Author Topic: INSULATION RESISTANCE ≥100MΩ  (Read 1052 times)
Offline ahlburuto
  • E&I tech.
« on: June 01, 2008, 11:10:09 AM »
nakikita ko to sa mga devices eh. dun sa datasheets nila. sino pwedeng mag explain ng detailed description?
br
Offline Inactive
  • Electrifying!
Re: INSULATION RESISTANCE ≥100MΩ
« Reply #1 on: June 01, 2008, 07:36:33 PM »
no idea pero sa palagay ko lng ito ang knyang resistance range?
Offline ahlburuto
  • E&I tech.
« Reply #2 on: June 01, 2008, 08:50:59 PM »
naguguluhan nga ako dun eh.... di ko magets para san yun eh electronic device naman yun... di bale sana kung mga motor yun... ;D
Offline Mentor Lee
  • Pogi/Ganda Points: 16
  • "Call to Me and I will answer you.....
« Reply #3 on: June 01, 2008, 09:37:56 PM »
Ahl,
Paki post mo  nung sample ng datasheet having this value. MOSFETS can have high resistance in the insulated region.
...and show you great and inscrutable things that you do not know "
--Hotline 333--
Offline ahlburuto
  • E&I tech.
« Reply #4 on: June 01, 2008, 09:40:00 PM »
check ko yung mga files ko po... ;D
Offline ahlburuto
  • E&I tech.
« Reply #5 on: June 01, 2008, 09:54:33 PM »
eto po yung sa omron na timer.... H3CR-A8 ang model
■Characteristics
Note: 1. The value is ?5% FS +100 ms to −0 ms max. when the C, D, or G mode signal of the H3CR-AP is OFF.
2. Refer to the Life-test Curve.
■Life-test Curve
Accuracy of operating
time
?0.2% FS max. (?0.2%?10 ms max. in a range of 1.2 s)
Setting error ?5% FS ?50 ms (See note 1)
Reset time Min. power-opening time: 0.1 s max.
Min. pulse width: 0.05 s (H3CR-A/-AS)
Reset voltage 10% max. of rated supply voltage
Influence of voltage ?0.2% FS max. (?0.2%?10 ms max. in a range of 1.2 s)
Influence of temperature ?1% FS max. (?1%?10 ms max. in a range of 1.2 s)
Insulation resistance 100 MΩ min. (at 500 VDC)
Dielectric strength 2,000 VAC (1,000 VAC for H3CR-A@S), 50/60 Hz for 1 min (between current-carrying metal parts and exposed noncurrent-
carrying metal parts)
2,000 VAC (1,000 VAC for H3CR-A@S), 50/60 Hz for 1 min (between control output terminals and operating circuit)
2,000 VAC, 50/60 Hz for 1 min (between contacts of different polarities)
1,000 VAC, 50/60 Hz for 1 min (between contacts not located next to each other)
2,000 VAC, 50/60 Hz for 1 min (between input and control output terminals and operation circuit) for H3CR-AP
Impulse withstand
voltage
3 kV (between power terminals) for 100 to 240 VAC/100 to 125 VDC, 1 kV for 24 to 48 VAC/12 to 48 VDC
4.5 kV (between current-carrying terminal and exposed non-current-carrying metal parts) for 100 to 240 VAC/100 to
125 VDC, 1.5 kV for 24 to 48 VAC/12 to 48 VDC and 24 to 48 VAC/VDC
Noise immunity ?1.5 kV (between power terminals) and ?600 V (between no-voltage input terminals), square-wave noise by noise
simulator (pulse width: 100 ns/1 μs, 1-ns rise)
Static immunity Malfunction: 8 kV
Destruction: 15 kV
Vibration resistance Destruction: 10 to 55 Hz with 0.75-mm single amplitude each in 3 directions for 2 hours each
Malfunction: 10 to 55 Hz with 0.5-mm single amplitude each in 3 directions for 10 minutes each
Shock resistance Destruction: 1,000 m/s2 3 times each in 6 directions
Malfunction: 100 m/s2 3 times each in 6 directions
Ambient temperature Operating: −10?C to 55?C (with no icing)
Storage: −25?C to 65?C (with no icing)
Ambient humidity Operating: 35% to 85%
Life expectancy Mechanical: 20,000,000 operations min. (under no load at 1,800 operations/h)
Electrical: 100,000 operations min. (5 A at 250 VAC, resistive load at 1,800 operations/h) (See note 2)
EMC (EMI) EN61812-1
Emission Enclosure: EN55011 Group 1 class A
Emission AC Mains: EN55011 Group 1 class A
(EMS) EN61812-1
Immunity ESD: IEC61000-4-2: 6 kV contact discharge (level 3)
8 kV air discharge (level 3)
Immunity RF-interference from AM Radio Waves: IEC61000-4-3: 10 V/m (80 MHz to 1 GHz) (level 3)
Immunity RF-interference from Pulse-modulated Radio Waves:IEC61000-4-3: 10 V/m (900?5 MHz) (level 3)
Immunity Conducted Disturbance: IEC61000-4-6: 10 V (0.15 to 80 MHz) (level 3)
Immunity Burst: IEC61000-4-4: 2 kV power-line (level 3)
2 kV I/O signal-line (level 4)
Immunity Surge: IEC61000-4-5: 1 kV line to line (level 3)
2 kV line to ground (level 3)
Case color Light gray (Munsell 5Y7/1)
Degree of protection IP40 (panel surface)
Offline mArKhAo
  • Pogi/Ganda Points: 70
  • point and shoot
« Reply #6 on: July 02, 2008, 01:21:45 AM »
anu yan ???
« Reply #7 on: July 02, 2008, 08:30:32 AM »
It only indicate that it's insulation resistance is greater than 100 megaohms. Sa industrial application ksi importance ang insulation resistance lalo na kung ilalagay mo sya sa mga panel na may mga high voltages na nkaterminate. Ibig sabihin mataas ang insulation resistance nya at safe gamitin.
Offline Tesla
« Reply #8 on: July 31, 2008, 01:48:21 AM »
This insulation resistance data indicates that the internal conductive components like contacts, coil are insulated to its case, to each other and across an open contact are having a minimum of 100Megohm. This will indicate that there is no moisture or shorted component. With this value, your device is having a very good IR since it even exceeds the 25Megohm minimum for a nominal rating of 250V at a 500Vdc test voltage per NETA ATS 2007 Table 100.1
