Author Topic: SHARP PRIMO 14v-r70m  (Read 908 times)
Offline ars
  • No man is an island
« on: July 27, 2011, 08:24:36 AM »
mga sis pls help,, damage ung fuse pag e up mo ung power. Ok lng kong nka standby sya.
Action taken...
palit na aku ng reg. STRW5453A, check ko na rin possible defect sa PSU section walang po akung makitang sira. Alam ko may nka encounter na nito pls help sis...TIA
Offline brucetech
Re: SHARP PRIMO 14v-r70m
« Reply #1 on: July 27, 2011, 08:36:07 AM »
palitan m lahat ng maliliit na ecap sa psu,, balikan at suyod mo lahat nang parts sa psu..nsa psu lng yan bro!!!
Offline noman75
  • Pogi/Ganda Points: 262
  • 09335154904 / 032-4848039
    • Here`s my blog....
« Reply #2 on: July 27, 2011, 08:46:14 AM »
try mo muna hang mga secondary outputs lalo na B+ to isolate baka may tama FBT,, tsaka post mo mga vcc f meron when unit is in standby mode...
NoMaNz 4-ever
Believe in Yourself!!! Swallow foods you need but not be greedy, share what you have, who knows you`re teaching now the future MASTERS.....
Here`s my blog....
http://noman75.blogspot.com/
Offline ars
« Reply #3 on: July 27, 2011, 09:03:10 AM »
update ko po kayo bukas sis nasa bahay ung unit.
@ sis noman75..pano ko ma identify kong may tama ung FBT, di na aku mka power up. Na try ko hung ung FBT at HOT, ok ung fuse d naman po full load un. Sa ibang unit ng sharp na gumagamit ng ganitong reg. d po nasisibak ung fuse. Iba to, pag standby ok, pagka power up dun sibak na.
Offline acer
  • Pogi/Ganda Points: 110
« Reply #4 on: July 27, 2011, 09:21:56 AM »
agree voltage reading muna
nevergive up
Offline ars
« Reply #5 on: July 27, 2011, 09:24:28 AM »
mga sis baka meron po kaung mapa nito pwedi pa share for reference lng.  ito email add. ko  kyle_jy@yahoo.com.  TIA
Offline brucetech
« Reply #6 on: July 27, 2011, 09:38:29 AM »
try mo hang lahat ng secondary,ung b+,supply sa sound at supply sa vertical section mo baka isa dyan ang my problema..voltge check kung ok, isa isahin mo load para malaman mo kng alin ang my problema,,huwag mo muna ikabit ung degausing coil mo baka isa din yan sa mga salarin.. check mo na din..
Offline taqui
  • Pogi/Ganda Points: 228
  • ang ganda ko
« Reply #7 on: July 27, 2011, 09:46:36 AM »
TS tanggalin mo muna ang posistor then power on.. GOod luck
mag painit ka muna .. kapag nilalamig..
  • Pogi/Ganda Points: 772
« Reply #8 on: July 27, 2011, 09:48:15 AM »
Offline acer
« Reply #9 on: July 27, 2011, 10:14:18 AM »
check mo bridge diode sama mo na rin ecaps
nevergive up
Offline nathanrico
  • Pogi/Ganda Points: 8
« Reply #10 on: July 27, 2011, 10:22:54 AM »
patambay po para matuto
Offline unitech
  • Pogi/Ganda Points: 58
  • all in one hunter
« Reply #11 on: July 27, 2011, 10:33:05 AM »
hung up muna lahat ng load sa secondary at isaisahin ito kabit kung saan parti ng crkt puputok ang fuse,ceguraduhin na tama ang rating ng fuse mo.
Offline ars
« Reply #12 on: July 27, 2011, 10:42:30 AM »
300+1 =301  master pete salamat
@ sa lahat na nag share tnx. Update ko po kayo bukas.
Offline J@M
  • Pogi/Ganda Points: 125
« Reply #13 on: July 27, 2011, 12:59:46 PM »
POsistor din hula ko d2.
Don't Give up
Offline ars
« Reply #14 on: July 27, 2011, 04:52:42 PM »
sis kong tama ung hula nyu pwedi ko bang palitan to?  may spare ba to. O may ibang way para pang replace nito.
Offline taqui
  • ang ganda ko
« Reply #15 on: July 27, 2011, 04:56:37 PM »
yap available yan.. may relay ba sa decousing at posistor yan?
Offline ars
« Reply #16 on: July 27, 2011, 05:00:40 PM »
 o po sis may relay at saka posistor.
Offline taqui
  • ang ganda ko
« Reply #17 on: July 27, 2011, 05:03:13 PM »
my b+ po ba pag naka standby? kung merun eh try na tanggalin muna tlaga posistor para ma-confirm. at bka kape na kasunod
Offline ars
« Reply #18 on: July 27, 2011, 05:04:51 PM »
ok sis try ko ngayon pag uwi ko...tnx sa advice...more power
Offline m@r
  • Pogi/Ganda Points: 59
« Reply #19 on: July 27, 2011, 05:53:25 PM »
kung ok yong regulator nito, sir paki check nalang main filter ecaps, small ecaps sa primary side direct sub mo nalang, posistor, brigde rectifier diode at yong chopper transformer... isolate mo muna PSU section!
it's not how much what we have but it's how we used what we have...
