Blameless nga di ba?The ckt caters all the possible areas where distortion may occur.
so did you personally tried it?
so panu kung i-overdrive ko itong amplifermagdidistort kaya?
May I make and assertion that the amplifier performance cannot be judged by (how well) the circuit (was designed) alone. There is one equally important component that is generally not given due attention by casual builders: the PCB Layout. Two identical circuits laid out differently will not give identical performance.Take this as a preview of my upcoming thread 150W+150W Class D Amplifier. SHAMELESS PLUG Yes, I am joining the audio amplifier craze!
Bah, gusto ko yan sir ah, overdrive.Palagay ko di na magdidistort, distorted na eh.
since itong amplifier eh 1Vrms ang input panu kaya kung 2V na-input ko? magdidistort kaya?
2 volt peak to peak is 1 volt peak and 0.7volts rms.....with a gain of 21 output becomes 14volts.....kaya pa nung amp....
since the given input of amplifer is in Vrmsmy question is also is in Vrms also
Ito na lang gawin natin.Could anybody suggest a Class-G output out of this amp?
Galing ba ito ng libro talaga ni doug sarili?Meron naglagay nyan dito.
bakit pa? gawin mo na lang....ikaw ang nangmention, ikaw ang gumawa....
