Author Topic: Power Amplifier - 20Wrms/channel : DR20W by 1diy  (Read 5642 times)
Offline Dandy
  • Pogi/Ganda Points: 31
« on: July 07, 2011, 11:55:16 AM »
Hello to all Audio Hobbyist, diyer’s and Music Lovers,  heto  share ko ang  IC  Power Amplifier base sa NS LM1876F,  capable of delivering 20Wrms/channel,  40Wrms Stereo,  good enough for home use (room use)  to deliver that kind of hifi music you always wanted to hear.
We, at 1diyTEAM called it DR20W,  it is primary  designed to Interface with the Digital Audio Tone Control (DATC)   http://www.electronicslab.ph/forum/index.php?topic=3775.0      that can be controlled to Automatically Turn On/Off at any time - 24 hours.   But of course,  the DR20W can be use to interface with other Tone Control / audio gadgets.
With DR20W  +  DATC   +  do diy MP3 Player  +  good pairs of Speakers, will make a complete a  diy  personal Home sound  systems.    { Do diy MP3 Player  :   http://www.electronicslab.ph/forum/index.php?topic=26831.0   }     The DATC is  a modern digital tone control with  surround processing, matrix and simulated surround that can be reproduced in the same front speakers – this makes the listening pleasure better than other  tone control.
The 1diyTEAM choose the IC amplifier other than its discrete design,   simplifying design, rugged, compact and reduced pcb size.  In the same manner, we also interested with latest  technology of digital power amplifier -specific to Class-T by tripath.
For  technical know how, the LM1876F datasheet described most of the information,  check this link to download the datasheet    http://www.alldatasheet.com/datasheet-pdf/pdf/224982/NSC/LM1876.html
Though, it appears to be Integrated and looks simple to design or  make,  indeed,  but then, there are issues that need to solved, like noise, oscillation, heating,  crosstalk, etc.. etc.. that appears when integrating into a system with other audio device / gadget – this makes the challenge to the diyers.
Here,  download the
a)   Technical preliminary information  :     http://www.1diycentre.com/DR20W_diiyPowerAmp_R1.0.pdf
b)   Schematic / Block Diagram  :    http://www.1diycentre.com/RD20W_hifi_schematic_diagram.pdf
Here are some pictures :
Prototype :
Prototype on the Universal PCB
First PCB :
Testing :
On its plastic case :
I believe that,  this design is not optimum and still many room for improvement, play around with it and learn from it.   I hope to hear from you, and I would be glad to hear anything you can come up with in using our DR20W.
Sa Audio Hobby,  I have completed the  a systems  with the integration of modular board :
1.  DR20W Power Amplifier   +   Digital Tone Control   +  MP3 Player
2.  5.1 DTS / Dolby Digital AC-3   diy  Home Theater
  • Pogi/Ganda Points: 412
Re: Power Amplifier - 20Wrms/channel : DR20W by 1diy
« Reply #1 on: July 07, 2011, 12:13:27 PM »
+1 for this info sis Dandy...
nasa magkano kaya? kasama yung enclosure..parang Alexan yung plastic??
Offline e-tronix
« Reply #2 on: July 07, 2011, 09:13:22 PM »
egizmo yata yan na plastic enclosure kulay gray
Offline 1diyMARKET
    • 1 am 1diyTEAM
« Reply #3 on: July 09, 2011, 05:35:05 PM »
nah... hehehehe,  this project is made 100%  outside pinas, it is made by Kuan Yu factory.  It is planned to use acrylic cabinet, kaso di natuloy, nagbakasyo bigla ang author.
« Reply #4 on: July 09, 2011, 05:44:45 PM »
Ganda! mas ok if may kasamang casing with decals na...;D
Offline e-tronix
« Reply #5 on: July 10, 2011, 08:42:15 PM »
magkano kya mga ganyang casing sir?
Offline 1diyMARKET
    • 1 am 1diyTEAM
« Reply #6 on: July 14, 2011, 01:12:00 PM »
Mas maganda kung fiber glass ang casing,  sinisiumlan pa lang buuin ang CNC para sa pag ukit ng mga opennings.  Sino kaya may service na ganito sa pinas?  iyong hobbyist service po.
Mura lang po ito sir kung sa China ka bibili,  pero kung isasama muna pati transport papunta pinas,  maganda bumili ka na lang sa Alexan kaya,  for my reference, magkano ito sa atin?
Offline 1diyMARKET
    • 1 am 1diyTEAM
« Reply #7 on: July 14, 2011, 01:14:43 PM »
may 10 pcs extra  pcb ng DR20W,  its for share sa mga gustong bumuo at minimum price.  PCB lang po  wala components,  inaayus pa lang iyong kit version,  check this site for more pix  http://www.1diycentre.com/DIYers_Space_files/Page494.htm
Offline n0th1n6
  • Pogi/Ganda Points: 62
« Reply #8 on: July 14, 2011, 01:17:38 PM »
Magkano naman ho yung PCB o kahit yung assembled yun pag umabot na iyan dito sa atin?
Offline 1diyMARKET
    • 1 am 1diyTEAM
« Reply #9 on: July 14, 2011, 01:24:23 PM »
Sir PM ko muna sa iyo for your reference, it will be open to fellow hobbyist once it finalized, salamat,   nasa pinas na po iyan at pangpilipinas ang price,  iyong pcb lang po ito,  naghahanap kami ng mga locally supplied materials,  lalu na heatsink saka transformer, para pang pinas na din ang whole kit price.
Of course, puwede ito gawin sa Universal pcb, hehehehe, see the prototype,  http://www.1diycentre.com/DIYers_Space_files/Page494.htm
Offline n0th1n6
« Reply #10 on: July 14, 2011, 01:28:30 PM »
Interested ako sir sa spare PCB nyo. Baka pwede ko po mabili yung dalawao apat dun. Meron kasi akong heatsink na maganda gusto ko subukan. :)
Offline 1diyMARKET
    • 1 am 1diyTEAM
« Reply #11 on: July 14, 2011, 01:34:45 PM »
Sure, ikaw pa.
Send mo na lang information mo,   http://www.1diycentre.com/estoreMCU_files/Page1167.htm  , para mamaya o bukas masabihan ko team natin na ipdala sa iyo, hoping satuday ay nasa iyo na,  thanks to Air21,  sana may Air11 para mas mura ang padala.
Offline n0th1n6
« Reply #12 on: July 14, 2011, 01:47:58 PM »
Hehe, kung dasma lang yun place sir kahit pickup ko na lang. Pero kung malayo ok na ang air 21
  • Pogi/Ganda Points: 521
« Reply #13 on: July 15, 2011, 03:28:56 PM »
meron din akong nakita nyan sa deeco...
Offline n0th1n6
« Reply #14 on: July 15, 2011, 04:51:09 PM »
Marami nyang ganyang enclosure sa deeco at e-gizmo. Ang plan ko ilagay ito sa freebie na OKW hehe.
Offline 1diyMARKET
    • 1 am 1diyTEAM
« Reply #15 on: July 17, 2011, 12:10:08 PM »
Hello Sir,  nakuha niyo  na ba ang PCB?  Dapat kahapon daw po ide-deliver.
Oks, looking forward to see the DR20W on your freebie OKW (ano ba iyon hehhehehe, picture naman).     Type ko pa din ilagay ito sa see thru  fiber glass.
Offline e-tronix
« Reply #16 on: July 17, 2011, 08:29:06 PM »
advice me kung may kit version na bka kaya ko ma imarket as student project sa mga contacts ko na skols.
  • Pogi/Ganda Points: 316
« Reply #17 on: July 17, 2011, 08:32:06 PM »
I have tried the lm1876 before too bad tinapon ng mother ko :D
Offline 1diyMARKET
    • 1 am 1diyTEAM
« Reply #18 on: July 17, 2011, 11:26:46 PM »
It was conceived and designed to have kit version, para sana sa school project, sa mga fellow hobbyist at audio freaks,   :) .    Kaya pala napili ito dahil individually controlled ang left at saka right channels,  mute at saka standby control.  It has also the flexibility to load, 4 and 8 ohms,  we tried 2 ohms as well,   kahit na i-short mo ang speaker ok parin after re-open,  overheat mo siya, ok pa din after thermal shutdown.
Tungkol sa kit, inaawitan pa namin iyong mga beloved OFW na i-share muna nila ang kanilang extra money at gained sa stock market, para magamit namin for this purpose, huwag muna sila punta KTV, sauna, bar, swimming, golf, etc..
hehehehehehe,  Sir,  kung saka sakli na  gusto mo i-build uli, share to us also,  I think our DR20W using LM1876F needed further improvement, puwede na paglaruan.
Offline e-tronix
« Reply #19 on: July 17, 2011, 11:39:04 PM »
cant wait to try the DR20W amp sir, im not an AMP fanatic nor into repairs,pero bka ito na simula. sa buy and sell lang gumagana utak ko. hehe. who are this OFW sir? how can thier money gain in stock market? hehehe
