Author Topic: 1-to-3 transistor circuit design projects  (Read 15016 times)
Offline rommelpm
  • Pogi/Ganda Points: 13
  • learning is a continuous process...
« on: June 02, 2008, 01:37:14 AM »
Kindly post all circuits that you have successfully designed/assembled and tested either by simulation or by actual prototype using up to three transistor devices.
The application could range from a simple audio amplifier, pre-amps, active-filters, basic power supplies, switch mode power supplies, transmitters, robotics...etc   ;)
Offline rommelpm
Re: 1-to-3 transistor circuit design projects
« Reply #1 on: June 02, 2008, 05:05:24 AM »
My experimental active BJT lowpass filter for my Subwoofer:
I actually extracted the basic circuit from the internal circuitry of an IC from which I added Q1 as voltage amp and Q3 as buffer circuit.  For the past 3 years, this circuit is still up and running.  ;)
Offline rommelpm
« Reply #2 on: June 02, 2008, 05:27:05 AM »
SCR equivalent in the BJT world.
During those times when I need the functionality of an SCR, I just go and salvage some old transistor circuits!  :)
Offline 'yus
  • Pogi/Ganda Points: 299
  • hw -> fw -> sw
    • yus' projects
« Reply #3 on: June 02, 2008, 10:52:27 PM »
ang walang kamatayang Astable Multivibrator circuit:
pwedeng gamitin as (push-pull) oscillator o kaya simpleng LED flasher:
Offline Shey
  • Administrator
  • Pogi/Ganda Points: 154
    • Elab.PH
« Reply #4 on: June 02, 2008, 11:09:44 PM »
first multivibrator LED Flasher ko na ginawa ay nung 1992 pa hehehehe
Alone I look for the way
Hoping you are waiting for me
where the hostile world has no say
that is where I always want to be.
Where my eyes want to follow
When I'm far, far away,
When life brings me sorrow,
Into silence I escape.
hoping you are waiting for me
Where my rush of thoughts
in oblivion drowns
to forget the evil lot
I will sleep in safe arms.
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #5 on: June 02, 2008, 11:14:32 PM »
pwede rin ang one-bjt negative resistance oscillator:
http://www.electronicslab.ph/forum/index.php?topic=2199.0
Offline rommelpm
« Reply #6 on: June 03, 2008, 06:41:15 AM »
This is my experimental Differential Amp Preamplifier that I used as input for my guitar amp:
Kadalasang BJT preamps na nakikita ko ay either a single stage CE amp or multistage CE and CC combinations. So I just tried this for a change. ;)
Note: the Hfe for all transistors used in this circuit where assumed to be 100. ;)
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #7 on: June 03, 2008, 02:11:55 PM »
pwede rin ang simple analog Mosfet ORing control:
(simple invention by: Bruce Frederick and Daryl Weispfennig)
pwede nyo itong gawing kung gusto nyong mag-parallel ng dalawang high-current power supply.
yung Q3 will act as "ideal" ORing diode, kaya dapat high current ang rating nya,
saka very low din ang kanyang drain-to-source ON resistance..
yung Q1 & Q2 naman pwedeng general purpose NPN lang, pero dapat ma-match yung temperature nila,
and as suggested, kung pwede dapat iisang package lang sila (like 6-pin sot-23 for thermal tracking).
for detailed explaination ng circuit operation, search nyo na lang sa net (e.g. freepatentsonline).
Offline rommelpm
« Reply #9 on: June 05, 2008, 08:22:21 PM »
A Simple transistorize Sinewave Oscillator:
Upon powering up the circuit, the LC tank will oscillate at its natural resonance until it will decay unless it will be reinforced.
F = 1/(2 x pi x [LC]1/2 )
F = 1.59 Khz
To enable the circuit to continuously oscillate, it needs to be reinforced by returning back the signal to the amplifier. And this can be done through R2 (or even the internal resistance = re).
The oscillation voltage from the tank circuit is being reflected across R2 while R2  serves as an input to the BJT circuit, thus oscillation process will start.
transistor Hfe=100 or higher
R1 can be from 1k to 10K
R2 can be any value lower from 1 to 10ohms. You can also remove this, utilizing only the internal re
From the simulation results:
    F = 1.6 Khz,  3.8Vpp
Offline mArKhAo
  • Pogi/Ganda Points: 70
  • point and shoot
« Reply #10 on: June 05, 2008, 09:26:27 PM »
w0w.  :o
Offline rommelpm
« Reply #11 on: June 05, 2008, 09:27:36 PM »
My Led-Bulb version
I bought a cheap portable rechargeable flashlight and somehow the filament lamp was easily busted.
With some spare White-LEDS that I got a few years back from one of the suppliers (that was 2 dollars each in 1997) I came up with this circuit.
The circuit uses a constant current source to protect the white LEDs from being over driven. Though I should have used a simple Resistor just to limit the current, I am not quit convinced that the internal circuitry of the flashlight would reliably produce a fix voltage especially when recharging it with a 220V source.
Offline 1110000
  • Pogi/Ganda Points: 28
« Reply #12 on: June 05, 2008, 09:42:38 PM »
pede rin boost yan lalagyan ng coil :D
E153C51513
Offline 1110000
« Reply #13 on: June 05, 2008, 10:00:04 PM »
E153C51513
Offline Macgyver
    • MakerDude
« Reply #14 on: June 06, 2008, 01:01:29 AM »
My Led-Bulb version
Paano naderive yung 38mA?
Offline rommelpm
« Reply #15 on: June 06, 2008, 03:43:59 AM »
The voltage drop at R1 is VR1= vd1+vd2 - vbe
vd1 = vd2 = voltage drop across the 1n4148
vbe = transistor base to emitter voltage
VR1 = 0.7 + 0.7 - 0.7 = 0.7
IR1 = VR1/R1 = 0.7/18
IR1 = 0.038A
IR1 = 38mA
Offline rommelpm
« Reply #16 on: June 06, 2008, 04:08:31 AM »
Hmm! interesting ckt, pero ano yung tested  value/ratio nang transformer? ferrite core ba to? at what frequency is this operating? It looks similar to a boost-converter without the capacitor.  8)
Offline ahlburuto
  • E&I tech.
« Reply #17 on: June 06, 2008, 05:36:00 AM »
My Led-Bulb version
bakit di pwedeng resistor na lang ilagay? tanong lang...
Offline rommelpm
« Reply #18 on: June 06, 2008, 05:51:56 AM »
Pwede  naman basta siguradong fix ang voltage source. heto kasing rechargeable flashlight na pinaggamitan ko ay mukhang unstable lalo't directa sa 220V ang pag recharge nito.  :)
Offline ahlburuto
  • E&I tech.
« Reply #19 on: June 06, 2008, 06:36:35 AM »
ah ok.... kaya pala me ganun pa.... yun kasing mga ginagawa ko eh resistor lang. ginadahan ko lang ang housing kasi nilagay ko sa kisame ng bahay ko.
br
