Author Topic: Nice 50W Amp  (Read 3565 times)
  • Pogi/Ganda Points: 540
Re: Nice 50W Amp
« Reply #40 on: August 07, 2011, 08:02:30 AM »
Oo nga eh.
Kaya lang baka gusto rin ng iba gumawa, pwede kaming magtulungan.
why don't you start another thread about class G? get engel dela pena chime in, lumalabas he is the expert in class G now.....link mo yung threads nya sa diysudio....
Re: Nice 50W Amp
Offline Johannah Aleksandria
  • Pogi/Ganda Points: 138
  • Make it simple
Re: Nice 50W Amp
« Reply #41 on: August 07, 2011, 08:26:30 AM »
Meron na nga akong thread sa Class-G eh, tingnan mo.
It was termed "working".
Re: Nice 50W Amp
Offline TinTopHack
  • Pogi/Ganda Points: 154
Re: Nice 50W Amp
« Reply #42 on: August 11, 2011, 10:53:43 AM »
Build and be satisfied.
ito nga yung blameless amp by doug self, nababasa ko ito sa DIYaudio
more info on this amp: http://douglas-self.com/ampins/dipa/dipa.htm#6
It is interesting to note that all the ideas presented by Douglas Self in his Blameless Amp were used by Randy Slone in his amp designs.
Re: Nice 50W Amp
Offline danny
  • Pogi/Ganda Points: 324
Re: Nice 50W Amp
« Reply #43 on: August 11, 2011, 12:23:51 PM »
douglas self and randy slone
are both great audio engineers
too bad, nawala na si randy
sayang talga, nabawasan ng beterano  :(
danny
Re: Nice 50W Amp
  • Make it simple
Re: Nice 50W Amp
« Reply #44 on: August 11, 2011, 12:38:00 PM »
With these ckt sir will it be possible that i would raise the voltage to +/- 80vdc and change the output to a triple stage emitter follower?
Re: Nice 50W Amp
Re: Nice 50W Amp
« Reply #45 on: August 11, 2011, 03:46:30 PM »
there is also robert cordell, william marshal leach, john curl, and walter jung among my favorites....
for tubes, there is norman crowhurst, david hafler, john broskie and others.....
Offline kulit06
  • Pogi/Ganda Points: 8
  • ^_^
Re: Nice 50W Amp
« Reply #46 on: August 11, 2011, 05:23:22 PM »
bakit pa? gawin mo na lang....ikaw ang nangmention, ikaw ang gumawa....
wala bang like dito tulad sa fb? ;D
Offline j a y k e z
  • gimmegaggigsss
Re: Nice 50W Amp
« Reply #47 on: August 11, 2011, 05:26:39 PM »
pa tag po este pa sub pala hehehe ;D
Offline danny
Re: Nice 50W Amp
« Reply #48 on: August 11, 2011, 10:47:27 PM »
yup agree.
its just too many to mention sir tony  :)
danny
Offline TinTopHack
Re: Nice 50W Amp
« Reply #49 on: August 11, 2011, 11:20:15 PM »
It will not be a straightforward thing to do. It will require recalc of circuit values. But yes it is is possible.
  • Make it simple
Re: Nice 50W Amp
« Reply #50 on: August 12, 2011, 09:11:30 AM »
I have tried the P3A which is designed for +/- 35vdc to +/-58vdc with yet no problem. But i change the output stage to a force sharing parallel for 4 output tranny and used it to a 4-ohm load, got no problem.
But for this ckt, i am really not sure it wud work knowing the huge increase in voltage. +/- 37 to +/-80vdc.
Plan ko kasi para sa trafo ko na 55-0-55vac. ;D ;D ;D
Re: Nice 50W Amp
« Reply #51 on: August 12, 2011, 11:26:59 AM »
^if you want to use +/-80 volt rails, see to it that the Vceo ratings of your devices are rated at least 170 volts, 200volts rating is even better....
Offline gorex
  • Pogi/Ganda Points: 47
Re: Nice 50W Amp
« Reply #52 on: June 02, 2012, 11:30:49 AM »
Re: Nice 50W Amp
« Reply #53 on: June 02, 2012, 11:51:54 AM »
parang may similarity sa dx amp st:
http://users.tpg.com.au/users/gerskine/dxamp/DX%20Blame%20ST%20Schematic.pdf
the difference is in the VAS, instead of a CCS, a bootstrapping network was used as VAS collector load....
variation on the same theme.....topologies are quite easy to figure out.....typical bjt ss amp consists of 3 stages...
1. input stage, can be common emitter, or ltp, can be single ended or complimentary-symmetrical, ltp's can be either npn's or pnp's...loading can be thru using plain resistor, or current mirrors or ccs....
2. voltage amplifying stage or VAS, can be single ended or push-pull, this is the stage that produces the voltage swing sent to the speakers..
3. Output stage, more often than not push-pull, can be a quasi-complimentary or complimentary symmetry....can be a simple Darlington, or a triple Darlington....this is the stage that delivers current to the speaker....
knowing the basic building blocks of a bjt amp, it is easy to see what the designer has in mind in coming up with such a circuit....
Offline jiggins20
Re: Nice 50W Amp
« Reply #54 on: June 03, 2012, 08:12:57 AM »
ilan po gain ng amp?...paano po pgcompute pag meron nkaparallel 330 doon sa 10k feedback resistor
Audio amp addict
Re: Nice 50W Amp
« Reply #55 on: June 03, 2012, 09:31:03 AM »
good question......voltage gain = R8/R9 = 10000/500 = 20 at midband,
the corner frequency formed by the shunt leg of the feedback network R9/C2 = 1.45hz, http://www.sengpielaudio.com/calculator-RCpad.htm
the R30 in series with C7 has a corner frequency of 32mhz......i am not sure why the designer chose this value, the fT of the output devices are at best 2mhz...but at 20khz a 15pf cap has an impedance of about 530k so that we can ignore it...http://www.kusashi.com/reactance-c.php
Offline gorex
Re: Nice 50W Amp
« Reply #56 on: June 03, 2012, 09:38:33 AM »
Thanks Sir Tony plus 1 .yung sa P3A same procedure din sa pag compute ng gain sa feedback? at yung frequency?
Re: Nice 50W Amp
« Reply #57 on: June 03, 2012, 11:40:25 AM »
thanks, same din ang computations for gain and frequency, you can use the links i posted to calculate on your own.......
  • Pogi/Ganda Points: 433
Re: Nice 50W Amp
« Reply #58 on: June 03, 2012, 11:43:50 AM »
Makikibasa uli.
Offline jiggins20
Re: Nice 50W Amp
« Reply #59 on: June 03, 2012, 11:53:43 AM »
maraming salamat po sir tony...
Audio amp addict
Re: Nice 50W Amp
