Author Topic: Samsung CRT Monitor with arcing  (Read 941 times)
Offline Johannah Aleksandria
  • Pogi/Ganda Points: 136
  • Make it simple
« on: July 11, 2011, 07:11:08 AM »
Pag binabaan ko brightness saka contrast tumitino, ayaw nman ng mga bata at may pagkalabo. Minadali kong gawan ng paraan, nilalayo ko yung anode cable sa ground plates, medyo nwala yung paglipad ng arc.
Ano ba kailangan ko gawin rito?
Nwawala na ko sa ganitong repair eh, di ko nga alam magtanggal ng anode cable.
Patulong nman po mga master!
FBT na ba kailangan palitan o anode cable, may nakikita akong nabibiling cable eh.
Offline danyenz
  • Pogi/Ganda Points: 196
Re: Samsung CRT Monitor with arcing
« Reply #1 on: July 11, 2011, 07:51:57 AM »
tangalin mo anode cap,bago yun sundutin mo ng testrod na koniktado sa earth ground para madischarge hv, lagyan mo grasa ang tube at anode cap balik mo ulit, presto wala na arking..
Offline J@M
  • Pogi/Ganda Points: 119
« Reply #2 on: July 11, 2011, 08:04:58 AM »
As in grasa master Dan? Pwidi ba na sa chassis ground kabit pan discharge.?
@ TS malamang ok na yan gawin u lng advice ni master dan.
Don't Give up
Offline Triple_D
  • Pogi/Ganda Points: 164
« Reply #3 on: July 11, 2011, 08:57:32 AM »
congrats na ts...
Offline danyenz
« Reply #4 on: July 11, 2011, 01:17:34 PM »
opo grasa lang katapat nyan
  • Make it simple
« Reply #5 on: July 11, 2011, 03:19:53 PM »
Nilagyan ko na pero nandun pa rin. Nanggagaling sa gitna ng cable yung arcing. Pag nilalayo ko yung cable ng kunti medyo nwawala, pero ok nman nwala yung ingay na sumisirit sa anode cap.
Offline danyenz
« Reply #6 on: July 11, 2011, 04:26:45 PM »
ah kung sa cable lagyan mo hose,tangal mo muna yun anode cap..bili ka hose yun gamit sa motor (gas hose) magkabilang dulo tape mo..
  • Make it simple
« Reply #7 on: July 11, 2011, 04:30:03 PM »
Cge try ko to sir. Yung transparent ba na hose gamit din ng karpentero para mag-level?
Offline danyenz
« Reply #8 on: July 11, 2011, 04:32:02 PM »
yup.. kung kaya mo lagyan grasa mag kabilang dulo mas maganda wala lusot ang kryente..gudluck
Offline J@M
« Reply #9 on: July 13, 2011, 02:09:32 AM »
Lupit ni master dan ah...dami alam diskarte.
Don't Give up
Offline danyenz
« Reply #10 on: July 13, 2011, 07:26:19 AM »
napa yup ako dito bok gamit ko yung hose gasolina sa motor kulay itim para di halata..hehehhe
Offline danyenz
« Reply #11 on: July 13, 2011, 07:28:25 AM »
gnyan talaga pag tipid sa pyesa dapat resurceful tayo hehehe.. kung kailan dyan share ko din pano convert fbt hehehe
Offline taqui
  • Pogi/Ganda Points: 228
  • ang ganda ko
« Reply #12 on: July 13, 2011, 09:55:12 AM »
sub nga ako dito ng mtuto kay tatay danyez..
Offline RRcom
« Reply #13 on: July 13, 2011, 08:16:28 PM »
kuya bago ka mag tagpi tagpi lang check mo muna kung over voltage ung b+ puntang flyback konting taas lang ng voltage dyan malaki na ang epekto sa voltage ng flyback, maaring di na nag reregulate kaya pag nag adjust ka ng bright ay nalakas ang voltage.
Made in Calamba City
Offline brucetech
  • Pogi/Ganda Points: 46
« Reply #14 on: July 13, 2011, 08:46:12 PM »
walang lusot yan ky master dan kaya sundin mo na lng..lupit ng diskarte...congrats na yan ts,,
 BOK iba ka talaga..
Offline pEN DoTA
« Reply #15 on: July 13, 2011, 08:50:28 PM »
pwede rin gamitan ng vulcaseal :) ilibot sa wire ng anode cap. ;)
GOD LOVES YOU
  • Make it simple
« Reply #16 on: July 13, 2011, 08:51:33 PM »
 BOK iba ka talaga..
Ggawin ko na to bukas, busy lang kasi, at naghanap pa ko ng hose.
Offline /
  • Pogi/Ganda Points: 317
« Reply #17 on: July 13, 2011, 09:35:51 PM »
patambay..
  • Make it simple
« Reply #18 on: July 14, 2011, 07:09:04 PM »
Nlagyan ko na ng hose, wlang arcing kaya lang may bumabagang resistor at may hissing sa FBT. Nagkakaroon ng liwanag sa display kaya lang prang sirang CRT socket ang display. Ito na ang mahirap sa akin ngayon dahil prang ayaw ko ng tumuloy at may bakal kasi ang monitor na kailangan mo ba baklasin ang board para ma-service.
Offline pEN DoTA
« Reply #19 on: July 14, 2011, 07:29:06 PM »
salpakan mo nlang ng china  board sis.
GOD LOVES YOU
