Author Topic: NEW - Unlock Sandbox/Redbox/Sun HUAWEI E153-u1 E153-u2 and E153-u3  (Read 1824 times)
Offline BANNEDMemberAccount
  • Pogi/Ganda Points: 130
  • You have No GOD?, You have No Peace of mind.
    • Hay tita lengwahe mo bading na bading halata na talaga, napaka-awkward! gack!!!
warning: TAKE YOUR OWN RISK
<<<Base ito Dito sa Site na Dito-(Click Me)->>>>
process ito ng Smartbro ko, model E153-u3: sa other network and model clicked ang site sa taas ^
- Upgrade ang firmware ng smartbro using Globe firmware update <<<Dito sa Site na ito(Click Me)>>>>
TAKE note that your modem accepting only globe sim after upgrading
now the device accepting Globe sim
-INSERT Smart sim (insert globe sim Para makita na globe na ang inaacept ng device mo, nde na niya iaaccept yung smart sim mo, tanggalin yung globe sim at insert niyo  smart sim para sa next process ng sola)
-Next Download Sola <<<(Click Me)>>>>
-Click Setting and change the comport to modem port, then click connect
-Click Read Device info --> if get a error check your comport, --> Click Caculate
-To Function, Select -> Reset Clck.  if the sim status = sim is not Accepted. do Click again "do job" until t accepted
Result
SmartBro
Globe
Wag HIHITHIT ng Katol para hinde Tamang Hinala  Account is permanently BANNED due to Accumulation of forum rules and violations.
Re: NEW - Unlock Sandbox/Redbox/Sun HUAWEI E153-u1 E153-u2 and E153-u3
« Reply #1 on: August 06, 2011, 07:17:27 PM »
macheck nga ito pag-uwe ko sa bahay ^________^^
« Reply #2 on: August 06, 2011, 10:22:50 PM »
Ito na lang masasabi ko. Isang impakta point sa iyo.  +1
Sis meron na rin ba sa mf 100?
« Reply #3 on: August 06, 2011, 10:35:15 PM »
^ unlock code lang meron ako sir saka yung offline dc_unlocker
« Reply #4 on: August 06, 2011, 10:41:21 PM »
Paot isa na lang.
Yung 15o16 digit ba yan sis na calculator? Yung sa dc kasi nauunlock kaso pagbalik uli lock na naman.  :D
Offline lightelectro
  • Pogi/Ganda Points: 51
    • Android Tablet Lover
« Reply #5 on: August 06, 2011, 10:47:50 PM »
Subscribing. 8)
LATEST ANDROID TABLET NEWS
http://androidtabletlover.blogspot.com/
« Reply #6 on: August 06, 2011, 10:56:35 PM »
Paot isa na lang.
15o16?
« Reply #7 on: August 06, 2011, 11:10:51 PM »
15 digit yata yung para sa sandbox unlock code sis red smart. Yung dati daw kasi ay 8 digit lang.
« Reply #8 on: August 07, 2011, 08:23:17 AM »
oo nga po, pwedi rin pala gumamit ng firmware ng galing sa ibang bansa na network basta parehong model para mas madaling i-unlock :)
« Reply #9 on: October 29, 2011, 10:00:10 PM »
Sakin lagi failed..huhu
« Reply #10 on: October 29, 2011, 10:44:24 PM »
sa unlock failed? ulitin mo sir atleast 2 times
« Reply #11 on: October 29, 2011, 10:48:40 PM »
Temporary unlock lng yan...pag hinugot mo...repeat mo enter code sa SOLA...
« Reply #12 on: October 29, 2011, 10:50:41 PM »
Ayaw talaga  binibing Red :) siguro dahil ito din gamit ko pang-connect sa internet.. Kaylangan ba separate din yung sa internet para makaupdate?
@ sir kaskas :D
Uu, temp.  unlock nga.. Pinakaeffective talaga is DC Unlocker.. Kaya lang mahal ng credits..
« Reply #13 on: October 29, 2011, 10:54:44 PM »
don't know if supported na to ng FG ko..
Offline Lola Baciang
  • Pogi/Ganda Points: 131
« Reply #14 on: October 29, 2011, 11:18:16 PM »
Patambay muna mga sis
Expect The Unexpected
Offline centOS
  • screw the screw
« Reply #15 on: November 15, 2011, 09:26:07 AM »
subokan nyo ganito
1. Fire-up your browser and type 192.168.1.1 onto the address bar, then press "enter", then log-in with your user-account details.
By default, here are the user-account details:
ISP Provider: Globe
Username: admin
Password: gtadmin
ISP Provider: Smart
Username: admin
Password: smartbro
2. Next is be sure to have your IMEI #; password; and such details prepared for the unlocking that might come in handy.
3. Next is to type in this URL again onto the browser's address bar: 192.168.1.1/en/cardlock.asp
4. Input the necessary details that are required on the corresponding fields.
Remember, unlocking the modem will void the warranty. And please do this one at your own risk.
By continuing to do so. I am not responsible to whatever damages it will result to you and your modem. :p
5. Start removing the sim card provided and use another one from another network to make sure it worked well for you.
Huawei B933 na model
Jesus is like a software. He enters your life, scan your problems, edits your tension, downloads solutions, deletes your worries & saves you...
Offline cliffromz23
« Reply #16 on: January 30, 2012, 09:24:56 PM »
try q toh... pa tambay mga sis...
Offline cliffromz23
« Reply #17 on: January 30, 2012, 09:53:11 PM »
bossing panu kung globe tatto e unlock?... no need na ba ang firmware? panu... my smart firmware update bah?
