Author Topic: Nice 50W Amp  (Read 3566 times)
Offline Woots29
  • Pogi/Ganda Points: 344
  • asan si mojacko?
    • Woots Page
Re: Nice 50W Amp
« Reply #20 on: August 06, 2011, 01:33:48 PM »
Blameless nga di ba?
The ckt caters all the possible areas where distortion may occur.
so did you personally tried it?
WootsPC2 Videos  Woots Page
Re: Nice 50W Amp
Offline Johannah Aleksandria
  • Pogi/Ganda Points: 138
  • Make it simple
Re: Nice 50W Amp
« Reply #21 on: August 06, 2011, 01:42:04 PM »
Di pa, balak pa lang.
Nadala lang ako sa nabasa ko tungkol dito. Naniwala.
IMO, mganda pagka-design.
Re: Nice 50W Amp
Offline Woots29
  • asan si mojacko?
    • Woots Page
Re: Nice 50W Amp
« Reply #22 on: August 06, 2011, 02:05:45 PM »
so panu kung i-overdrive ko itong amplifer
magdidistort kaya?
Re: Nice 50W Amp
  • Make it simple
Re: Nice 50W Amp
« Reply #23 on: August 06, 2011, 02:09:24 PM »
magdidistort kaya?
Bah, gusto ko yan sir ah, overdrive.
Palagay ko di na magdidistort, distorted na eh. ;D ;D ;D
Re: Nice 50W Amp
Offline Mayalin22
  • Pogi/Ganda Points: 402
Re: Nice 50W Amp
« Reply #24 on: August 06, 2011, 02:14:34 PM »
May I make and assertion that the amplifier performance cannot be judged by (how well) the circuit (was designed) alone. There is one equally important component that is generally not given due attention by casual builders: the PCB Layout. Two identical circuits laid out differently will not give identical performance.
Take this as a preview of my upcoming thread  150W+150W Class D Amplifier. SHAMELESS PLUG ;D
Yes, I am joining the audio amplifier craze! ;D ;D :D
start na yan sis born SHAMELESS PLUG  ;D ;D ;D
Re: Nice 50W Amp
  • Pogi/Ganda Points: 321
Re: Nice 50W Amp
« Reply #25 on: August 06, 2011, 02:17:08 PM »
5.7 DISTORTION 7: NFB Takeoff point distortion.
There is a subtle trap in applying global NFB. Class-B output stages are awash with large halfwave-rectified currents, and if the feedback takeoff point is in slightly the wrong place, these currents contaminate the feedback signal, making it an inaccurate representation of the output voltage, and so introducing distortion; Fig 29 shows the problem.
At these current levels, all wires and PCB tracks must be treated as resistances, and it follows that point C is not at the same potential as point D whenever TR2 conducts. If feedback is taken from D, then a clean signal is established here, but the signal at output point C has a half- wave rectified sinewave added to it, due to the resistance C-D. The output will be distorted but the feedback loop does nothing about it as it does not know about the error. Fig 30 shows the practical result for an amplifier driving 100W into 8-Ohm. The resistive path C-D that did the damage was a mere 6mm length of heavy-gauge wirewound resistor lead.
To eliminate this distortion is easy, once you are alert to the danger. Taking the NFB feed from D is not advisable as D is not a mathematical point, but has a physical extent, inside which the current distribution is unknown. Point E on the output line is much better, as half-wave currents do not flow through this arm of the circuit.
 pcb layout pa lang pamatay na.;D
Offline Woots29
  • asan si mojacko?
    • Woots Page
Re: Nice 50W Amp
« Reply #26 on: August 06, 2011, 02:28:44 PM »
since itong amplifier eh 1Vrms ang input
panu kaya kung 2V na-input ko? magdidistort kaya?
  • Make it simple
Re: Nice 50W Amp
« Reply #27 on: August 06, 2011, 02:31:56 PM »
Hindi pa.
Kasi 2v p-p eh. ;D ;D ;D
  • Pogi/Ganda Points: 540
Re: Nice 50W Amp
« Reply #28 on: August 06, 2011, 02:46:43 PM »
this is a typical 3 stage ss amp.....
input impedance is about 10k, midband gain is 20 or 21 if you will......so that at 2volts rms input, output is supposed to be 42volts rms, question is will the output be distorted?
let us see.....with rails of +/- 37 volts, assuming that this rail will not sag with load.....and that collector saturation voltage is 2 volts, and that negligible ang drop sa 0.1ohm emitter degeneration resistors....
peak voltage then is 35volts peak or 24.5 volts rms....so that our output is severely distorted as you try to increase output voltage beyond 26volt say....
so answer is yes, it will be distorted....
Re: Nice 50W Amp
« Reply #29 on: August 06, 2011, 02:48:53 PM »
2 volt peak to peak is 1 volt peak and 0.7volts rms.....
with a gain of 21 output becomes 14volts.....kaya pa nung amp....
Offline Woots29
  • asan si mojacko?
    • Woots Page
Re: Nice 50W Amp
« Reply #30 on: August 06, 2011, 02:50:18 PM »
wel said sir tony +1 ;D
Re: Nice 50W Amp
« Reply #31 on: August 06, 2011, 02:51:51 PM »
i used the mj4502 and mj802 to build DAN Meyer's Tigersaurus amps back in the 80's, i get them from Variproducts......now obsolete....
the MJ15003/15004 are better subs....
  • Make it simple
Re: Nice 50W Amp
« Reply #32 on: August 06, 2011, 02:57:37 PM »
Tumama ako dahil ginawang p-p. ;D ;D ;D
Offline Woots29
  • asan si mojacko?
    • Woots Page
Re: Nice 50W Amp
« Reply #33 on: August 06, 2011, 04:08:05 PM »
since the given input of amplifer is in Vrms
my question is also is in Vrms also :)
  • Make it simple
Re: Nice 50W Amp
« Reply #34 on: August 06, 2011, 08:26:00 PM »
Eh may sumalo eh, nkalusot ako.
  • Make it simple
Re: Nice 50W Amp
« Reply #35 on: August 06, 2011, 08:27:37 PM »
Ito na lang gawin natin.
Could anybody suggest a Class-G output out of this amp?
  • Pogi/Ganda Points: 433
Re: Nice 50W Amp
« Reply #36 on: August 06, 2011, 09:08:40 PM »
Galing ba ito ng libro talaga ni doug sarili?
Meron naglagay nyan dito.
Re: Nice 50W Amp
« Reply #37 on: August 07, 2011, 07:28:48 AM »
bakit pa? gawin mo na lang....ikaw ang nangmention, ikaw ang gumawa....
  • Make it simple
Re: Nice 50W Amp
« Reply #38 on: August 07, 2011, 07:56:12 AM »
Galing nga to kay Douglas Self.
It is a nice book i acquired. I think i may start my learning from that book.
  • Make it simple
Re: Nice 50W Amp
« Reply #39 on: August 07, 2011, 07:58:35 AM »
Oo nga eh.
Kaya lang baka gusto rin ng iba gumawa, pwede kaming magtulungan.
Re: Nice 50W Amp
