Author Topic: 1diy group design & Learn Product Development - 100Wrms Power Amplifier  (Read 9770 times)
Offline Dandy
  • Pogi/Ganda Points: 31
Re: 1diy group design & Learn Product Development - 100Wrms Power Amplifier
« Reply #80 on: November 16, 2011, 08:02:25 AM »
Sige sir just inform me kung kailan sya available. Malamang kasi oorder ako ng GSM module sa inyo saka yung RF remote na 4 channels (baka meron kayong 8 channels?)
Basically, Ok na ang DR100W_EQ, may kaunting aayusin lang sa PCB, inaayos pa namin sa mga gustong mag-avail ng hardware, kung hindi naman,  the schematic is  there, puwede na gamitin for experimentation.    Noted iyong hardware na gusto mong i-avail.  Salamat.
Offline Dandy
« Reply #81 on: November 16, 2011, 08:05:49 AM »
<reserved for updated scheamtic and specification for posted soon>
1.  Technical Project Definition
2.  Schematic Diagram
With the DR100W_EQ Hardware finished,  let's see the software point of view,  dedicated for those Audio Hobbyist who might want to  customized the software for this project, para po sa mga nagsisimulang mag-aral ng MCU.
Offline Dandy
« Reply #82 on: November 16, 2011, 08:11:10 AM »
Writing the Program:
Absolutely for beginners with zero background in MCU Programming -  advance Users are encourage to participate to expound the method presented here, maraming salamat.
In the DR100W concept, there are several hardware to control, the LED, 20x4 LCD, Buzzer, tact switch, DR100W_EQ via TTL and I2C,  DR100W_PA  Standby and Mute, Infrared Receiver,  Bluetooth, etc….  all of these hardware is interfaced to the MCU,  the  most basic hardware to control is the LED, so let’s start with the LED.
Schematic Diagram:
1)  LED
Here is the schematic  how the LED is connected to the Atmel AT89S52 MCU – this connection is called current sink.  The LED is connected at Port 3 bit 6 (P3.6)
Target Board:
I would like to use the Smart-H Module,  this module is used with AT89Sxx MCU (8051 core from Atmel), I used it to programmed the MCU on original board designed with AT89Cxx – without ISP programming, with the Smart-H board, I can programmed the MCU on the board without taking out and plugging in the MCU back to the board.
What to do here?
Simply  “lit” the LED,  that LED connected at Port 3 bit 6 (P3.6)
A)  Program Code -  using BASIC   (BASCOM 8051 Compiler):
And here it is,
         P3.6 =0     'let  P3.6 to logic zero, so that the LED will lit
As simple as that.
Note:
In some 8051 derivative from other chipset factory, the code work best
Do      ‘ endless loop – the program just keep running
Loop
End           ‘end of program
Offline Dandy
« Reply #83 on: November 16, 2011, 08:26:18 AM »
The equivalent code in  C,   with keil uVision 2,
B)  Code in C  --- with keil uVision 2
#include <REG51.H>            // include generic 8051 library
sbit led = P3^6;       // declare a variable type sbit for P3.6 << rename port 3.6 as LED>>
void main()      //the main function
    while(1)      //super loop, keep the program running
    led = 0;       //Lit the LED,  by putting LED port to logic 0  [P3.6 = 0 ]
Offline Dandy
« Reply #84 on: November 16, 2011, 08:35:22 AM »
I supposed that, intel 8051 core with Atmel derivative is not your type,  you like AVR core MCU  (from atmel),  and you have ATmega8A.
LED is connected to PortD bit 6, in current sink configuration,  the program will be :
C)  BASCOM AVR
$regfile = "m8def.dat"                        'specify that the chipset is generic ATmge8
Config Portd.6    = Output       'Configure Port D bit 6 as output  to drived the LED
Set  PORTD..6                        'Let PortD.6 Output Logic 1, the initial logic state after power On
PORTD.6 = 0                          'Let port D bit 6 output a  logic zero, so that the LED will lit
Do                                                'keep the program Running
Loop
End                                              'end of program
Here is the Target/Trainer Board
Offline Dandy
« Reply #85 on: November 16, 2011, 08:49:52 AM »
Supposed, there is an Arduino Uno Board you got  on hand for free because you join the raffle promo and you are one of the lucky winner for Arduino Uno :   http://www.electronicslab.ph/forum/index.php?topic=29832.msg552703;topicseen#msg552703,  what is the code looks like, supposed for test, you connected the LED at Arduino board label I/O 13?
D)  Arduino Code
« Reply #86 on: November 16, 2011, 10:15:35 AM »
D)  Arduino Code
ganito ba sis ang hinahanap mo?
  Blink
  Turns on an LED on for one second, then off for one second, repeatedly.
  This example code is in the public domain.
void setup() {
  // initialize the digital pin as an output.
  // Pin 13 has an LED connected on most Arduino boards:
  pinMode(13, OUTPUT);
void loop() {
  digitalWrite(13, HIGH);   // set the LED on
  delay(1000);              // wait for a second
  digitalWrite(13, LOW);    // set the LED off
Offline Dandy
« Reply #87 on: November 16, 2011, 11:44:30 AM »
  Blink
void setup() {
void loop() {
Exactly sis.   The code above shows  a better control of  the LED,
here, maybe a good finding.
In the code above, the LED is connected at I/O 13  in current sourcing connection, thus, a logic 1 lit the LED and logic 0 turn off the LED.   Here is the  testing setup with arduino uno.
With the current sink connection of the LED,  I found out that,  even there is no program,  the LED still lit.    It looks like that, the I/O 13  will be forced to go logic 0 when current enters this port.   This is the same effect as with the code  :
void setup()
  pinMode(13, OUTPUT);             //Define pin 13 as Output to drive the LED
void loop()
  digitalWrite (13, LOW);              //let Pin 13 goes logic low to lit the LED
Here is the connection in the current sink mode
To realized that you control the LED,  you have to blink it - with the code you have provided above, it blinks the LED  , 1 sec ON, 1 sec OFF.   In your sample above, it can really shows that, the LED is being controlled.  Cool!
Offline Dandy
« Reply #88 on: November 16, 2011, 12:11:21 PM »
Let’s try the PIC MCU, PIC16F877A,  connect the LED at PORTB.0  in current sink mode
E)  Mikro C code
#define LED PORTB.0
#define LED ON 0
Void main()
   TRISB =0;   //configure port B  as output
   For (;; )          //endless loop
               LED ON;           //PORTB.0 goes  logic 0 to lit the LED
Note:
The above code is untested <modified --  copy from  Advance PIC Microcontroller, page 189>
Offline Dandy
« Reply #89 on: November 16, 2011, 12:23:31 PM »
We seen above -- from the simple program and task to controll the LED, that, with different MCUs, 8051, avr, pic, etc...., it can do the job  - - - - -  to control the LED,  ( and of coure, not only the LED , it can  control also the  different hardware like LCD, buzzer, Bluetooth, I2C device, etc...)
Let's have a better control of LED,  we know how to turn it on,  so how to turn it off?     In our DR100W conCEPT, the MMI is that,  when the LED is turn Off -- the system is on the standby mode.   When the LED is turned ON , the system is in the active mode.
Let's control the LED  Turn On and Turned OFF -- this is the next task now.
I seen a good thread on how to do this, with many example ....<<Share Your Blinker Code>>>   http://www.electronicslab.ph/forum/index.php?topic=26242.0
<<Share Your Bliner Code>>>
In this thread,   one of our friend posted a BASIC Code  as below,  which I will adapt it to fit our hardware above,  in his program as below :
'This is for AT89S51  with BASCOM 8051
do
  P1.0 = 0           'turn off led
  waitms 200       'wait 200 msec
  P1.0 = 1           'turn on led
loop                  'keep repeating
end
the code above blink the LED connected at P1.0, the LED is connected in current sink with series 470 ohms resistor at pin 1 of AT89s51
I simply modify the P1.0  into P3.6, and modify the Logic output level to  fit the hardware, using BASCOM 8051.
do
      P3.6 = 1              'turn off led
      P3.6 = 0              'turn on led
end
« Reply #90 on: November 17, 2011, 05:56:51 AM »
Lalo tuloy ako na-excite sa hardware. I'll have my MCU ready (16F877 and/or Gizduino).
Offline Dandy
« Reply #91 on: November 17, 2011, 07:55:07 AM »
Here is a complete Code in BASCOM 8051 {Basic Language} that will blink the LED connected at P3.6 at 200 msec
'                 DR100W  conCEPT - - -   Power Amplifier
'                 Heart Systems Elecronic Center [ HSEC ], Baguio City
'                 1diyTEAM Project
'DESCRIPTION :
'this program will blink the LED connected at port 3 bit 6 (P3.6)
'Hardware Note:  ----------------------------------------------HARDWARE NOTE
'  MCU      :  AT89S52 40 pins DIP (ATMEL)
'  Crystal  :  12 MHz
'  Power On_LED:
'        Power_On_LED > P3.6    <Port 3 bit 6>
'Filename   :  Blink_ledp3.6.bas
'           :  Rev. 1.0
'           :  october 11, 2011
'Designer   :
'           :  Heart Systems -  1diyTEAM
'              [http://www.1diycentre.com ]
'Compiler   :
'           :  BASCOM 8051 IDE 2.0.15.0 <Full Version>
'              http://www.mcselec.com
'              Thanks to Mark Alberts for the permission to use BASCOM 8051
'              Demo version to share and distribute to our diy Learners
'Level      :  Shareware <Seminar / uC Workshop 201>  :
'              Simple Micro Controller Programming - Part - 3
'              DR100W conCEPT
'------------------------------------------------------- COMPILER Directives
$regfile = "8052.dat"
'Ang Compiler directive na ito ay para utusan ang Compiler na gamitin ang
'Standard 8052 Core
'--------------------------------------------------------- NAMING VARIABLES
'Ang mga sumusunod na declarations ay para mas madaling tandaan ang pangalan
'ng mga Ports ayon sa function sa program
'LED
   Power_LED   Alias P3.6
'----------------------------------------------------------------INITAILIZATION
'Ang susunod na declaration ay para sa initialization ng values ng mga
'Variables
Const Delayed      = 200      '200 mesec delay
'                              MAIN PROGRAM START
Do
   Power_LED =0     'put P3.6 to logic zero
   Waitms Delayed   'Have a delay so the LED can see as Lighted
   Power_LED =1     'put P3.6 to logic one
   Waitms Delayed   'Have a delay so the LED can see as Turned Off
Loop
'                               END of PROGRAM
End
Offline Dandy
« Reply #92 on: November 17, 2011, 08:01:36 AM »
Thanks to Romel for sharing the code in C using Keil
                 DR100W conCEPT        |
                 Heart Systems Electronic Center [ HSEC ], Baguio City        |
                 DR100W 1diyTEAM        |
DESCRIPTION : Lear How To Blink the LED connected at P3.6 of  AT89S51/52
Romel L. Emperado
1diyTEAM - Mindanao
Nov. 15, 2011
'  HARDWARE NOTE
'  MCU      :  AT89S52/51 40 pins DIL
'  Crystal  :  12 MHz
Software IDE :  KEIL V4
LINK: http://www.keil.com/
PROGRAM NAME: LightALedProgram.c
TARGET BOARD  : NE2ss
Link: http://www.1diycentre.com/product_profile_security.htm
LEVEL            :  Shareware and Courseware
                               START of PROGRAM
#include <REG51.H> // include 8051 register file
/* Function Prototypes */
void delayus(unsigned char delay);
void delayms(unsigned char delay);
sbit blinkingled = P3^6; // decleare a variable type sbit for P3.6
    blinkingled = 0; //Clear port and initialized as output
        blinkingled = ~blinkingled; //Blink the LED
        delayms(1000); //Produce approx 1s delay
/* Simple Software Delay
Function to Produce delay
void delayus(unsigned char delay){
    while(delay--);
void delayms(unsigned char delay){
    while(delay--)
        delayus(149);
/* End of Simple Software Delay */
                               END of PROGRAM
Offline Dandy
« Reply #93 on: November 17, 2011, 09:06:25 AM »
2.  Adding the Tact Switch  and Buzzer    <now we need to control the Buzzer and the Tact Switch>
So much for the LED,  let's control the Tact switch (keyboard)  and  Buzzer (Sound) -- which enriched the MMI between the "User" and our DR100W conCEPT.
The use of these Hardware:
a) Tact Swith = will be used by the User to communicate to the DR100W -- particularly the Control Module
b) Buzzer    = it will enrich sound communication  to the User, example, a "BEEP" confirmation if a key is pressed
From here,  I will be using BASCOM 8051 (Basic Language)  of http://www.mcselec.com - THE Nederlands ,  everyone is welcome to share their code with C, Pascal and Ladder or any other compiler.   That would be nice if someone will share  running uCOS   <while the MMI program is just starting>
Offline Dandy
« Reply #94 on: November 17, 2011, 11:19:10 AM »
2.1  Program to Control the Tact Switch and LED ON  -  the buzzer program is not included.
'This program will let the User to pressed the Power ON/OFF Key and it will  Light ON / Turn OFF the LED)
'  LED ON  = Standby Mode
'  LEd OFF = Active Mode
'                 1diyTEAM Project
'DESCRIPTION :
'Light / Turn OFF the LED)
'  Crystal  :  12 MHz
'  Power On_LED:
'  Power_On_Off_Switch:
'        Power_On_Off_Switch    > P3.3    <Port 3 bit 3>
'Filename   :  Tact_Switch.bas
'           :  Rev. 1.0
'Designer   :
' TARGET Board :
'           :  Smart-H  ISP Board
'              Simply for testing
'Compiler   :
'              DR100W conCEPT
'Standard 8052 Core
'--------------------------------------------------------- CONFIGURATIONS
'LED
   Power_led            Alias P3.6
'Tact Switch
   Power_on_off_Switch  Alias P3.3
   'I will Turn ON the Power On/OFF LED  upon Power ON, this will indicate
   'that the system by default is on the Standby Mode
   Reset Power_LED      '<<<I used Reset Power_LED   instead of Power_LED = 0>>
                        '<<which is the same effect>>>
'The following code, checking ang tact switch kung may pumindot,  kung may
'pumindot sa Tact switch, tatakbo ito sa label na Power_ON_LED_Status
      Do
         Debounce Power_on_off_Switch, 0, Power_ON_LED_Status, Sub
      Loop
'The code will check the status of the Power_LED,  if it is lit, it turned off
'If it is turned off, it will lit,
   Power_ON_LED_Status:
      If  Power_LED = 0  then
         Power_LED =1         'Turn OFF the LED, system is Active Mode
      Else
         Power_LED = 0        'Turn ON the LED, system is Standby Mode
      End If
   Return
'                               END of PROGRAM
End
Offline Dandy
« Reply #95 on: November 17, 2011, 11:27:00 AM »
2.2  Program to control the LED,  Tact Switch and Buzzer :
'DESCRIPTION :
'this program will let the User to pressed the Power ON/OFF Key and it will Light ON  / Turn OFF the LED.  Everytime the User pressed the  Power ON/OFF Key, the buzzer will emit "Beep"
LED STatus:
'                 1diyTEAM Project
'DESCRIPTION :
'Light / Turn OFF the LED.  Everytime the User pressed the  Power ON/OFF Key,
'The buzzer will emit "Beep"
'  Crystal  :  12 MHz
'  Power On_LED:
' Buzzer:
'        Buzzer > P2.2    <Port 2 bit 2>
'Filename   :  Tact_Switch_Put_LED_Status_Subroutine.bas
'           :  Rev. 1.0
'Designer   :
' TARGET Board :
'           :  NE2ss - SHSP
'           :  http://www.1diycentre.com/product_profile_security.htm
'Compiler   :
'              DR100W conCEPT
'Standard 8052 Core
'LED
'Tact Switch
'Buzzer
   Buzzer               Alias P2.2
'This jump instruction to the MAIN PROGRAM will "skip" the Subroutine to execute
'You do not actually need the Subroutine now,  it is the MAIN Program
'that will call the Subroutine
Goto START_PROGRAM
'                             SUBROUTINE / FUNCTIONS
Declare Sub Keypressed_Tone   '---------------------------------Keypressed_Tone
Sub Keypressed_Tone
   Sound Buzzer , 200 , 100         'duration = 200,  Frequency = 100
   Set Buzzer                       'this instruction is inserted to make
                                    'it sure that buzzer port will end in
                                    'logic 1 so as not to consume power
                                    'when P2.2 port end in logic 0, as due
                                    'to the connection of current Sink
End Sub
Power_ON_LED_Status:  '------------------------------------- Power On/OFF  LED
'The Keypressed_Tone  instruction will Sound the Buzzer
      Keypressed_Tone
      Else
      End If
   Return
START_PROGRAM:
'pumindot sa Tact switch, tatakbo ito sa label na Power_ON_LED_Status doon
'sa Subroutine
      Do
      Loop
'                               END of PROGRAM
End
Offline Dandy
« Reply #96 on: November 17, 2011, 12:22:13 PM »
3. Adding the LCD Module
The next thign to control is the LCD Module.   You can use trhe Industry Standard 16x2 or 20x4 LCD Module.  For DR100W conCEPT, we are aiming for 20x4 LCD,  but if you have the 16x2 LCD Module,  you can also use it.
« Reply #97 on: November 23, 2011, 08:59:36 PM »
Hu hu hu kailan ko kaya masisimulan ito. Sir isama nyo na sa package ko. he he he
Offline 1diyMARKET
  • Pogi/Ganda Points: 4
    • 1 am 1diyTEAM
« Reply #98 on: November 24, 2011, 02:03:22 PM »
i-proto muna lang sis sa univ.pcb, hehehehe,  magastos daw kasi mayroon bagong tsik.
« Reply #99 on: November 24, 2011, 05:58:10 PM »
I already have the controller ready. Yung equalizer na lang, amplifier at speaker protection ang hinihintay ko. Sana mapost ko picture mamya.
