Author Topic: Tubig Power Machine  (Read 1732 times)
Re: Tubig Power Machine
« Reply #40 on: November 29, 2011, 01:02:59 PM »
si asimo kausap si asimo????? ;D ;D ;D ;D
baliw baliwan ;D
Offline Pinoy_Tech
  • Pogi/Ganda Points: 181
    • My YT-Channel
« Reply #41 on: November 29, 2011, 09:51:06 PM »
saw an actual  demo of that, water being sprayed to generate DC power. failed BTW.
Failed! So, ibig sabihin yung mga naka installed street lights sa demo nila which
shows okay are not successful? Madami at maliwanag naman at plano pa nilang
mag expand sa mga provinces, are they considered hoax?
Offline iyo karpo
« Reply #42 on: November 30, 2011, 10:48:55 AM »
kung low wattage lang ung ilaw...baka okay pa yan.
basta ang waste nya non-toxic...walang mercury, lead, cadmium
mas safe pa yan sa kandila.
Offline Pinoy_Tech
    • My YT-Channel
« Reply #43 on: November 30, 2011, 09:36:16 PM »
Yap, low wattage nga kasi yung loads ay LED lamp, pero sa mga AM radio kadalasan
4pcs na battery which is 6V, okey rin naman. If low wattage vs low budget production,
pwede na di ba? Ang tanong na lang ay kung hanggang kelan ang life span baka dun matalo.
Offline iyo karpo
« Reply #44 on: November 30, 2011, 09:38:46 PM »
kung mas mahaba pa sa kandila...bakit hindi pede?
Offline robbietan
  • Pogi/Ganda Points: 17
« Reply #45 on: December 01, 2011, 08:07:56 AM »
there also many installed solar powered streetlights and parking lights. failed also.
failed, as in they are not viable commercially and are definitely not a reliable source of power. even for small applications like parking lights inside malls
apqi.ph
Offline iyo karpo
« Reply #46 on: December 01, 2011, 08:35:06 AM »
ung naputulan ng Meralco...mas safe to kaysa kandila.
Offline Pinoy_Tech
    • My YT-Channel
« Reply #47 on: December 01, 2011, 12:59:26 PM »
Thanks to your info.
Offline robbietan
« Reply #48 on: December 05, 2011, 08:51:09 AM »
a demo unit of the water power generator. did not pass expectations as the unit failed several times in lighting the lamp
apqi.ph
« Reply #49 on: December 05, 2011, 09:13:24 AM »
UNLIKE!
