Author Topic: 1diy group design & Learn Product Development - 100Wrms Power Amplifier  (Read 9768 times)
Offline 1diyMARKET
  • Pogi/Ganda Points: 4
    • 1 am 1diyTEAM
Re: 1diy group design & Learn Product Development - 100Wrms Power Amplifier
« Reply #120 on: January 06, 2012, 02:02:22 PM »
The moment of truth - fresh from the CNC
When idea turned into reality.
Offline Dandy
  • Pogi/Ganda Points: 31
« Reply #121 on: January 22, 2012, 08:06:46 AM »
before the casing,  here is a capture of the earlier prototype performing Automatic Testing on the software,
The 24/7 test of software functionality,  on the ATE, we seen lock up on the software in the 300 and onward cycles,  I need to solved this software lock up.
The above pix is a setup of the early prototype
Offline Dandy
« Reply #122 on: January 22, 2012, 08:11:00 AM »
The development of this project is finished,  I am proud to present to you the DR100W conCEPT working Modular boards :
1.  DR100W_PA  (Power Amplifier)
This power amp can use 3 chipsets,  TDA8920TH with the least power,   TDA8920BTH with medium power and TDA8950TH with hig power.
More on this thread,   http://www.electronicslab.ph/forum/index.php?topic=30065.msg557421;topicseen#msg557421
Offline Dandy
« Reply #123 on: January 22, 2012, 08:14:39 AM »
2.  DR100W_EQ   (Equalizer)
Integrating the DR100W_EQ and DR100W_CM modules
Offline Dandy
« Reply #124 on: January 22, 2012, 08:20:43 AM »
3.  DR100W_CM  (Control Module)
Early development
Top side with the MCU and EEPROM
with RF interface,  Bluetooth Module and 433 MHz RF
The final prototype
Top side
Bottom side with Bluetooth for access by Home Automation Module
MMI on the LCD
Offline Dandy
« Reply #125 on: January 22, 2012, 08:28:00 AM »
And finally,  on its case :
even assembly is very crucial, due to GND loop interconnecting the different modules, there are those noise heard on the speaker.  So, the only thing the systeme engineer to do is to ....................................... try the "trial and error" isolating and solving the problem.
The fiber glass casing is not as good as the metal casing,  somehow, the low level signal processing module like the DR100W_EQ needs large grounding, otherwise hum is evident.
But finally, system engineers find a way to add gorunding and solved the issue of humming.
Offline Dandy
« Reply #126 on: January 22, 2012, 08:33:19 AM »
The DR100W conCEPT is nothing without a music Source,  so I added internally a MP3 Player - another module that can be ADD-on value on the systems.
The bad thing is that,  this MP3 player is noise noturious, digital signal during SD card playback is really annoying to the ear, like our do diy MP3 player.  Thanksd again to the systems engineer who spent day and night just to solved the noise issue, at least minimized the effect of digital noise during playback, it cannot be completely eliminated.
This MP3 player comes with USB and FM radio.
  • Pogi/Ganda Points: 53
« Reply #127 on: January 22, 2012, 08:40:41 AM »
wow!  :o :o :o
Offline Dandy
« Reply #128 on: January 22, 2012, 08:43:41 AM »
and . . . .  I end here the development.  It is a successful Project using Heart Systems Project Management :  Ladder Systems Product Development,  even in hobby level this tools to manage project can work good.
Thanks to the support of :
Noli, Romel, Bryan, Ariel and Anna
even though, we are ocean and miles apart, your dedication and effort makes this project to move on bit by bit behing the most hectic schedule on real job.
These guys contributed a part of the development, combining all their contributions comes a successful DR100W conCEPT project, its also a successful Team to deliver a project,  this project woudn't be this success without them.
Thanks to all.
Offline BhongTech
  • Pogi/Ganda Points: 152
« Reply #129 on: January 22, 2012, 09:13:05 AM »
nice sir +1 for you.
nice one too sir.
+1 too.
naka fiber glass ang gandang tignan.may blower po ba kayung in-install?
  • Pogi/Ganda Points: 316
« Reply #130 on: January 22, 2012, 09:18:06 AM »
magkano po yang equalizer?
Offline Johannah Aleksandria
  • Pogi/Ganda Points: 136
  • Make it simple
« Reply #131 on: January 22, 2012, 09:32:53 AM »
Maliban po ba sa MP3 player na yan eh analog signal processing na lahat ang dinaanan ng music?
Ang ganda nung development ng project, but i think limited to engineers ang understanding.
Sana merong ebook din kayong dinivelop, at least pwedeng pag-aralan ng iba. Even to the smallest details.
Thanks po sa project na to.
Sana nandyan lang po kayo para sa mga mangyaring katanungan.
Salamat din doon sa kabilang thread about Vacuum tubes, malaking bagay din yun na sana wag din mwala.
Offline Dandy
« Reply #132 on: January 24, 2012, 09:36:56 AM »
Wala po Sir,  hindi po mainit ang heatsink ng DR100W_power amp,  warm lang siya, even the chipset is TDA8950TH.  Adding a exhaust fan (not blower) to suck-out the heat generated inside the casing is nice idea, its better than nothing,  pero hindi ito mandatory.   Note, dapat kung maglagay ng exhaust fan dapat noisess siya
Offline Dandy
« Reply #133 on: January 24, 2012, 09:56:18 AM »
Here are preliminary documents that is shareware and courseware,  please download at 1diycentre website,  the following are the direct links  :
1.  DR100W  control Module  :  http://www.1diycentre.com/1DIY_Issue17_DR100W_control_module.pdf
2.  DR100W equalizer module :    http://www.1diycentre.com/1DIY_Issue16_DR100W_equalizer.pdf
Offline Dandy
« Reply #134 on: January 24, 2012, 10:05:45 AM »
3..  The DR100W power amplifier   :     http://www.1diycentre.com/1DIY_Issue18_DR100W_PA.pdf
4.  The DR100W conCEPT - the project architecture and expandability  :
http://www.1diycentre.com/1DIY_Issue15_DR100W_concept.pdf
I am involved in the documentation,  mas mahirap pa ang mag document kesa sa magdesign.  In liu of this,  if anyone would like to share his view about this project, making it clearer to understand a and can go deeper down to the least component to explained,  you are more than welcome to join and bve our co-author,  thanks for participating in the making and development of the User Manual to be more effective Learning, Trainer Kit and project.
The standard DR100W conCEPT book will be released soon at your favorite bookstore.
Offline ♪ ♫ ♫ ♪ ♪ ♪ ♫ ♫ ♫
« Reply #135 on: February 21, 2012, 09:11:18 AM »
sir Dandy, yong full specs pwede post nyo.
...si sir egizmo pwede yata maka tulong dito, kompleto siya ng instrumento para makuha ito  ;)
Offline BhongTech
« Reply #136 on: February 21, 2012, 09:36:13 AM »
nasanay lang ako sa salitang "blower" pero ang tinutukoy ko po ay exhaust fan :)
sa casing magandang tignan,problema lang sa katagalan magkakaroon ito ng crack dahil sa init na sa unti unti ay naiipun kahit may mga butas,sa mga nag diy nito at gusto nilang mapanatili ang casing ,maganda nga po dito na exhaust fan ay yung bushing type para tahimik. :)
« Reply #137 on: February 21, 2012, 11:42:16 AM »
parang ang trend ngayon ay dapat walang boxfan o blower ang desenyo, problema kasi ang maintenance nito.
pagmay boxfan o blower ang desenyo, dapat may dust filter ang mga ito, at every year itong papalitan depende rin sa accumulation ng dust sa bawat lugar na mapaglalagyan ng device. nakasalalay rin kasi ang tibay at quality ng gamit dito, malaki ang epekto nito sa deterioration ng lifespan ng gamit.
yong ambient temperature natin ang nakikita kung problema dito sa atin, mataas ito kaysa intended ambient temperature ng mga pyesa, kaya airconditioned room nanaman hhayy... ;D
Offline hilltopcrew
« Reply #138 on: February 21, 2012, 12:50:26 PM »
Subscribing...........
Offline 01110011
  • Pogi/Ganda Points: 98
« Reply #139 on: February 21, 2012, 04:28:04 PM »
hehehe safety first daw bago s** ;D ;D ;D
