July 05, 2011, 03:23:57 PM »
more info...
ok ba speaker...audio input..rca..
resolder...check supply voltage...to main amp..
   =How about the other side?=
Offline Triple_D
  • Pogi/Ganda Points: 164
« Reply #3 on: July 05, 2011, 05:31:25 PM »
baka nakamute hehe..spkr ok ba?
Offline unitech
  • Pogi/Ganda Points: 61
  • all in one hunter
« Reply #4 on: July 05, 2011, 06:08:12 PM »
baka hindi napalo..
agree! mga voltahe na check naba lahat?
Offline GuDo
  • repair is my hobby and also my career..
« Reply #5 on: July 10, 2011, 02:27:49 AM »
ano na troubleshooting done mo? as your topic says, walang power ang unit mo.. please right the appropriate title para hindi siya contradicting sa concern mo.. okay kamo ang power transistors mo? tama si taquinaga maybe the relay isn't clicking.. check also the signal path.. check also the pre-amp of it has supply.. kasi madalas sa mga ganyang amplifier may ginagamit para sa bass and treble drive, medyo common type of pre-amp IC na ginagamit sa audio ay LM4558.. more info sa troubleshooting done..
"manatiling masipag, dahil ito ang tutulong sa iyo na umahon sa kahirapan"
Offline taqui
  • ang ganda ko
« Reply #6 on: July 10, 2011, 06:05:21 AM »
abang lang kame sir ts
  • Pogi/Ganda Points: 324
« Reply #7 on: July 10, 2011, 07:08:04 AM »
tambay tambay
Offline RhUNhA
  • Pogi/Ganda Points: 356
« Reply #8 on: July 10, 2011, 07:17:17 AM »
tama........ ang topic is no power tpos ang tnung bakit walang audio...usually sa sakura ay yung relay baka hindi nga nag trigger....maybe may heavy load or no supply..check m n mabuti yung mga supply ...speakr bka shorted ...
pki detalye m n mabuti sir TS...at kung anu n yung mga ngawa mo
Offline sharbor_tech
  • Pogi/Ganda Points: 75
  • <img src="http://www.chatchaielec.com/board/index.
« Reply #9 on: July 10, 2011, 09:23:41 AM »
« Reply #10 on: July 10, 2011, 09:38:35 AM »
uy may schema, ung fanstart, eto ba ung sumasabay sa tunog???
« Reply #11 on: July 10, 2011, 09:39:17 AM »
Offline GuDo
« Reply #12 on: July 10, 2011, 11:34:35 PM »
astig yung schema ng sakura ahh, may fanstart pa.. palagay ko ito nga yung sumasabay sa tunog dahil may fan driver ehh.. :) balita TS?
Offline Jerbho
« Reply #13 on: September 03, 2011, 02:59:55 PM »
mga master may click po ang relay nya kaso nga lng po walang indicator sa lcd   kahit na ilipat ang mga input nya saan po ako maghahanap ng trouble goog naman ang power transistor nya
Offline malamig
  • Pogi/Ganda Points: 66
« Reply #14 on: September 03, 2011, 11:03:08 PM »
pa sub na lang po muna.
Offline acer
  • Pogi/Ganda Points: 117
« Reply #15 on: September 03, 2011, 11:49:51 PM »
touch mo yung input ng volume control kung mag iindicate pag meron pusible sira switching IC
 parang wala akung nakitang ganitung model ng sakura sa site nila
nevergive up
