Author Topic: SANYO ST-14CE1/no standby light  (Read 1957 times)
Offline hackerz
  • Pogi/Ganda Points: 5
    • operamini
« on: July 21, 2011, 11:13:37 AM »
ganda araw po,mga master at sis.sanyo tv,naistambay po daw ng 1year,pag on may standby pero second lang nawawala,.Hang ko  tacksw/hout/wala parin pagbbgo help naman po.
god is good all the time
Offline taqui
  • Pogi/Ganda Points: 228
  • ang ganda ko
Re: SANYO ST-14CE1/no standby light
« Reply #1 on: July 21, 2011, 12:39:16 PM »
resoldier muna at voltage read.
Offline x13r_kit_0
  • Pogi/Ganda Points: 150
  • --__x13r_kit_0__--
« Reply #2 on: July 21, 2011, 12:50:37 PM »
 agree,measure voltage muna,
   =How about the other side?=
  • Pogi/Ganda Points: 231
« Reply #3 on: July 21, 2011, 12:55:42 PM »
na stambay ng matagal! check mo mga Ecap especialy in B+ line.
Offline hackerz
    • operamini
« Reply #4 on: July 21, 2011, 01:05:45 PM »
B +110/24v/12/v5v meron po,kaya lang dahan dahan po bumabba hangang maging zero ang voltage.Mga zener diode hang ko vertical ic,ganun parin,
Offline hackerz
    • operamini
« Reply #5 on: July 21, 2011, 01:06:17 PM »
Offline Triple_D
  • Pogi/Ganda Points: 164
« Reply #6 on: July 21, 2011, 01:12:45 PM »
resolder muna..
Offline danyenz
  • Pogi/Ganda Points: 196
« Reply #7 on: July 21, 2011, 01:33:26 PM »
psu lang problema nyan,wag ka lalayo,msfet baka sira na o pwm..
Offline hackerz
    • operamini
« Reply #8 on: July 21, 2011, 01:49:40 PM »
update nalang ako master,.maya.chek ko muna ps/
Offline hackerz
    • operamini
« Reply #9 on: July 21, 2011, 02:54:11 PM »
strw6753 pin 5 cap 1uf50v/1v pero humihinga,sira na po ba eto,salamat po
Offline acer
  • Pogi/Ganda Points: 109
« Reply #10 on: July 21, 2011, 03:17:13 PM »
paki liwanag po
nevergive up
Offline hackerz
    • operamini
« Reply #11 on: July 21, 2011, 04:05:48 PM »
STRW6753 yong pin3 at 5/humihinga tanong ko po,sira na ba eto?Kc secondary..Dahan dahan bumababa voltage,.hang hout vertical,tacksw.Resuldering ko na lahat.
Offline taqui
  • ang ganda ko
« Reply #12 on: July 21, 2011, 04:09:45 PM »
palitan muna yang small ecap sa primary, chek resistor sa feedback..
Offline hackerz
    • operamini
« Reply #13 on: July 21, 2011, 04:24:23 PM »
nag palit na po ako.cap 1uf/at 47uf/resistor primary wala parin po pagbbgo,
Offline Triple_D
« Reply #14 on: July 21, 2011, 04:35:00 PM »
suyod ulit sa ps baka may nakaligtaan pa.
Offline unitech
  • Pogi/Ganda Points: 58
  • all in one hunter
« Reply #15 on: July 21, 2011, 04:58:19 PM »
patambay ...nasa psu lang ang prob. isa isahin na ang lahat ng parts sa primary..
Offline danyenz
« Reply #16 on: July 21, 2011, 05:30:42 PM »
ano chasis nito?
Offline acer
« Reply #17 on: July 21, 2011, 05:47:29 PM »
hanap ka lang nasa psu lang may problem isa isahin mo  mga diode sa secondary check mo na rin yung feedback nyan baka may error kaya hindi nag tutuloy pasok ng supply
nevergive up
Offline hackerz
    • operamini
« Reply #18 on: July 21, 2011, 07:26:00 PM »
bukas po ako update,.Salamat po.
Offline gie62
  • Pogi/Ganda Points: 56
« Reply #19 on: July 21, 2011, 07:41:56 PM »
yung pinalitan mo bang cap sa pin5 ng strw6759? ilan ang voltage sa pin4?
