Author Topic: question about Proteus audio simulation.. hehe  (Read 759 times)
Offline romel_emperado
« on: July 30, 2011, 12:04:47 PM »
Hi guys mga sis at boss.. :)
makaka simulate ba tayo ng real audio sa protues? just like serial interfacing pwede nating gamitin ang compim model ng protues to communicate with the physical port of our pc so Im thinking also if protues can communicate with the audio peripheral of our PC..
may ganyan po ba?? ehhe may naka try na ba o nabasa about dito?
Example ay maglalagay ako ng buzzer model tapos tutunog kaya sa spkr ng PC? hmmm
Offline Woots29
  • Pogi/Ganda Points: 344
  • asan si mojacko?
    • Woots Page
Re: question about Proteus audio simulation.. hehe
« Reply #1 on: August 01, 2011, 07:20:23 AM »
yup naka simulate na ako
dahil sa bagal ng pc ko noon putol putol ung sound :D
WootsPC2 Videos  Woots Page
« Reply #2 on: August 01, 2011, 02:23:54 PM »
sure? tutunog pala talaga? any advisable settings para di ako mahirapan? or automatic na pag simulate tunog agad?
Offline Woots29
  • asan si mojacko?
    • Woots Page
« Reply #3 on: August 01, 2011, 07:11:26 PM »
yup automatic na tumunog sakin
« Reply #4 on: August 02, 2011, 01:55:57 AM »
wow pogi points for you sir..
pero ang problema if tutunog kaya if kakanta ako .. hehe
Offline Woots29
  • asan si mojacko?
    • Woots Page
« Reply #5 on: August 02, 2011, 10:06:57 AM »
i-record mo muna ung kanta mo sa format na wav. tapus using audio terminal load mo dun
then speaker na output
sinubukan ko nga ulit ngaun, may niload akong wav file, pero result nya parang palaka ung tunog ;D
« Reply #6 on: August 04, 2011, 12:11:19 AM »
wala akong makitang audio terminal boss.. Im using protues 7.8.. nasa library ba yan ano model name o something.
naisipan ko kasi gumawa ng wav player eh.. ta try ko if gagana
« Reply #7 on: August 04, 2011, 01:30:54 AM »
ako na magsasabi. hindi ganito mag simulate sa proteus nang audio signal.
* NEVER do it in realtime. (duh)
* phono/line/mic level signal ka mag start (function gen tool)
* may "analog analysis" graph ka para makita mo kung clipping or amplifying or distorted yung signal.
* you can even change the ambient temperature sa spice simulation under proteus.
* may settings din if you want your simulation for in-favor of convergence or accuracy.
* don't press play. period. (space bar to simulate)
Offline Woots29
  • asan si mojacko?
    • Woots Page
« Reply #8 on: August 04, 2011, 06:36:09 AM »
nasa generator
i agreeeeeeee pero naintriga ako sa huli. anu pinagkaiba nun?
« Reply #9 on: August 04, 2011, 08:49:55 AM »
^ magrerender muna yung audio bago mo marinig yung simulation.
« Reply #10 on: August 04, 2011, 09:13:28 AM »
Offline Woots29
  • asan si mojacko?
    • Woots Page
« Reply #11 on: August 10, 2011, 06:39:44 AM »
ah right yan gusto ko
+1 ;D
